Dolfinx, 'Failure to conjugate test function in complex Form'
I ran into the error ‘ArityMismatch: Failure to conjugate test function in complex Form’ when solving the LinearProblem. I met the same error before when I used f*v instead of inner(f,v) for integral in complex-mode, for a Langrange scalar FunctionSpace.
However, this time I’m using a N1curl vector FunctionSpace and I have (properly?) use ufl.inner for integral. Thanks if someone can tell me where’s my mistake.
from dolfinx import (Function, FunctionSpace, UnitSquareMesh,
has_petsc_complex)
from dolfinx.fem.assemble import assemble_scalar
from ufl import FiniteElement, FacetNormal, TestFunction, TrialFunction, dx, grad, inner, curl, cross
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, ‘./Radiation/Cube_cf.xdmf’, ‘r’) as infile:
mesh = infile.read_mesh(name=‘Grid’)
ct = infile.read_meshtags(mesh, name=‘Grid’)
mesh.topology.create_connectivity(mesh.topology.dim, mesh.topology.dim-1)
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, ‘./Radiation/Cube_mf.xdmf’, ‘r’) as infile:
ft = infile.read_meshtags(mesh, name=‘Grid’)
print(‘has_pestc_complex:’,has_petsc_complex)
elem_type = FiniteElement(‘N1curl’, mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, elem_type)
#define current(J) function
eps = 1e-4
def Delta(x):
values = np.zeros(x.shape)
values[0] = 0
values[1] = 0
values[2] = eps/np.pi/(np.linalg.norm(x, axis=0)* *2 + eps**2)
return values
J = Function(V)
J.interpolate(Delta)
with XDMFFile(MPI.COMM_WORLD, “./Radiation/J.xdmf”, “w”,
encoding=XDMFFile.Encoding.HDF5) as file:
file.write_mesh(mesh)
file.write_function(J)
#construct the problem
n = ufl.FacetNormal(mesh)
a = ufl.dot(v, u)*dx
L = ufl.dot(v, J)*dx
problem = dolfinx.fem.LinearProblem(a, L, u=u, petsc_options={“ksp_type”: “preonly”, “pc_type”: “lu”})
problem.solve()
The xdmf mesh files are not supported to be upload, they are tetraherons mesh of a Cube.
The error still shows when I change from dot to inner
For further posts, please use 3x ` encapsulation for formatting, to ensure that the code is executable with a copy-paste.
The problem is that you are supplying v as the first input to your form. It as to be the second input.
I.e. the following minimal code shows how a working example would look like
from dolfinx import (Function, FunctionSpace, UnitCubeMesh,
has_petsc_complex)
from dolfinx.fem import LinearProblem
print("has_pestc_complex:",has_petsc_complex)
mesh = UnitCubeMesh(MPI.COMM_WORLD, 10, 10, 10)
elem_type = ufl.FiniteElement("N1curl", mesh.ufl_cell(), 1)
# Define current(J) function
eps = 1e-4
def Delta(x):
    values[0] = 0
    values[1] = 0
    values[2] = eps/np.pi/(np.linalg.norm(x, axis=0)**2 + eps**2)
    return values
J = Function(V)
a = ufl.inner(u, v)*ufl.dx
L = ufl.inner(J, v)*ufl.dx
problem = LinearProblem(a, L, u=u, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
problem.solve()
Thanks dokken ! The code is running now.
Sorry for my poor writing, I’ll definitely use 3x` the next time.
Good evening,
I’m trying to run the demo of poisson equation using JupyterLab and i have installed Dolfinx via Docker.
i have encountered the same errorType by implementing the code i found in the FEniCSx Tutorial and i have been searching what i’ve been missing and looked through the Changelog too but that didn’t get me anywhere.
i have tried both dot and inner functions and none of them did work as well.
i wish if you could help me with that.
