Hello everyone,
I am running FEniCS 2018.1.0 from Docker on macOS version 10.14.3, and I encountered an error with dolfin-convert.
I imported a .step geometry file from FreeCAD into Gmsh and created a 3D mesh, which looked completely normal in Gmsh.
Here is my .geo file:
Merge "test3d_cad.step";
SetFactory("OpenCASCADE");
Physical Volume("working_vol") = {1};
Physical Surface("electrode") = {7};
Physical Surface("walls") = {6, 4, 5, 3, 2, 1};
I then ran “dolfin-convert test3d.msh test3d.xml” and received the following error message:
Converting from Gmsh format (.msh, .gmsh) to DOLFIN XML format
File "/usr/local/bin/dolfin-convert", line 132, in <module>
main(sys.argv[1:])
File "/usr/local/bin/dolfin-convert", line 79, in main
meshconvert.convert2xml(ifilename, ofilename, iformat=iformat)
File "/usr/local/lib/python3.6/dist-packages/dolfin_utils/meshconvert/meshconvert.py", line 1301, in convert2xml
convert(ifilename, XmlHandler(ofilename), iformat=iformat)
File "/usr/local/lib/python3.6/dist-packages/dolfin_utils/meshconvert/meshconvert.py", line 1322, in convert
gmsh2xml(ifilename, handler)
File "/usr/local/lib/python3.6/dist-packages/dolfin_utils/meshconvert/meshconvert.py", line 271, in gmsh2xml
num_elements = int(line)
ValueError: invalid literal for int() with base 10: '8 10129\n'
Does anyone know how to solve this issue?
Thank you
