Dolfinx on MacOS conda env, cmake and boost version problem
I keep having trouble using cmake to install dolfinx, I keep getting some error with boost or basix version. I created a conda env, installed all dependencies, but now I have this error that I am not sure what to do anymore. Would appreciate if anyone is able to catch the issue or perhaps help me resolve it.
CMake Error at CMakeLists.txt:275 (find_package):
  By not providing "FindBoost.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "Boost", but
  CMake did not find one.
  Could not find a package configuration file provided by "Boost" (requested
  version 1.70) with any of the following names:
    BoostConfig.cmake
    boost-config.cmake
  Add the installation prefix of "Boost" to CMAKE_PREFIX_PATH or set
  "Boost_DIR" to a directory containing one of the above files.  If "Boost"
  provides a separate development package or SDK, be sure it has been
  installed.
What specific dependencies do you have installed in your conda env?
In general, one would just use the conda package of FEniCS-dolfinx (https://anaconda.org/conda-forge/fenics-dolfinx) and not trying to build it by hand.
What is the motivation for building it by hand?
Thank you for your reply, I have used the provided conda env, initially I made it using the newest python 3.13 version, but that caused errors.
I now made it with python 3.11, I have the following dependencies :
# packages in environment at /Users/Hawraa_1/opt/anaconda3/envs/fenicsx-3-11:
# Name                       Version          Build                  Channel
_python_abi3_support         1.0              hd8ed1ab_2             conda-forge
aiohappyeyeballs             2.6.1            pyhd8ed1ab_0           conda-forge
aiohttp                      3.13.0           py311hdaf2c26_0        conda-forge
aiosignal                    1.4.0            pyhd8ed1ab_0           conda-forge
attrs                        25.4.0           pyh71513ae_0           conda-forge
blosc                        1.21.6           hd145fbb_1             conda-forge
boost                        1.84.0           he764780_7             conda-forge
brotli                       1.1.0            h1c43f85_4             conda-forge
brotli-bin                   1.1.0            h1c43f85_4             conda-forge
brotli-python                1.1.0            py311h7b20566_4        conda-forge
bzip2                        1.0.8            h6c40b1e_6
c-ares                       1.34.5           hf13058a_0             conda-forge
c-blosc2                     2.15.2           h62acda9_1             conda-forge
ca-certificates              2025.10.5        hbd8a1cb_0             conda-forge
cairo                        1.18.4           h950ec3b_0             conda-forge
cctools_osx-64               1010.6           heaa7f0c_1             conda-forge
certifi                      2025.10.5        pyhd8ed1ab_0           conda-forge
cffi                         1.16.0           py311hc0b63fd_0        conda-forge
charset-normalizer           3.4.4            pyhd8ed1ab_0           conda-forge
clang                        16.0.6           default_h510d6ca_15    conda-forge
clang-16                     16.0.6           default_h4651f56_15    conda-forge
clang-19                     19.1.7           default_hc369343_5     conda-forge
clang_impl_osx-64            16.0.6           h8787910_19            conda-forge
clang_osx-64                 16.0.6           hb91bd55_19            conda-forge
clangxx                      16.0.6           default_h1b9e3cd_15    conda-forge
clangxx_impl_osx-64          16.0.6           h6d92fbe_19            conda-forge
clangxx_osx-64               16.0.6           hb91bd55_19            conda-forge
cli11                        2.5.0            h92383a6_0             conda-forge
cmake                        4.1.2            h29fc008_0             conda-forge
compiler-rt                  16.0.6           ha38d28d_2             conda-forge
compiler-rt_osx-64           16.0.6           ha38d28d_2             conda-forge
contourpy                    1.3.3            py311hd4d69bb_2        conda-forge
cpython                      3.11.14          py311hd8ed1ab_1        conda-forge
cycler                       0.12.1           pyhd8ed1ab_1           conda-forge
cyrus-sasl                   2.1.28           h610c526_0             conda-forge
double-conversion            3.3.1            h240833e_0             conda-forge
