Dolfinx stops to work_ dolfinx dependencies error
I am getting an error recently.
ImportError                               Traceback (most recent call last)
Cell In[3], line 1
----> 1 import dolfinx
File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/__init__.py:34
     30     else:
     31         return output
---> 34 pusimp.prevent_user_site_imports(
     35     "dolfinx", "apt", "https://fenicsproject.discourse.group/",
     36     "/usr/lib/python3/dist-packages",
     37     ["basix", "ffcx", "ufl"],
     38     ["fenics-basix", "fenics-ffcx", "fenics-ufl"],
     39     [False, False, False],
     40     ["", "", ""],
     41     pip_uninstall_call
     42 )
     44 del pip_uninstall_call, pusimp
     46 from dolfinx import common
File /usr/lib/python3/dist-packages/pusimp/prevent_user_site_imports.py:187, in prevent_user_site_imports(package_name, system_manager, contact_url, dependencies_expected_prefix, dependencies_import_name, dependencies_pypi_name, dependencies_optional, dependencies_extra_error_message, pip_uninstall_call)
    171 if counter_error_categories > 1:
    172     import_error = (
    173         f"pusimp has detected the following problems with {package_name} dependencies:\n"
    174         f"{missing_dependencies_error}"
    185         f"If you believe that this message appears incorrectly, report this at {contact_url} ."
    186     )
--> 187     raise ImportError(import_error)
ImportError: pusimp has detected the following problems with dolfinx dependencies:
1) Dependencies imported from a local path rather than from the path provided by apt:
* ufl was imported from a local path: expected in /usr/lib/python3/dist-packages/ufl/__init__.py, but imported from /home/bagla0/.local/lib/python3.10/site-packages/fenics_ufl-2019.1.0-py3.10.egg/ufl/__init__.py.
pusimp suggests to apply all of the following fixes:
1) To uninstall local dependencies:
* run 'pip uninstall fenics-ufl' in a terminal, and verify that you are prompted to confirm removal of files in /home/bagla0/.local/lib/python3.10/site-packages/fenics_ufl-2019.1.0-py3.10.egg/ufl.
You can disable this check by exporting the DOLFINX_ALLOW_USER_SITE_IMPORTS environment variable. Note, however, that this may break the installation provided by apt.
If you believe that this message appears incorrectly, report this at https://fenicsproject.discourse.group/ .
I have uninstalled using pip uninstall fenics-ufl in terminal, but, the error remains same. I don’t know what wrong I did. I remember, I updated the doflinx only. I also reinstalled fenicsx in my ubuntu, but, it doesn’t work
The error says it all. You need to get rid of /home/bagla0/.local/lib/python3.10/site-packages/fenics_ufl-2019.1.0-py3.10.egg, which would hide the apt installation of ufl.
should be the way to uninstall it cleanly. What do you get when running it? Worst case scenario you can simply remove the folder :wink:
