Elasticity problem with radially symmetric traction function on a circle on a face
I would like to load a rectangle with a traction boundary condition on a face normal to the x axis. The traction is applied on a circle in that face, and the traction follows a radially symmetric function, that is pre-computed for 10 points and then accessed using np.interp().
My current self-contained code is attached below. When I run the code I get the following warning:
/usr/lib/python3/dist-packages/ufl/core/terminal.py:60: UserWarning: Couldn't map 'f' to a float, returning ufl object without evaluation.
And the code freezes. Am I declaring the correct space in the function get_traction_yz()? If I’m applying the traction to a face, should the space be 2D?
If tried the following instead:
Trac_vals = fem.functionspace(domain, (“Lagrange”, 1, (domain.geometry.dim-1,)))
But get the following error:
File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/function.py:484 in interpolate
self._cpp_object.interpolate(np.asarray(u0(x), dtype=self.dtype), cells0) # type: ignore
RuntimeError: Interpolation data has the wrong shape/size.
Another option is not to use np.interp(), like this:
def traction_fun(x, g_n):
    r = ufl.sqrt((x[1]-g_n[1])**2 + (x[2]-g_n[2])**2)
    return ufl.conditional(ufl.gt(r, 2.0e-3), 2e4*(1.0 - (r-2.0e-3)**2/(4.0e-3-2.0e-3)**2), 2e4)
def get_traction_yz(domain, g_n, pre_rs, pre_vals):
    Trac_vals = fem.functionspace(domain, ("Lagrange", 1, (domain.geometry.dim-1,)))
    trac_vals = fem.Function(Trac_vals)
    trac_vals.interpolate(lambda x: traction_fun(x, g_n))
    return trac_vals
But I get this error:
File /usr/lib/python3/dist-packages/ufl/constantvalue.py:511 in as_ufl
    raise ValueError(
ValueError: Invalid type conversion: [5.0e-05 5.0e-05 3.4e-05 ... 5.0e-05 3.4e-05 5.0e-05] can not be converted to any UFL type.
I would like to be able to use a function with ufl expressions and if possible something like what is coded now, using np.interp() for a pointwise defined function
Thank you,
Alex
import time
from dolfinx import mesh, fem, io, default_scalar_type
import dolfinx.fem.petsc
r_loading = 4.0e-3
def in_sphere(x, point, r_range):
    return ((x[0]-point[0])**2 + (x[1]-point[1])**2 + (x[2]-point[2])**2) < r_range**2
def mark_boundaries(domain, facet_node,grasp_node,grasp_node_normal):
    dim = domain.topology.dim
    fdim = dim - 1
    domain.topology.create_connectivity(fdim, dim)
    def left_facets(xq):
        return in_sphere(xq, facet_node, r_loading)
    def right_facets(xq):
        return in_sphere(xq, grasp_node, r_loading)
    facets_left  = mesh.locate_entities(domain, fdim, left_facets)
    facets_right = mesh.locate_entities(domain, fdim, right_facets)
    facet_indices = np.concatenate([facets_left, facets_right])
    facet_markers = np.concatenate([np.full_like(facets_left,  1, dtype=np.int32),
                                    np.full_like(facets_right, 2, dtype=np.int32)])
    # Sort by facet index
    sort_perm = np.argsort(facet_indices)
    facet_indices = facet_indices[sort_perm]
    facet_markers = facet_markers[sort_perm]
    mt = mesh.meshtags(domain, fdim, facet_indices, facet_markers)
    return mt
def elasticity_parameters(E=1.0e6, nu=0.20):
    """Lamé parameters from E, nu."""
