Hello to everyone.
I’m having some issues understanding some concepts in fenics. In the following code, I didn’t enforce any Dirichlet Boundary conditions and the function g doesn’t exist, so my space is still H1 and has a Neumann zero condition on the boundary ? How do the applications of Neumann and Dirichlet boundary conditions work in the sense of H1 and H0 spaces (Sobolev Spaces)? Finally, I’m questioning this because in the following code, without specifying any Dirichlet boundary conditions and setting f as 1, I obtained the following:
domain = Rectangle(Point(-0.5, -0.5), Point(0.5, 0.5))
mesh = generate_mesh(domain, 64)
mesh = refine(mesh)
# Define Dirichlet boundary (x = 0 or x = 1)
def boundary(x):
return x[0] < DOLFIN_EPS or x[0] > 1.0 - DOLFIN_EPS
# Define boundary condition
u0 = Constant(0.0)
bc = DirichletBC(V, u0, boundary)
f = Expression("1", degree=2)
a = inner(grad(u), grad(v))*dx
L = f*v*dx
# Compute solution
solve(a == L, u)
# Save solution in VTK format
file = File("poisson.pvd")
file << u
# Plot solution
from mpl_toolkits.mplot3d import Axes3D
plot(u)
mesh_coordinates = mesh.coordinates()
x, y = mesh_coordinates[:, 0], mesh_coordinates[:, 1]
# Extract the values of u at mesh vertices
u_values = u.compute_vertex_values(mesh)
# Plot 3D solution of u
fig = plt.figure()
ax = fig.add_subplot(111, projection='3d')
ax.plot_trisurf(x, y, u_values, cmap='viridis')
ax.set_title("3D Solution of u")
And I expected the solution closer to 1.
Thanks.