FEniCSx Tutorial:
the Code:
from dolfinx import mesh
domain = mesh.create_unit_square(MPI.COMM_WORLD, 8, 8, mesh.CellType.quadrilateral)
from dolfinx.fem import FunctionSpace
V = FunctionSpace(domain, ("CG", 1))
from dolfinx import fem
uD = fem.Function(V)
uD.interpolate(lambda x: 1 + x[0]**2 + 2 * x[1]**2)
import numpy
# Create facet to cell connectivity required to determine boundary facets
tdim = domain.topology.dim
fdim = tdim - 1
boundary_facets = numpy.flatnonzero(mesh.compute_boundary_facets(domain.topology))
boundary_dofs = fem.locate_dofs_topological(V, fdim, boundary_facets)
bc = fem.dirichletbc(uD, boundary_dofs)
u = ufl.TrialFunction(V)
f = fem.Constant(domain, ScalarType(-6))
a = ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = f * v * ufl.dx
problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
the Error that i get:
ArityMismatch                             Traceback (most recent call last)
Input In [26], in <cell line: 32>()
     29 a = ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
     30 L = f * v * ufl.dx
---> 32 problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
     33 uh = problem.solve()
File /usr/local/dolfinx-complex/lib/python3.8/dist-packages/dolfinx/fem/petsc.py:508, in LinearProblem.__init__(self, a, L, bcs, u, petsc_options, form_compiler_params, jit_params)
    505 self._a = _create_form(a, form_compiler_params=form_compiler_params, jit_params=jit_params)
    506 self._A = create_matrix(self._a)
--> 508 self._L = _create_form(L, form_compiler_params=form_compiler_params, jit_params=jit_params)
    509 self._b = create_vector(self._L)
    511 if u is None:
    512     # Extract function space from TrialFunction (which is at the
    513     # end of the argument list as it is numbered as 1, while the
    514     # Test function is numbered as 0)
File /usr/local/dolfinx-complex/lib/python3.8/dist-packages/dolfinx/fem/forms.py:139, in form(form, dtype, form_compiler_params, jit_params)
    136         return list(map(lambda sub_form: _create_form(sub_form), form))
    137     return form
--> 139 return _create_form(form)
File /usr/local/dolfinx-complex/lib/python3.8/dist-packages/dolfinx/fem/forms.py:134, in form.<locals>._create_form(form)
    131 """Recursively convert ufl.Forms to dolfinx.fem.Form, otherwise
    132 return form argument"""
    133 if isinstance(form, ufl.Form):
--> 134     return _form(form)
    135 elif isinstance(form, collections.abc.Iterable):
File /usr/local/dolfinx-complex/lib/python3.8/dist-packages/dolfinx/fem/forms.py:108, in form.<locals>._form(form)
    105 if mesh is None:
    106     raise RuntimeError("Expecting to find a Mesh in the form.")
--> 108 ufcx_form, module, code = jit.ffcx_jit(mesh.comm, form,
    109                                        form_compiler_params=form_compiler_params,
    110                                        jit_params=jit_params)
    112 # For each argument in form extract its function space
    113 V = [arg.ufl_function_space()._cpp_object for arg in form.arguments()]
File /usr/local/dolfinx-complex/lib/python3.8/dist-packages/dolfinx/jit.py:56, in mpi_jit_decorator.<locals>.mpi_jit(comm, *args, **kwargs)
     51 @functools.wraps(local_jit)
     52 def mpi_jit(comm, *args, **kwargs):
     53
     54     # Just call JIT compiler when running in serial
     55     if comm.size == 1:
---> 56         return local_jit(*args, **kwargs)
     58     # Default status (0 == ok, 1 == fail)
     59     status = 0
File /usr/local/dolfinx-complex/lib/python3.8/dist-packages/dolfinx/jit.py:204, in ffcx_jit(ufl_object, form_compiler_params, jit_params)
    202 # Switch on type and compile, returning cffi object
    203 if isinstance(ufl_object, ufl.Form):
--> 204     r = ffcx.codegeneration.jit.compile_forms([ufl_object], parameters=p_ffcx, **p_jit)
    205 elif isinstance(ufl_object, ufl.FiniteElementBase):
    206     r = ffcx.codegeneration.jit.compile_elements([ufl_object], parameters=p_ffcx, **p_jit)
File /usr/local/lib/python3.9/dist-packages/ffcx/codegeneration/jit.py:168, in compile_forms(forms, parameters, cache_dir, timeout, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries)
    165     for name in form_names:
    166         decl += form_template.format(name=name)
--> 168     impl = _compile_objects(decl, forms, form_names, module_name, p, cache_dir,
    169                             cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries)
    170 except Exception:
    171     # remove c file so that it will not timeout next time
    172     c_filename = cache_dir.joinpath(module_name + ".c")
File /usr/local/lib/python3.9/dist-packages/ffcx/codegeneration/jit.py:232, in _compile_objects(decl, ufl_objects, object_names, module_name, parameters, cache_dir, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries)
    228 import ffcx.compiler
    230 # JIT uses module_name as prefix, which is needed to make names of all struct/function
    231 # unique across modules
--> 232 _, code_body = ffcx.compiler.compile_ufl_objects(ufl_objects, prefix=module_name, parameters=parameters)
    234 ffibuilder = cffi.FFI()
    235 ffibuilder.set_source(module_name, code_body, include_dirs=[ffcx.codegeneration.get_include_path()],
    236                       extra_compile_args=cffi_extra_compile_args, libraries=cffi_libraries)
File /usr/local/lib/python3.9/dist-packages/ffcx/compiler.py:98, in compile_ufl_objects(ufl_objects, object_names, prefix, parameters, visualise)
     96 # Stage 1: analysis
     97 cpu_time = time()
---> 98 analysis = analyze_ufl_objects(ufl_objects, parameters)
     99 _print_timing(1, time() - cpu_time)
    101 # Stage 2: intermediate representation
File /usr/local/lib/python3.9/dist-packages/ffcx/analysis.py:75, in analyze_ufl_objects(ufl_objects, parameters)
     72     else:
     73         raise TypeError("UFL objects not recognised.")
