Hi all,
I would like to use dolfinx+bempp to solve a magnetostatic problem, which has a boundary condition: phi1_boundary=BEM*phi0_boundary. I create a distributed mesh with dolfinx and would like to use bempp to handle the FEM/BEM problem.
I’m experiencing the following issue, which can be reproduced with the following MWE:
import bempp_cl.api
from bempp_cl.api.external import fenicsx
from dolfinx import mesh
L = 6.0
mesh_size = 0.4
N = int(round(L/mesh_size))
comm = MPI.COMM_WORLD
# Create a DolfinX mesh
domain = mesh.create_box(comm=comm, points=[[0.0, 0.0, 0.0], [L, L, L]],n=[N, N, N], cell_type=mesh.CellType.tetrahedron)
tdim = domain.topology.dim
fdim = tdim - 1
domain.topology.create_connectivity(tdim, 0)
domain.topology.create_connectivity(fdim, 0)
# Print number of boundary facets and number of boundary nodes per rank
# print(f"Rank {domain.comm.rank}: Number of boundary facets = {len(boundary_facets)}", flush=True)
local_has_zero = int(len(boundary_facets) == 0) # 1 if true, 0 otherwise
all_has_zero = comm.allgather(local_has_zero) # everyone receives list of 0/1 flags for all ranks
if comm.rank == 0:
ranks_with_zero_facets = [rank for rank, flag in enumerate(all_has_zero) if flag == 1]
print(f"Ranks with 0 boundary facets = {ranks_with_zero_facets}", flush=True)
# Create the boundary mesh grid for BEMpp from the DolfinX mesh
bempp_grid, bempp_boundary_dofs = fenicsx.boundary_grid_from_fenics_mesh(domain)
# print('Rank {}: BEMpp Number of elements on boundary {}'. format(comm.rank, bempp_grid.number_of_elements), flush=True)
# print('Rank {}: BEMpp Number of vertices on boundary {}'. format(comm.rank, bempp_grid.number_of_vertices), flush=True)
bempp_space = bempp_cl.api.function_space(bempp_grid, "P", 1)
bempp_operator = bempp_cl.api.operators.boundary.laplace.double_layer(
bempp_space, bempp_space, bempp_space)
print(f"Rank {comm.rank}: Created BEMpp grid with {bempp_grid.number_of_vertices} vertices and {bempp_grid.number_of_elements} elements.", flush=True)
the code runs in parallel up to the point where 1 or multiple ranks do not have any node on the boundary. if this happens (for instance for this particular mesh, by requesting 50 ranks), it fails with:
File “XX/miniconda3/envs/fenicsx/lib/python3.12/site-packages/bempp_cl/api/grid/grid.py”, line 57, in init
self._enumerate_edges()
File “XX/miniconda3/envs/fenicsx/lib/python3.12/site-packages/bempp_cl/api/grid/grid.py”, line 508, in _enumerate_edges
self._edges, self._element_edges = _numba_enumerate_edges(self._elements, edge_tuple_to_index)
IndexError: getitem out of range
also, it is unclear to me how to construct the vector phi0_boundary vector if there are ranks that do not have nodes on the boundary.
Thank you for your help!!