expat                        2.7.1            h6d0c2b6_0
fenics-basix                 0.10.0.dev0      pypi_0                 pypi
fenics-dolfinx               0.8.0            py311h5dc119b_104      conda-forge
fenics-ffcx                  0.8.0            pyh4af843d_0           conda-forge
fenics-libbasix              0.8.0            h2dcea0d_1             conda-forge
fenics-libdolfinx            0.8.0            hdba04dd_104           conda-forge
fenics-ufcx                  0.8.0            h22f594c_0             conda-forge
fenics-ufl                   2024.1.0         pyhd8ed1ab_0           conda-forge
fftw                         3.3.10           mpi_mpich_h1893886_10  conda-forge
fmt                          11.2.0           hbf61d64_0             conda-forge
font-ttf-dejavu-sans-mono    2.37             hab24e00_0             conda-forge
font-ttf-inconsolata         3.000            h77eed37_0             conda-forge
font-ttf-source-code-pro     2.038            h77eed37_0             conda-forge
font-ttf-ubuntu              0.83             h77eed37_3             conda-forge
fontconfig                   2.15.0           h37eeddb_1             conda-forge
fonts-conda-ecosystem        1                0                      conda-forge
fonts-conda-forge            1                0                      conda-forge
fonttools                    4.60.1           py311he13f9b5_0        conda-forge
freetype                     2.14.1           h694c41f_0             conda-forge
frozenlist                   1.7.0            py311h7a2b322_0        conda-forge
gl2ps                        1.4.2            hd82a5f3_1             conda-forge
glew                         2.1.0            h046ec9c_2             conda-forge
gmp                          6.3.0            hf036a51_2             conda-forge
graphite2                    1.3.14           h21dd04a_2             conda-forge
h2                           4.3.0            pyhcf101f3_0           conda-forge
harfbuzz                     11.4.5           h0ffbb26_0             conda-forge
hdf4                         4.2.15           h8138101_7             conda-forge
hdf5                         1.14.3           mpi_mpich_h116ac41_9   conda-forge
hpack                        4.1.0            pyhd8ed1ab_0           conda-forge
hyperframe                   6.1.0            pyhd8ed1ab_0           conda-forge
hypre                        2.31.0           mpi_mpich_h356c364_1   conda-forge
icu                          75.1             h120a0e1_0             conda-forge
idna                         3.11             pyhd8ed1ab_0           conda-forge
jsoncpp                      1.9.6            h466cfd8_1             conda-forge
kahip                        3.16             h8ff10bf_4             conda-forge
kahip-python                 3.16             py311h041dfb2_4        conda-forge
kiwisolver                   1.4.9            py311ha94bed4_1        conda-forge
krb5                         1.21.3           h37d8d59_0             conda-forge
lcms2                        2.17             h72f5680_0             conda-forge
ld64_osx-64                  951.9            h3516399_1             conda-forge
lerc                         4.0.0            hcca01a6_1             conda-forge
libadios2                    2.10.1           mpi_mpich_haa7c07a_4   conda-forge
libaec                       1.1.4            ha6bc127_0             conda-forge
libamd                       3.3.3            ha5840a7_7100102       conda-forge
libblas                      3.9.0            37_he492b99_openblas   conda-forge
libboost                     1.84.0           hf0da243_7             conda-forge
libboost-devel               1.84.0           h20888b2_7             conda-forge
libboost-headers             1.84.0           h694c41f_7             conda-forge
libboost-python              1.84.0           py311h10847b1_7        conda-forge
libboost-python-devel        1.84.0           py311he764780_7        conda-forge
libbrotlicommon              1.1.0            h1c43f85_4             conda-forge
libbrotlidec                 1.1.0            h1c43f85_4             conda-forge
libbrotlienc                 1.1.0            h1c43f85_4             conda-forge
libbtf                       2.3.2            hca54c18_7100102       conda-forge
libcamd                      3.3.3            hca54c18_7100102       conda-forge