---> 75 form_data = tuple(_analyze_form(form, parameters) for form in forms)
     76 for data in form_data:
     77     elements += data.unique_sub_elements
File /usr/local/lib/python3.9/dist-packages/ffcx/analysis.py:75, in <genexpr>(.0)
     72     else:
File /usr/local/lib/python3.9/dist-packages/ffcx/analysis.py:156, in _analyze_form(form, parameters)
    153 complex_mode = "_Complex" in parameters["scalar_type"]
    155 # Compute form metadata
--> 156 form_data = ufl.algorithms.compute_form_data(
    157     form,
    158     do_apply_function_pullbacks=True,
    159     do_apply_integral_scaling=True,
    160     do_apply_geometry_lowering=True,
    161     preserve_geometry_types=(ufl.classes.Jacobian,),
    162     do_apply_restrictions=True,
    163     do_append_everywhere_integrals=False,  # do not add dx integrals to dx(i) in UFL
    164     complex_mode=complex_mode)
    166 # Determine unique quadrature degree, quadrature scheme and
    167 # precision per each integral data
    168 for id, integral_data in enumerate(form_data.integral_data):
    169     # Iterate through groups of integral data. There is one integral
    170     # data for all integrals with same domain, itype, subdomain_id
    176
    177     # Extract precision
File /usr/local/lib/python3.9/dist-packages/ufl/algorithms/compute_form_data.py:407, in compute_form_data(form, do_apply_function_pullbacks, do_apply_integral_scaling, do_apply_geometry_lowering, preserve_geometry_types, do_apply_default_restrictions, do_apply_restrictions, do_estimate_degrees, do_append_everywhere_integrals, complex_mode)
    403 # TODO: This is a very expensive check... Replace with something
    404 # faster!
    405 preprocessed_form = reconstruct_form_from_integral_data(self.integral_data)
--> 407 check_form_arity(preprocessed_form, self.original_form.arguments(), complex_mode)  # Currently testing how fast this is
    409 # TODO: This member is used by unit tests, change the tests to
    410 # remove this!
    411 self.preprocessed_form = preprocessed_form
File /usr/local/lib/python3.9/dist-packages/ufl/algorithms/check_arities.py:177, in check_form_arity(form, arguments, complex_mode)
    175 def check_form_arity(form, arguments, complex_mode=False):
    176     for itg in form.integrals():
--> 177         check_integrand_arity(itg.integrand(), arguments, complex_mode)
File /usr/local/lib/python3.9/dist-packages/ufl/algorithms/check_arities.py:170, in check_integrand_arity(expr, arguments, complex_mode)
    168 for arg, conj in arg_tuples:
    169     if arg.number() == 0 and not conj:
--> 170         raise ArityMismatch("Failure to conjugate test function in complex Form")
    171     elif arg.number() > 0 and conj:
    172         raise ArityMismatch("Argument {0} is spuriously conjugated in complex Form".format(arg))
Changing this to
L = ufl.inner(f, v)* ufl.dx
Should resolve the issue.
Thank you so much. it did work.
I have the same problem as Hamdi_Kahloum.
However, it wasn’t fixed by changing L to
Then you need to provide a minimal example that reproduces the issue.
Hello
I’m trying to run the example in the tutorial of Fenicsx. It did well except cannot plotting the image of results
So, can you help me to solve this problem?
Thank you so much for your helps
The following code was copy-pasted from Implementation — FEniCSx tutorial, changing f * v to ufl.inner(f, v) as instructed in messages above.
