Hello, I am a new user of dolfinx and I am going to convert the code in this link, https://github.com/ryanfreckleton/dolfin/blob/f8cd6c0b2722bef82f1d429a9e838a4491b30154/python/demo/undocumented/curl-curl/demo_curl-curl.py# , from dolfin to dolfinx version. However, I have trouble in line 121, which is “G = DiscreteOperators.build_gradient(V, P1)”. I cannot find the equivalent command in dolfinx. The code in dolfinx is provided below.
from dolfinx import mesh, fem, plot
from dolfinx.fem import FunctionSpace, Function, Constant, Expression, dirichletbc
from ufl import TrialFunction, TestFunction
import pyvista
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([10, 10, 1])],[20,20,4])
V = FunctionSpace(domain, ("Nedelec 1st kind H(curl)", 1))
dbdt = Constant(domain, (0.0, 0.0, 1.0))
zero = Function(V)
T = Function(V)
tdim = domain.topology.dim
fdim = tdim - 1
boundary_dofs = fem.locate_dofs_topological(V, fdim, boundary_facets)
bc = dirichletbc(zero, boundary_dofs)
a = ufl.inner(ufl.curl(v), ufl.curl(u))*ufl.dx
L = -ufl.inner(v, dbdt)*ufl.dx
a_assembled = fem.petsc.assemble_matrix(fem.form(a))
a_assembled.assemble()
L_assembled = fem.petsc.assemble_vector(fem.form(L))
L_assembled.assemble()
ksp = PETSc.KSP()
ksp.create(PETSc.COMM_WORLD)
ksp.setType("cg")
ksp.setTolerances(rtol=1.0e-8, atol=1.0e-12, divtol=1.0e10, max_it=300)
pc = ksp.getPC()
pc.setType("hypre")
pc.setHYPREType("ams")
P1 = FunctionSpace(domain, ("Lagrange", 1))
G = dolfinx.cpp.fem.petsc.discrete_gradient(V, P1)
pc.setHYPREDiscreteGradient(as_backend_type(G).mat())
constants = [fem.Function(V) for i in range(3)]
for i, c in enumerate(constants):
direction = Constant(domain, [1.0 if i == j else 0.0 for j in range(3)])
c_expr = Expression(direction , V.element.interpolation_points())
c.interpolate(c_expr)
cvecs = [constant.vector for constant in constants]
pc.setHYPRESetEdgeConstantVectors(cvecs[0], cvecs[1], cvecs[2])
pc.setHYPRESetBetaPoissonMatrix(None)
ksp.setOperators(a_assembled)
ksp.setOptionsPrefix("eddy_")
opts = PETSc.Options()
opts.setValue("-eddy_ksp_monitor_true_residual", None)
ksp.setFromOptions()
ksp.solve(L_assembled, T.vector)
I receive the following error.
TypeError: discrete_gradient(): incompatible function arguments. The following argument types are supported:
1. (V0: dolfinx::fem::FunctionSpace, V1: dolfinx::fem::FunctionSpace) -> mat
Invoked with: FunctionSpace(Mesh(VectorElement(Basix element (P, tetrahedron, 1, gll_warped, unset, False), 3), 2), Basix element (N1E, tetrahedron, 1, legendre, unset, False)), FunctionSpace(Mesh(VectorElement(Basix element (P, tetrahedron, 1, gll_warped, unset, False), 3), 2), Basix element (P, tetrahedron, 1, gll_warped, unset, False))
I would be grateful if you could please help me in this regard.
