I am trying to solve a Poisson problem with periodic boundary conditions. The meshes I am importing are 3D boxes, but generally these meshes will not be periodic (ie. nodes and/or element edges do not match identically on opposite faces). As a simplified example, I have tried solving the following “manufactured” problem on a 2D rectangular mesh:
for which the exact solution is u_{e} = \sin\left(\frac{2\pi y}{L}\right). Below, I attempt to solve this problem twice: first with matching nodes on the upper and lower portions of boundary \Gamma_P, and then with non-matching nodes.
from math import pi
import os
from dolfinx import mesh, fem, io, common
import dolfinx_mpc
comm = MPI.COMM_WORLD
comm_rank = comm.rank
gmsh.option.setNumber("General.Terminal", 0)
# Domain size and problem definition
L = 1
def u_exact(mod): # mod is either np or ufl
return lambda x : mod.sin(2*pi*x[1]/L)
# Solve Poisson problem with periodic BC's
def solve_periodic(L, h1, h2, i):
# L - size of square domain
# h1 - mesh size 1
# h2 - mesh size 2
# i - counter for file
# Create mesh
if comm_rank == 0:
gmsh.model.add("mesh_{}".format(i))
p1 = gmsh.model.geo.addPoint(0, 0, 0, h1)
p2 = gmsh.model.geo.addPoint(L, 0, 0, h2)
p3 = gmsh.model.geo.addPoint(0, L, 0, h2)
p4 = gmsh.model.geo.addPoint(L, L, 0, h1)
c1 = gmsh.model.geo.addLine(p1,p2)
c2 = gmsh.model.geo.addLine(p1,p3)
c3 = gmsh.model.geo.addLine(p2,p4)
c4 = gmsh.model.geo.addLine(p3,p4)
cl1 = gmsh.model.geo.addCurveLoop([c1,c3,-c4,-c2])
s1 = gmsh.model.geo.addPlaneSurface([cl1])
pg1 = gmsh.model.addPhysicalGroup(2, [s1])
gmsh.model.geo.synchronize()
gmsh.model.mesh.generate(2)
gmsh.write("mesh.msh")
msh = meshio.read("mesh.msh")
meshio.write("mesh.xdmf", meshio.Mesh(points=msh.points[:,0:2], cells={"triangle":msh.get_cells_type("triangle")})) # add cell data if physical groups specified
with io.XDMFFile(comm, "mesh.xdmf", "r") as infile:
domain = infile.read_mesh(name="Grid")
# Boundary definitions
b_Left = lambda x : np.isclose(x[0], 0)
b_Right = lambda x : np.isclose(x[0], L)
b_Bot = lambda x : np.isclose(x[1], 0)
b_Top = lambda x : np.isclose(x[1], L)
# Function space
# Dirichlet boundary conditions - sinusoidal on left and right ends
dofs_L = fem.locate_dofs_geometrical(V, b_Left)
u_L = fem.Function(V)
u_L.interpolate(u_exact(np))
bc_L = fem.dirichletbc(u_L, dofs_L)
dofs_R = fem.locate_dofs_geometrical(V, b_Right)
u_R = fem.Function(V)
u_R.interpolate(u_exact(np))
bc_R = fem.dirichletbc(u_R, dofs_R)
bcs = [bc_L, bc_R]
periodic_boundary = b_Top # specify the "master" surface as bottom (note - this is function pointer)
# Map master (bottom) surface to slave (top) surface (note: this is opposite of old fenics)
def periodic_relation(x):
out_x = np.zeros(x.shape)
out_x[0] = x[0]
out_x[1] = L - x[1]
out_x[2] = x[2]
return out_x
# Periodic boundary - topological
facets = mesh.locate_entities_boundary(domain, domain.topology.dim - 1, periodic_boundary)
arg_sort = np.argsort(facets)
mt = mesh.meshtags(domain, domain.topology.dim - 1, facets[arg_sort], np.full(len(facets), 2, dtype=np.int32))
with common.Timer("~~Periodic: Compute mpc condition"):
mpc = dolfinx_mpc.MultiPointConstraint(V)
mpc.create_periodic_constraint_topological(V, mt, 2, periodic_relation, bcs)
mpc.finalize()
# Variational form
u = ufl.TrialFunction(V)
w = ufl.TestFunction(V)
a = ufl.dot(ufl.grad(w), ufl.grad(u))*ufl.dx
f = -4*pi**2/L**2 * ufl.sin(2*pi*x[1]/L)
L_ = w*-f*ufl.dx
# Solve
problem = dolfinx_mpc.LinearProblem(a, L_, mpc, bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
uh.name = "u"
# Output
with io.XDMFFile(comm, "results_periodic_{}.xdmf".format(i), 'w') as file_results:
file_results.write_mesh(domain)
file_results.write_function(uh,1)
# Evaluate norm
error = fem.form((uh - u_exact(ufl)(x))**2 * ufl.dx)
l2_error = np.sqrt(comm.allreduce(fem.assemble_scalar(error), MPI.SUM))
print(l2_error)
# Solve for different mesh sizes
meshsize_1 = [L/10, L/10]
meshsize_2 = [L/10, L/30]
for i, (h1, h2) in enumerate(zip(meshsize_1, meshsize_2)):
On the periodic mesh, the solution is periodic as expected. However, for the non-periodic mesh shown below, there is some error:
The plot shows the solution along the lower (red) and upper (blue) periodic boundaries, with large deviation between the solutions that grows worse near the ends where the nodes don’t overlap. Any suggestions on how to properly enforce this multi-point constraint using dolfinx_mpc? Thank you in advance.