Code
from dolfinx.fem import functionspace
V = functionspace(domain, ("Lagrange", 1))
import numpy
fdim = tdim - 1
f = fem.Constant(domain, default_scalar_type(-6))
a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = ufl.inner(f, v) * ufl.dx
This code throws error ArityMismatch: Failure to conjugate test function in complex Form
Backtrace
Cell In[19], line 33
     30 L = ufl.inner(f, v) * ufl.dx
     32 from dolfinx.fem.petsc import LinearProblem
---> 33 problem = LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
     34 uh = problem.solve()
File /opt/conda/lib/python3.11/site-packages/dolfinx/fem/petsc.py:762, in LinearProblem.__init__(self, a, L, bcs, u, petsc_options, form_compiler_options, jit_options)
    724 def __init__(
    725     self,
    726     a: ufl.Form,
    732     jit_options: typing.Optional[dict] = None,
    733 ):
    734     """Initialize solver for a linear variational problem.
    735
    736     Args:
    760        "mumps"})
    761     """
--> 762     self._a = _create_form(
    763         a, form_compiler_options=form_compiler_options, jit_options=jit_options
    764     )
    765     self._A = create_matrix(self._a)
    766     self._L = _create_form(
    767         L, form_compiler_options=form_compiler_options, jit_options=jit_options
    768     )
File /opt/conda/lib/python3.11/site-packages/dolfinx/fem/forms.py:249, in form(form, dtype, form_compiler_options, jit_options, entity_maps)
    246         return list(map(lambda sub_form: _create_form(sub_form), form))
    247     return form
--> 249 return _create_form(form)
File /opt/conda/lib/python3.11/site-packages/dolfinx/fem/forms.py:244, in form.<locals>._create_form(form)
    241 """Recursively convert ufl.Forms to dolfinx.fem.Form, otherwise
    242 return form argument"""
    243 if isinstance(form, ufl.Form):
--> 244     return _form(form)
    245 elif isinstance(form, collections.abc.Iterable):
File /opt/conda/lib/python3.11/site-packages/dolfinx/fem/forms.py:186, in form.<locals>._form(form)
    184 if mesh is None:
    185     raise RuntimeError("Expecting to find a Mesh in the form.")
--> 186 ufcx_form, module, code = jit.ffcx_jit(
    187     mesh.comm, form, form_compiler_options=form_compiler_options, jit_options=jit_options
    188 )
    190 # For each argument in form extract its function space
    191 V = [arg.ufl_function_space()._cpp_object for arg in form.arguments()]
File /opt/conda/lib/python3.11/site-packages/dolfinx/jit.py:51, in mpi_jit_decorator.<locals>.mpi_jit(comm, *args, **kwargs)
     47 @functools.wraps(local_jit)
     48 def mpi_jit(comm, *args, **kwargs):
     49     # Just call JIT compiler when running in serial
     50     if comm.size == 1:
---> 51         return local_jit(*args, **kwargs)
     53     # Default status (0 == ok, 1 == fail)
     54     status = 0
File /opt/conda/lib/python3.11/site-packages/dolfinx/jit.py:201, in ffcx_jit(ufl_object, form_compiler_options, jit_options)
    199 # Switch on type and compile, returning cffi object
    200 if isinstance(ufl_object, ufl.Form):
--> 201     r = ffcx.codegeneration.jit.compile_forms([ufl_object], options=p_ffcx, **p_jit)
    202 elif isinstance(ufl_object, ufl.AbstractFiniteElement):
    203     r = ffcx.codegeneration.jit.compile_elements([ufl_object], options=p_ffcx, **p_jit)
File /opt/conda/lib/python3.11/site-packages/ffcx/codegeneration/jit.py:256, in compile_forms(forms, options, cache_dir, timeout, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    253     for name in form_names:
    254         decl += form_template.format(name=name)
--> 256     impl = _compile_objects(
    257         decl,
    258         forms,
    259         form_names,
    260         module_name,
    261         p,
    262         cache_dir,
    263         cffi_extra_compile_args,
    264         cffi_verbose,
    265         cffi_debug,
    266         cffi_libraries,
    267         visualise=visualise,
    268     )
    269 except Exception as e:
    270     try:
    271         # remove c file so that it will not timeout next time
File /opt/conda/lib/python3.11/site-packages/ffcx/codegeneration/jit.py:383, in _compile_objects(decl, ufl_objects, object_names, module_name, options, cache_dir, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    379 libraries = _libraries + cffi_libraries if cffi_libraries is not None else _libraries
    381 # JIT uses module_name as prefix, which is needed to make names of all struct/function
    382 # unique across modules
--> 383 _, code_body = ffcx.compiler.compile_ufl_objects(
    384     ufl_objects, prefix=module_name, options=options, visualise=visualise
    385 )
    387 ffibuilder = cffi.FFI()
    389 ffibuilder.set_source(
    390     module_name,
    391     code_body,
    394     libraries=libraries,
    395 )
File /opt/conda/lib/python3.11/site-packages/ffcx/compiler.py:108, in compile_ufl_objects(ufl_objects, options, object_names, prefix, visualise)
    106 # Stage 1: analysis
    107 cpu_time = time()
--> 108 analysis = analyze_ufl_objects(ufl_objects, options["scalar_type"])  # type: ignore
    109 _print_timing(1, time() - cpu_time)
    111 # Stage 2: intermediate representation
File /opt/conda/lib/python3.11/site-packages/ffcx/analysis.py:94, in analyze_ufl_objects(ufl_objects, scalar_type)
     91     else:
     92         raise TypeError("UFL objects not recognised.")