libcblas                     3.9.0            37_h9b27e0a_openblas   conda-forge
libccolamd                   3.3.4            hca54c18_7100102       conda-forge
libcholmod                   5.3.1            h7ea7d7c_7100102       conda-forge
libclang-cpp16               16.0.6           default_h4651f56_15    conda-forge
libclang-cpp18.1             18.1.8           default_hc369343_15    conda-forge
libclang-cpp19.1             19.1.7           default_hc369343_5     conda-forge
libclang13                   19.1.7           default_h7f9524c_5     conda-forge
libcolamd                    3.3.4            hca54c18_7100102       conda-forge
libcurl                      8.14.1           h5dec5d8_0             conda-forge
libcxx                       21.1.3           h3d58e20_0             conda-forge
libcxx-devel                 16.0.6           h8f8a49f_2             conda-forge
libdeflate                   1.24             hcc1b750_0             conda-forge
libedit                      3.1.20250104     pl5321ha958ccf_0       conda-forge
libev                        4.33             h10d778d_2             conda-forge
libexpat                     2.7.1            h21dd04a_0             conda-forge
libfabric                    2.2.0            h694c41f_2             conda-forge
libfabric1                   2.2.0            h1c43f85_2             conda-forge
libffi                       3.4.6            h281671d_1             conda-forge
libfreetype                  2.14.1           h694c41f_0             conda-forge
libfreetype6                 2.14.1           h6912278_0             conda-forge
libgfortran                  15.2.0           h306097a_1             conda-forge
libgfortran5                 15.2.0           h336fb69_1             conda-forge
libglib                      2.84.3           h5fed8df_0             conda-forge
libhwloc                     2.12.1           default_h8c32e24_1000  conda-forge
libiconv                     1.18             h57a12c2_2             conda-forge
libintl                      0.25.1           h3184127_1             conda-forge
libjpeg-turbo                3.1.0            h6e16a3a_0             conda-forge
libklu                       2.3.5            hc7f8671_7100102       conda-forge
liblapack                    3.9.0            37_h859234e_openblas   conda-forge
libllvm16                    16.0.6           hbedff68_3             conda-forge
libllvm18                    18.1.8           default_hd2a208e_9     conda-forge
libllvm19                    19.1.7           hc29ff6c_1             conda-forge
liblzma                      5.8.1            hd471939_2             conda-forge
liblzma-devel                5.8.1            hd471939_2             conda-forge
libnetcdf                    4.9.2            nompi_hf3c7182_116     conda-forge
libnghttp2                   1.67.0           h3338091_0             conda-forge
libntlm                      1.8              h6e16a3a_0             conda-forge
libogg                       1.3.5            he3325bb_1             conda-forge
libopenblas                  0.3.30           openmp_h83c2472_2      conda-forge
libpng                       1.6.50           h84aeda2_1             conda-forge
libpq                        17.6             h5a4e477_2             conda-forge
libptscotch                  7.0.4            h6939ab0_5             conda-forge
libscotch                    7.0.4            hfcec5db_5             conda-forge
libsodium                    1.0.20           hfdf4475_0             conda-forge
libspqr                      4.3.4            h795628b_7100102       conda-forge
libsqlite                    3.50.4           h39a8b3b_0             conda-forge
libssh2                      1.11.1           hed3591d_0             conda-forge
libsuitesparseconfig         7.10.1           h00e5f87_7100102       conda-forge
libtheora                    1.1.1            hfdf4475_1006          conda-forge
libtiff                      4.7.1            haa3b502_0             conda-forge
libumfpack                   6.3.5            h0658b90_7100102       conda-forge
libuv                        1.51.0           h58003a5_1             conda-forge
libvorbis                    1.3.7            ha059160_2             conda-forge
libwebp-base                 1.6.0            hb807250_0             conda-forge
libxcb                       1.17.0           hf1f96e2_0             conda-forge