    lambda_ = E * nu  / ((1.0 + nu) * (1.0 - 2.0 * nu))
    mu      = E * 0.5 /  (1.0 + nu)
    return lambda_, mu
    Trac_vals = fem.functionspace(domain, ("DG", 0))
    trac_vals.interpolate(lambda x: np.interp(np.sqrt((x[1]-g_n[1])**2 + (x[2]-g_n[2])**2), pre_rs,pre_vals))
    return trac_vals
    return ufl.sym(ufl.grad(u))
def sigma(u, lambda_, mu):
    return lambda_ * ufl.nabla_div(u) * ufl.Identity(len(u)) + 2.0 * mu * epsilon(u)
def build_primal_problem(domain, facet_tags, lambda_, mu, grasp_node, node_normal, lock_num, pre_rs, pre_vals, body_force=(0.0, 0.0, 0.0)):
    fdim = dim - 1
    ds = ufl.Measure("ds", domain=domain, subdomain_data=facet_tags)
    V = fem.functionspace(domain, ("Lagrange", 1, (domain.geometry.dim,)))
    u = ufl.TrialFunction(V)
    f_vec = fem.Constant(domain, default_scalar_type(body_force))
    if lock_num == 1:
        p_traction = get_traction_yz(domain, grasp_node, pre_rs, pre_vals)
        # Traction direction: push along +x (change sign if needed)
        T = fem.Constant(domain, -default_scalar_type((node_normal[0]*p_traction, node_normal[1], node_normal[2])))
    a = ufl.inner(sigma(u, lambda_, mu), epsilon(v)) * ufl.dx
    L = ufl.dot(f_vec, v) * ufl.dx + ufl.dot(T, v) * ds(2)
    # Dirichlet BC on left jaw (tag 1)
    left_facets = facet_tags.find(1)
    left_dofs = fem.locate_dofs_topological(V, fdim, left_facets)
    u_D = np.array((0.0, 0.0, 0.0), dtype=default_scalar_type)
    bc_left = fem.dirichletbc(u_D, left_dofs, V)
    # Dirichlet BC to stop deflection normal to x (lock_num == 1) or y (lock_num == 2) axis
    if lock_num == 1:
        right_facets = facet_tags.find(2)
        right_dofs1   = fem.locate_dofs_topological(V.sub(1), fdim, right_facets)
        bc_1 = fem.dirichletbc(0.0, right_dofs1, V.sub(1))
        right_dofs2   = fem.locate_dofs_topological(V.sub(2), fdim, right_facets)
        bc_2 = fem.dirichletbc(0.0, right_dofs2, V.sub(2))
        return V, a, L, [bc_left, bc_1, bc_2]
    if lock_num == 2:
        right_dofs0   = fem.locate_dofs_topological(V.sub(0), fdim, right_facets)
        bc_1 = fem.dirichletbc(0.0, right_dofs0, V.sub(0))
    return V, a, L, [bc_left]
def principal_stress(domain, uh, lambda_, mu):
    #Compute principal stresses via invariants (analytical eigenvalue solution)
    sigma_uh = sigma(uh, lambda_, mu)
    q = ufl.tr(sigma_uh) / 3                            # mean stress (I1/3)
    B = sigma_uh - q * ufl.Identity(3)                  # deviatoric stress tensor
    j = ufl.tr(B * B) / 2                               # J2 = 1/2 tr(B^2)
    b = ufl.tr(B * B * B) / 3                           # J3 = 1/3 tr(B^3)
    p = 2 / ufl.sqrt(3) * ufl.sqrt(j + 1e-14)           # p = 2/sqrt(3)*sqrt(J2) (small eps**2 added)
    r = 4 * b / (p**3)                                  # r = 4 J3 / p^3
    r = ufl.max_value(ufl.min_value(r,+1-1e-7),-1+1e-7) # clamp r to [-1+eps, 1-eps] to avoid acos domain error
    phi = ufl.acos(r) / 3
    lambda2 = q + p * ufl.cos(phi)                      # largest principal stress (max)
    V_dg = fem.functionspace(domain, ("DG", 0))
    pmax_expr = fem.Expression(lambda2, V_dg.element.interpolation_points)
    pmax = fem.Function(V_dg, name="PrincipalStress")
    pmax.interpolate(pmax_expr)
    return pmax, V_dg
def array_dist_squared(x, p):
    return (x[:,0]-p[0])**2 + (x[:,1]-p[1])**2 + (x[:,2]-p[2])**2
def fea_solve(domain, facet_node, grasp_node, grasp_node_normal, lock_num, pre_rs, pre_vals):
    lambda_, mu = elasticity_parameters()
