DOLFIN encountered an error
Hi everyone,
I am first using fenics in an attempt to simulate the evolution of a tumor. Hoping to have carried out all the installation steps of fenics (and dolfin) correctly, I am having problems trying to get the right .xml and .pvd files respectively for the execution of the diffusion simulation and for the visualization with paraview.
In particular, in particular from such commands (defDT.py is the code that should produce the indicated outputs) I get the following output:
(base) MAC-2:~ lorenzomarta$ conda deactivate
MAC-2:~ lorenzomarta$ conda activate fenicsproject
(fenicsproject) MAC-2:~ lorenzomarta$ cd Desktop/Pre-simulation/
(fenicsproject) MAC-2:Pre-simulation lorenzomarta$ python defDT.py
File “/Users/lorenzomarta/Desktop/Pre-simulation/defDT.py”, line 9, in
mvc_Dxx = MeshValueCollection(“double”, mesh, “meshDxx.xml”)
File “/Applications/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/dolfin/mesh/meshvaluecollection.py”, line 16, in **new**
return mvc(mesh, dim)
RuntimeError:
*** [fenics-support@googlegroups.com](mailto:fenics-support@googlegroups.com)
*** Error: Unable to read DOLFIN XML data.
*** Reason: Unable to find tag <mesh_value_collection>.
*** Where: This error was encountered inside xmlutils.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset:
How can I proceed? I cannot understand the nature of the error. Could it depend on the right directory or not? How can I check if I am in the right ambient?