libxml2                      2.13.8           he1bc88e_1             conda-forge
libzip                       1.11.2           h31df5bb_0             conda-forge
libzlib                      1.3.1            hd23fc13_2             conda-forge
llvm-openmp                  19.1.7           ha54dae1_1             conda-forge
llvm-tools                   16.0.6           hbedff68_3             conda-forge
llvm-tools-19                19.1.7           he90a8e3_1             conda-forge
loguru                       0.7.3            pyh707e725_0           conda-forge
lz4-c                        1.10.0           h240833e_1             conda-forge
matplotlib-base              3.10.6           py311h48d7e91_1        conda-forge
metis                        5.1.0            h3023b02_1007          conda-forge
mpfr                         4.2.1            haed47dc_3             conda-forge
mpi                          1.0.1            mpich                  conda-forge
mpi4py                       4.1.1            py311h59adea6_100      conda-forge
mpich                        4.3.2            h7ea6e94_100           conda-forge
msgpack-python               1.1.2            py311haec20ae_0        conda-forge
multidict                    6.6.3            py311h1cc1194_0        conda-forge
mumps-include                5.7.3            h694c41f_4             conda-forge
mumps-mpi                    5.7.3            h0669c1d_4             conda-forge
munkres                      1.1.4            pyhd8ed1ab_1           conda-forge
mysql-common                 9.3.0            hd00b0ec_0             conda-forge
mysql-libs                   9.3.0            h062309a_0             conda-forge
ncurses                      6.5              h923df54_0
nlohmann_json                3.12.0           h53ec75d_1             conda-forge
numpy                        2.3.3            py311hf157cb9_0        conda-forge
openjpeg                     2.5.4            h87e8dc5_0             conda-forge
openldap                     2.6.10           hd8a590d_0             conda-forge
openssl                      3.5.4            h230baf5_0             conda-forge
packaging                    25.0             pyh29332c3_1           conda-forge
parmetis                     4.0.3            hc9a99f5_1007          conda-forge
pcre2                        10.45            hf733adb_0             conda-forge
petsc                        3.21.5           real_h6bbe012_101      conda-forge
petsc4py                     3.21.5           py311h695f91b_1        conda-forge
pillow                       11.3.0           py311ha88f94d_3        conda-forge
pip                          25.2             pyhc872135_1
pixman                       0.46.4           ha059160_1             conda-forge
pkg-config                   0.29.2           hf7e621a_1009          conda-forge
platformdirs                 4.5.0            pyhcf101f3_0           conda-forge
pooch                        1.8.2            pyhd8ed1ab_3           conda-forge
proj                         9.5.1            h5273da6_0             conda-forge
propcache                    0.3.1            py311ha3cf9ac_0        conda-forge
pthread-stubs                0.4              h00291cd_1002          conda-forge
pugixml                      1.14             he965462_0             conda-forge
pycparser                    2.22             pyh29332c3_1           conda-forge
pyparsing                    3.2.5            pyhcf101f3_0           conda-forge
pysocks                      1.7.1            pyha55dd90_7           conda-forge
python                       3.11.14          h3999593_1_cpython     conda-forge
python-dateutil              2.9.0.post0      pyhe01879c_2           conda-forge
python-gil                   3.11.14          hd8ed1ab_1             conda-forge
python_abi                   3.11             8_cp311                conda-forge
pyvista                      0.46.3           pyhd8ed1ab_1           conda-forge
qhull                        2020.2           h3c5361c_5             conda-forge
qt6-main                     6.8.3            he2a6cc6_4             conda-forge
readline                     8.3              h49f2429_0
requests                     2.32.5           pyhd8ed1ab_0           conda-forge
rhash                        1.4.6            h6e16a3a_1             conda-forge
scalapack                    2.2.0            h8151de6_4             conda-forge
