Context
I recently installed the 0.9 stack from source and started going through tutorial examples. Despite matching versions, I kept hitting the same crash at fem.functionspace(...).
My environment:
dolfinx==0.9.0 -
basix==0.9.0 -
ffcx==0.9.0 -
ufl==2024.2.0 -
petsc4pybuilt for real scalars -
venv path looks correct:
.../venv/lib/python3.12/site-packages/...
Example that fails
msh = mesh.create_rectangle(
comm=MPI.COMM_WORLD,
points=((0.0, 0.0), (2.0, 1.0)),
n=(32, 16),
cell_type=mesh.CellType.triangle,
V = fem.functionspace(msh, ("Lagrange", 1))
Error output:
TypeError Traceback (most recent call last)
Cell In[13], line 15
7 from ufl import ds, dx, grad, inner
9 msh = mesh.create_rectangle(
10 comm=MPI.COMM_WORLD,
11 points=((0.0, 0.0), (2.0, 1.0)),
12 n=(32, 16),
13 cell_type=mesh.CellType.triangle,
14 )
---> 15 V = fem.functionspace(msh, ("Lagrange", 1))
File ~/opt/install/fenicsx/venv/lib/python3.12/site-packages/dolfinx/fem/function.py:628, in functionspace(mesh, element, form_compiler_options, jit_options)
625 form_compiler_options = dict()
626 form_compiler_options["scalar_type"] = dtype
--> 628 cpp_element = _create_dolfinx_element(mesh.comm, mesh.topology.cell_type, ufl_e, dtype)
630 cpp_dofmap = _cpp.fem.create_dofmap(mesh.comm, mesh.topology._cpp_object, cpp_element)
632 assert np.issubdtype(
633 mesh.geometry.x.dtype, cpp_element.dtype
634 ), "Mesh and element dtype are not compatible."
File ~/opt/install/fenicsx/venv/lib/python3.12/site-packages/dolfinx/fem/function.py:586, in _create_dolfinx_element(comm, cell_type, ufl_e, dtype)
584 else:
585 basix_e = ufl_e.basix_element._e
--> 586 return CppElement(basix_e, ufl_e.block_size, ufl_e.is_symmetric)
TypeError: __init__(): incompatible function arguments. The following argument types are supported:
1. __init__(self, element: basix::FiniteElement<double>, block_size: int, symmetric: bool) -> None
2. __init__(self, elements: collections.abc.Sequence[dolfinx.cpp.fem.FiniteElement_float64]) -> None
3. __init__(self, cell_type: dolfinx.cpp.mesh.CellType, points: numpy.ndarray[dtype=float64, shape=(*, *)], block_size: int, symmetry: bool) -> None
Invoked with types: dolfinx.cpp.fem.FiniteElement_float64, basix._basixcpp.FiniteElement_float64, int, bool
Thank you.