    facet_tags  = mark_boundaries(domain, facet_node,grasp_node,grasp_node_normal)
    Vp, a_p, L_p, bcs_p = build_primal_problem(domain, facet_tags, lambda_, mu, grasp_node, grasp_node_normal, lock_num, pre_rs, pre_vals)
    problem = dolfinx.fem.petsc.LinearProblem(a_p, L_p, bcs=bcs_p,
                                              petsc_options_prefix="linear_problem",
                                              petsc_options={"ksp_type": "preonly", "pc_type": "lu", "pc_factor_mat_solver_type": "mumps"})
    uh = problem.solve()
    # Principal stress field
    pmax, V_dg = principal_stress(domain, uh, lambda_, mu)
    # MPS maximum value not considering low E area
    dof_coords = V_dg.tabulate_dof_coordinates()
    indices    = np.where(np.logical_and(array_dist_squared(dof_coords, facet_node) > 5.0e-3**2, \
                                         array_dist_squared(dof_coords, grasp_node) > 5.0e-3**2))
    max_pmax   = np.sort(pmax.x.array[indices])[-1]
    # Get displacement at node where load is applied
    dof_coords = Vp.tabulate_dof_coordinates()
    distances  = np.linalg.norm(dof_coords - grasp_node, axis=1)
    dof_index  = np.argmin(distances)
    u_node     = np.sqrt(uh.x.array[3*dof_index]**2 + uh.x.array[3*dof_index+1]**2 + uh.x.array[3*dof_index+2]**2)
    return domain, uh, pmax, max_pmax, u_node
# Part FEA
length = 20.0e-3
width  = 10.0e-3
grasp_facet_node   = np.array([0.0,    width/2, width/2])
grasp_node2        = np.array([length, width/2, width/2])
grasp_node_normals = np.array([1.0,    0.0,     0.0    ])
cell_size = 2.0e-3
num_loops = 1
cell_sizes = np.empty((num_loops,1))
u_disps    = np.empty((num_loops,1))
stresses   = np.empty((num_loops,1))
lock_num = 1
def gen_pressure_profile(ri, ro, pmag, num_ps):
    pre_r   = np.linspace(0.0, ro, num=50, endpoint=True)
    pre_val = np.zeros(pre_r.size)
    for nn in range(pre_r.size):
        if pre_r[nn] < ri:
            pre_val[nn] = pmag
            pre_val[nn] = pmag*(1.0 - (pre_r[nn]-ri)**2/(ro-ri)**2)
    return pre_r, pre_val
r_i   = 2.0e-3
r_o   = r_loading
p_mag = 1.0/(np.pi*r_loading**2)
pre_rs, pre_vals = gen_pressure_profile(r_i, r_o, p_mag, 10)
plt.figure()
plt.plot(pre_rs, pre_vals)
for n in range(num_loops):
    n_l = int(length/cell_size)
    n_w = int(width/cell_size )
    domain = mesh.create_box(MPI.COMM_WORLD, ((0.0, 0.0, 0.0), (length,width,width)), (n_l,n_w,n_w), mesh.CellType.tetrahedron)
    t_start = time.perf_counter()
    domain_f, uh, pmax, max_stress, u_node = fea_solve(domain, grasp_facet_node, grasp_node2, grasp_node_normals, lock_num, pre_rs, pre_vals)
    t_end   = time.perf_counter()
    print(f"FEA elapsed time: {t_end  - t_start:.6f} seconds")
    cell_sizes[n] = cell_size
    u_disps[n]    = u_node
    stresses[n]   = max_stress
    cell_size = cell_size/2.0**0.25
with io.XDMFFile(domain_f.comm, "max_p_stress_part.xdmf", "w") as xdmf:
    xdmf.write_mesh(domain_f)
    uh.name   = "u"
    xdmf.write_function(uh)
    pmax.name = "PrincipalStress"
    xdmf.write_function(pmax)
print('\n')
print(cell_sizes)
print('\n')
print(u_disps)
print('\n')
print(stresses)
This should use a dolfinx.fem.Expression, not mix numpy and UFL expressions.
This is explained in: Function and expression evaluation — FEniCS Workshop
and would be along the lines of
    g_n_ufl = ufl.as_ufl(g_n)
    tr_expr = dolfinx.fem.Expression(traction_fun(x, ufl.as_ufl(g_n)), Trac_vals.element.interpolation_points)
    trac_vals.interpolate(tr_expr)