scooby                       0.10.2           pyhd8ed1ab_0           conda-forge
setuptools                   78.1.1           py311hecd8cb5_0
sigtool                      0.1.3            h88f4db0_0             conda-forge
six                          1.17.0           pyhe01879c_1           conda-forge
slepc                        3.21.2           real_h278fd84_300      conda-forge
slepc4py                     3.21.2           py311hb2dbe2f_0        conda-forge
snappy                       1.2.2            h25c286d_0             conda-forge
spdlog                       1.15.3           hcdbecca_1             conda-forge
sqlite                       3.50.4           h64b5abc_0             conda-forge
suitesparse                  7.8.2            ha93ada7_0             conda-forge
superlu                      7.0.0            h9cb3e3b_1             conda-forge
superlu_dist                 9.0.0            ha4643b9_1             conda-forge
tapi                         1300.6.5         h390ca13_0             conda-forge
tbb                          2022.2.0         hc025b3e_1             conda-forge
tk                           8.6.13           hf689a15_2             conda-forge
typing-extensions            4.15.0           h396c80c_0             conda-forge
typing_extensions            4.15.0           pyhcf101f3_0           conda-forge
tzdata                       2025b            h04d1e81_0
unicodedata2                 16.0.0           py311h13e5629_1        conda-forge
urllib3                      2.5.0            pyhd8ed1ab_0           conda-forge
utfcpp                       4.0.8            h694c41f_0             conda-forge
vtk-base                     9.3.1            qt_py311h3403a8e_215   conda-forge
wheel                        0.45.1           py311hecd8cb5_0
wslink                       2.4.0            pyhd8ed1ab_0           conda-forge
xorg-libxau                  1.0.12           h6e16a3a_0             conda-forge
xorg-libxdmcp                1.1.5            h00291cd_0             conda-forge
xz                           5.8.1            h357f2ed_2             conda-forge
xz-gpl-tools                 5.8.1            h357f2ed_2             conda-forge
xz-tools                     5.8.1            hd471939_2             conda-forge
yaml                         0.2.5            h4132b18_3             conda-forge
yarl                         1.20.1           py311ha3cf9ac_0        conda-forge
zeromq                       4.3.5            h6c33b1e_9             conda-forge
zfp                          0.5.5            h4a89273_8             conda-forge
zlib-ng                      2.2.5            he7f0fdc_0             conda-forge
zstandard                    0.25.0           py311h62e9434_0        conda-forge
zstd                         1.5.7            h8210216_2             conda-forge
When I ran cmake, this is the issue I am facing now, still with the basix package:
CMake Error at CMakeLists.txt:318 (find_package):
  Could not find a configuration file for package "Basix" that is compatible
  with requested version "0.10".
  The following configuration files were considered but not accepted:
    /Users/Hawraa_1/opt/anaconda3/envs/fenicsx-env/lib/cmake/basix/BasixConfig.cmake, version: 0.9.0
    /Users/Hawraa_1/opt/anaconda3/envs/fenicsx-3-11/lib/cmake/basix/BasixConfig.cmake, version: 0.8.0
I tried installing basix from git, and pulling an updated package, but got the following :
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
fenics-dolfinx 0.8.0 requires fenics-basix<0.9.0,>=0.8.0, but you have fenics-basix 0.10.0.dev0 which is incompatible.
fenics-ffcx 0.8.0 requires fenics-basix<0.9.0,>=0.8.0, but you have fenics-basix 0.10.0.dev0 which is incompatible.
So it seems to me there is a conflict, one needs version 0.10, another requires 0.8 or 0.9 if I am understanding correctly.
You clearly see here that you have installed the lastest version of basix. This is due to the fact that you probably cloned the repo (which default puts you on the developer branch). You should use git checkout to select the appropriate version (same for ffcx, ufl and dolfinx). And then proceed to installation.
However, this doesn’t answer the question:
-why are you trying to install dolfinx from source with conda as the base environment, when stable releases of dolfinx is already on conda?
I just got it working! I misunderstood the instructions and thought I still had to run the source files to build the c++ core.