---> 94 form_data = tuple(_analyze_form(form, scalar_type) for form in forms)
     95 for data in form_data:
     96     elements += data.unique_sub_elements
File /opt/conda/lib/python3.11/site-packages/ffcx/analysis.py:94, in <genexpr>(.0)
     91     else:
File /opt/conda/lib/python3.11/site-packages/ffcx/analysis.py:180, in _analyze_form(form, scalar_type)
    177 complex_mode = np.issubdtype(scalar_type, np.complexfloating)
    179 # Compute form metadata
--> 180 form_data = ufl.algorithms.compute_form_data(
    181     form,
    182     do_apply_function_pullbacks=True,
    183     do_apply_integral_scaling=True,
    184     do_apply_geometry_lowering=True,
    185     preserve_geometry_types=(ufl.classes.Jacobian,),
    186     do_apply_restrictions=True,
    187     do_append_everywhere_integrals=False,  # do not add dx integrals to dx(i) in UFL
    188     complex_mode=complex_mode,
    189 )
    191 # Determine unique quadrature degree and quadrature scheme
    192 # per each integral data
    193 for id, integral_data in enumerate(form_data.integral_data):
    194     # Iterate through groups of integral data. There is one integral
    195     # data for all integrals with same domain, itype, subdomain_id
    199     # all integrals in this integral data group, i.e. must be the
    200     # same for for the same (domain, itype, subdomain_id)
File /opt/conda/lib/python3.11/site-packages/ufl/algorithms/compute_form_data.py:427, in compute_form_data(form, do_apply_function_pullbacks, do_apply_integral_scaling, do_apply_geometry_lowering, preserve_geometry_types, do_apply_default_restrictions, do_apply_restrictions, do_estimate_degrees, do_append_everywhere_integrals, complex_mode)
    424 preprocessed_form = reconstruct_form_from_integral_data(self.integral_data)
    426 # TODO: Test how fast this is
--> 427 check_form_arity(preprocessed_form, self.original_form.arguments(), complex_mode)
    429 # TODO: This member is used by unit tests, change the tests to
    430 # remove this!
    431 self.preprocessed_form = preprocessed_form
File /opt/conda/lib/python3.11/site-packages/ufl/algorithms/check_arities.py:211, in check_form_arity(form, arguments, complex_mode)
    209 """Check the arity of a form."""
    210 for itg in form.integrals():
--> 211     check_integrand_arity(itg.integrand(), arguments, complex_mode)
File /opt/conda/lib/python3.11/site-packages/ufl/algorithms/check_arities.py:203, in check_integrand_arity(expr, arguments, complex_mode)
    201 for arg, conj in arg_tuples:
    202     if arg.number() == 0 and not conj:
--> 203         raise ArityMismatch("Failure to conjugate test function in complex Form")
    204     elif arg.number() > 0 and conj:
    205         raise ArityMismatch(f"Argument {arg} is spuriously conjugated in complex Form")
It was run under DolfinX v0.8.0, installed from conda. The environment may be reproduced using dockerfile below.
Environment
from quay.io/jupyter/scipy-notebook:python-3.11
USER root
RUN apt-get update -q \
        && DEBIAN_FRONTEND=noninteractive \
        apt-get install -qy --no-install-recommends \
        freecad \
        && apt-get autoremove \
        && apt-get autoclean \
        && rm -rf /var/lib/apt/lists/*
# FIXME: use conda package when available for python3.11 #
USER jovyan
run conda install -y -c conda-forge \
    python=3.11 \
    fenics-dolfinx=0.8.0 \
    mpich petsc='*=complex*' \
    python-gmsh \
    jedi-language-server
run find /usr/share/freecad/Mod/ -maxdepth 1 -type d \
    > /opt/conda/lib/python3.11/site-packages/freecad.pth \
    && echo /usr/share/freecad/Ext \
    && echo /usr/lib/freecad-python3/lib \
must be
instead.
