dokken
February 4, 2025, 7:59pm
5
Currently no, but you can call it with a single map, as for instance done in:
README.md
# TODO
1. Create interface that reads in the original global index from MSH directly
```python
import dolfinx.io
import numpy.typing as npt
import gmsh
gmsh.initialize()
This file has been truncated. show original
create_mesh.py
import gmsh
import argparse
from pathlib import Path
parser = argparse.ArgumentParser(description="Create a mesh for a box in a channel")
parser.add_argument(
"--res", type=float, default=0.05, help="Resolution of the mesh (at inlet)"
mwe_failing.py
from dolfinx import fem
from dolfinx.io.gmshio import model_to_mesh
from dolfinx.io import VTXWriter
import gmsh
from basix.ufl import element
There are more than three files. show original
which was made together with Cristian Ciraci.
filliong:
Also, I was wondering if it would be simpler to generate a periodic mesh directly with GMSH (or any other meshing tools). What would be the behavior of Fenicsx when loading such a mesh? Would it work directly with MPI? Or do we need some mappings somewhere, or some other features?
In theory, one could simplify the code I have made by using information from GMSH. I’ve not had time to do this yet. In the aforementioned example you see gmsh being used for the periodic map on a cube.
The function from script.py should work with MPI out of the box.
