Hi all,
Now that I understand my previous issue Lid-driven cavity simulation issue (thanks to Jack Hale) I’m trying to look at my problem with an enriched element.
One of my options is to use the (P2 + Bubble3) * P1 element :
P2 = FiniteElement("CG", mesh.ufl_cell(), 2)
B = FiniteElement("B", mesh.ufl_cell(), 3)
P1 = FiniteElement("CG", mesh.ufl_cell(), 1)
P2B = P2 + B
element = MixedElement([VectorElement(P2B, dim = 2), P1])
W = FunctionSpace(mesh, element)
When I use this element it raises a new warning :
*** FFC warning: evaluate_dof(s) for enriched element not implemented.
Is there any way to bypass this problem ?
Any help will be appreciated !
Here is the full code using the latest Fenics version
n = 50
Re= 100
nu = Constant(1.0 / Re)
T = 5
steps = 500
dt = T / steps
t = 0.0
ufile = File("velocity.pvd")
pfile = File("pressure.pvd")
mesh = UnitSquareMesh(n, n)
def MarkDomain(mesh):
boundary_parts = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
boundary_parts.set_all(0)
class Inflow(SubDomain):
return near(x[1], 1.0) and on_boundary
inflow = Inflow()
inflow.mark(boundary_parts, 1)
class Walls(SubDomain):
return on_boundary and (near(x[0], 0.0) or near(x[1], 0.0) or near(x[0], 1.0))
walls = Walls()
walls.mark(boundary_parts, 2)
return boundary_parts
P2B = P2 + B
v, q = TestFunctions(W)
w = Function(W)
u, p = split(w)
w_prec = Function(W)
u_prec, v_prec = split(w_prec)
boundary_parts = MarkDomain(mesh)
lid = DirichletBC(W.sub(0), Constant((1.0,0.0)), boundary_parts, 1)
noslip = DirichletBC(W.sub(0), Constant((0.0,0.0)), boundary_parts, 2)
bc = [noslip, lid]
class InitialConditions(UserExpression):
def eval(self, values, x):
values[0] = 0.0
values[1] = 0.0
values[2] = 0.0
def value_shape(self):
return (3,)
w.interpolate(InitialConditions())
F = (inner(u - u_prec, v) / dt + inner(grad(u) * u_prec, v) + nu * inner(grad(u), grad(v)) - inner(p, div(v)) - inner(q, div(u))) * dx
for step in range(1, steps):
print("Step = ", step)
assign(w_prec, w)
solve(F == 0, w, bc)
u, p = w.split(deepcopy = True)
ufile << u
pfile << p
