Hi all,
I’m trying to model acoustic waves using DG. I have roughly followed the DG discretization described in this thesis. My implementation seems to work. The problem is that it runs slower than a CG version of the same code, for practical number of time steps (>1000). DG’s mass matrix is block diagonal, so its inversion is considerably faster than CG’s mass matrix inversion. However, the DG formulation has an additional term (integral of numerical fluxes on internal faces) whose assembly at each iteration seems to be dominating DG’s running time, making it less time efficient than CG. My question: is there a more efficient way of assembling that flux vector that I may not be aware of? You’ll find a MWE below, where you can switch between CG and DG by changing the isDG variable.
Kind regards,
import time
nx=1000
ny=nx
lx,ly=3,3
dx=lx/nx
mesh = dolfinx.mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([lx, ly])],
[nx, ny], dolfinx.mesh.CellType.triangle)
T=0.0003
t = 0
dt = 0.02*(dx)
nt=int(T/dt)
isDG=False #Switch between continuous and discontinuous Galerkin
order=1
q = ufl.VectorElement("CG", mesh.ufl_cell(), order, 3)
if isDG:
q = ufl.VectorElement("DG", mesh.ufl_cell(), order, 3)
V_q = dolfinx.fem.FunctionSpace(mesh, q)
tst_q=ufl.TestFunction(V_q)
sol_q=ufl.TrialFunction(V_q)
sol_q0=dolfinx.fem.Function(V_q)
sol_qtmp=dolfinx.fem.Function(V_q)
source=dolfinx.fem.Function(V_q)
Ax_mat=np.zeros((3,3))
Ax_mat[0][2]=1
Ax_mat[2][0]=1
Ay_mat=np.zeros((3,3))
Ay_mat[1][2]=1
Ay_mat[2][1]=1
V_M = dolfinx.fem.TensorFunctionSpace(mesh, ("DG", 0),(3,3))
Ax=dolfinx.fem.Function(V_M)
Ay=dolfinx.fem.Function(V_M)
nbr_cells=len(mesh.topology.original_cell_index)
Ax.x.array[:]= np.tile(Ax_mat.flatten(),nbr_cells)
Ay.x.array[:]= np.tile(Ay_mat.flatten(),nbr_cells)
Mute_str_mat=[\
1,0,0, \
0,1,0, \
0,0,0]
Mute_str=dolfinx.fem.Function(V_M)
Mute_str.x.array[:]=np.tile(Mute_str_mat,nbr_cells)
Fx=Ax*sol_q0
Fy=Ay*sol_q0
n=ufl.FacetNormal(mesh)
Fn_f=n[0]('+')*ufl.avg(Fx)+n[1]('+')*ufl.avg(Fy)-0.5*ufl.jump(sol_q0) # Lax-Fridrichs Flux
Fn_b=n[0]*(Ax*(Mute_str*sol_q0))+n[1]*(Ay*(Mute_str*sol_q0)) # stress free boundary condition
a0= ufl.dot(sol_q,tst_q)*ufl.dx
l0= ufl.dot(source,tst_q)*ufl.dx \
-( ufl.dot(Fx,tst_q.dx(0))*ufl.dx + ufl.dot(Fy,tst_q.dx(1))*ufl.dx ) \
+ ufl.dot(Fn_b, tst_q) * ufl.ds
if isDG:
l0 = ufl.dot(source, tst_q) * ufl.dx \
- (ufl.dot(Fx, tst_q.dx(0)) * ufl.dx + ufl.dot(Fy, tst_q.dx(1)) * ufl.dx) \
+ ufl.dot(Fn_b, tst_q) * ufl.ds + ufl.dot(Fn_f, ufl.jump(tst_q)) * ufl.dS
L0= ufl.dot(sol_q0,tst_q)*ufl.dx + dt*l0
form_a0=dolfinx.fem.form(a0)
form_L0=dolfinx.fem.form(L0)
A0=dolfinx.fem.petsc.assemble_matrix(form_a0)
b0=dolfinx.fem.petsc.create_vector(form_L0)
A0.assemble()
solver_q0 = PETSc.KSP().create(mesh.comm)
solver_q0.setOperators(A0)
solver_q0.setType(PETSc.KSP.Type.PREONLY)
solver_q0.getPC().setType(PETSc.PC.Type.LU)
for i in range(nt):
start_b = time.time()
with b0.localForm() as loc_b0:
loc_b0.set(0)
dolfinx.fem.petsc.assemble_vector(b0, form_L0)
print("assemble b: Time elapsed ",time.time() - start_b," seconds")
# Solve linear problem
start = time.time()
solver_q0.solve(b0, sol_qtmp.vector)
print("solve: Time elapsed ",time.time() - start," seconds")
sol_qtmp.x.scatter_forward()
sol_q0.x.array[:] = sol_qtmp.x.array
