Hi All,
I am trying to port this fenics notebook to Dolfinx.
I somehow navigated through the syntax but I am unable to “translate” a legacy some_function.vector().set_local()) command. Searching I found the setValueLocal command (e.g. here, but it does require an index.
Looking at the original fenics code, the line theta.vector().set_local(np.maximum(np.minimum(1, thetav), thetamin)) populates a Function with certain values present in another Function, dof by dof (both are defined on the same VectorSpace.
How could I achieve the same on Dolfinx?
I attach the code I put together so far, it does run indefinitely as the update_theta function is not doing what it should, the way I am trying to “translate” the set_local command might well be total nonsense.
########## DOLFINX ##############
%matplotlib notebook
from dolfinx import *
from dolfinx.fem import FunctionSpace, Function
from dolfinx.fem import VectorFunctionSpace
from dolfinx import fem, io
from dolfinx import mesh
from dolfinx.mesh import CellType, create_rectangle
# Algorithmic parameters
niternp = 20 # number of non-penalized iterations
niter = 80 # total number of iterations
pmax = 4 # maximum SIMP exponent
exponent_update_frequency = 4 # minimum number of steps between exponent update
tol_mass = 1e-4 # tolerance on mass when finding Lagrange multiplier
thetamin = 0.001 # minimum density modeling void
L = 5
domain = create_rectangle(MPI.COMM_WORLD, np.array([[0,0],[3*L, L]]), [30,30], cell_type=CellType.triangle)
tdim = domain.topology.dim
fdim = tdim - 1
# Problem parameters
thetamoy = 0.4 # target average material density
E = fem.Constant(domain, ScalarType(1))
nu = fem.Constant(domain, ScalarType(0.3))
lamda = E*nu/(1+nu)/(1-2*nu)
mu = E/(2*(1+nu))
f = fem.Constant(domain, ScalarType([0,-1])) # vertical downwards force
body = fem.Constant(domain, ScalarType((0, 0.1)))
# Function space for density field
V0 = fem.FunctionSpace(domain, ("DG", 0))
# Function space for displacement
V2 = fem.VectorFunctionSpace(domain, ("CG", 2))
def clamped_boundary(x):
return np.isclose(x[0], 0)
u_D = np.array([0,0], dtype=ScalarType)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V2, fdim, boundary_facets), V2)
def left(x):
def right(x):
return np.isclose(x[0], 3*L)
fdim = domain.topology.dim -1
# Concatenate and sort the arrays based on facet indices. Left facets marked with 1, right facets with two
marked_values = np.hstack([np.full_like(left_facets, 1), np.full_like(right_facets, 2)])
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tag, metadata=metadata)
p = fem.Constant(domain, ScalarType(1)) # SIMP penalty exponent
exponent_counter = 0 # exponent update counter
lagrange = fem.Constant(domain, ScalarType(1))# Lagrange multiplier for volume constraint
thetaold = Function(V0, name="Density")
thetaold.x.set(thetamoy)
coeff = thetaold**p
theta = Function(V0)
volume = fem.assemble_scalar(fem.form(thetaold*ufl.dx))
avg_density_0 = fem.assemble_scalar(fem.form(thetaold*ufl.dx))/volume
avg_density = 0.
def eps(v):
return ufl.sym(ufl.grad(v))
def sigma(v):
return coeff*(lamda*ufl.nabla_div(v)*ufl.Identity(2)+2*mu*eps(v))
# return lambda_ * ufl.nabla_div(u) * ufl.Identity(len(u)) + 2*mu*epsilon(u)
def energy_density(u, v):
return ufl.inner(sigma(u), eps(v))
# Inhomogeneous elastic variational problem
u_ = ufl.TestFunction(V2)
du = ufl.TrialFunction(V2)
a = ufl.inner(sigma(u_), eps(du)) * ufl.dx
L = ufl.dot(f, u_)*ds(2)
def local_project(u,V, mesh):
# ut = ufl.TrialFunction(V)
# v = ufl.TestFunction(V)
uh = Function(V)
# solve(inner(ut,v)*dx==inner(u,v)*dx,uh)
dx = ufl.Measure("dx", domain=mesh)
#problem_int = fem.petsc.LinearProblem(ufl.inner(ut,v)*dx,ufl.inner(u,v)*dx,
# petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
u_0 = u
uh = problem_int.solve()
#uh = fem.solve(ufl.inner(ut,v)*dx, ufl.inner(u,v)*dx,uh)
return uh
def update_theta():
theta_new = Function(V0)
theta.x.array[:] = local_project((p*coeff*energy_density(u, u)/lagrange)**(1/(p+1)), V0, domain).x.array
thetav = theta.vector.getArray()
### The next line is the issue ####
theta.x.array[:] = (np.maximum(np.minimum(1, thetav), thetamin))
avg_density = fem.assemble_scalar(fem.form(theta*ufl.dx))/volume
return avg_density
def update_lagrange_multiplier(avg_density):
print("made it to Lagrange update proc")
avg_density1 = avg_density
# Initial bracketing of Lagrange multiplier
if (avg_density1 < avg_density_0):
lagmin = float(lagrange)
while (avg_density < avg_density_0):
# lagrange.assign(fem.Constant(domain, ScalarType(lagrange/2)))
#lagrange.value(fem.Constant(domain, ScalarType(lagrange/2)))
print(f"First while loop, lagrange is {lagrange.value}")
lagrange.value= (lagrange.value/2)
avg_density = update_theta()
lagmax = float(lagrange)
elif (avg_density1 > avg_density_0):
while (avg_density > avg_density_0):
# lagrange.assign(fem.Constant(domain, ScalarType(lagrange*2)))
#lagrange.value(fem.Constant(domain, ScalarType(lagrange*2)))
print(f"Second while loop, lagrange is {lagrange.value}")
lagrange.value = lagrange.value*2
# Dichotomy on Lagrange multiplier
inddico=0
print("made it to Lagrange dichotomy")
while ((abs(1.-avg_density/avg_density_0)) > tol_mass):
# lagrange.assign(Constant((lagmax+lagmin)/2))
#lagrange.value(fem.Constant((lagmax+lagmin)/2))
lagrange.value= (lagmax+lagmin)/2
inddico += 1;
if (avg_density < avg_density_0):
print(" Dichotomy iterations:", inddico)
def update_exponent(exponent_counter):
exponent_counter += 1
if (i < niternp):
elif (i >= niternp):
if i == niternp:
print("\n Starting penalized iterations\n")
if ((abs(compliance-old_compliance) < 0.01*compliance_history[0]) and
(exponent_counter > exponent_update_frequency) ):
# average gray level
gray_level = fem.assemble_scalar((theta-thetamin)*(1.-theta)*dx)*4/volume
# p.assign(Constant(min(float(p)*(1+0.3**(1.+gray_level/2)), pmax)))
p.value = (min(float(p.value)*(1+0.3**(1.+gray_level/2)), pmax))
p.assign(fem.Constant(domain, ScalarType(1)))
print(" Updated SIMP exponent p = ", float(p))
return exponent_counter
u = Function(V2, name="Displacement")
ut = ufl.TrialFunction(V0)
u_0 = ufl.TrialFunction(V0)
v = ufl.TestFunction(V0)
problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
problem_int = fem.petsc.LinearProblem(ufl.inner(ut,v)*dx,ufl.inner(u_0,v)*dx,
old_compliance = 1e30
compliance_history = []
for i in range(niter):
# problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
print("Made it past uh")
compliance = fem.assemble_scalar(fem.form(ufl.action(L, uh)) )
compliance_history.append(compliance)
print("Iteration {}: compliance =".format(i), compliance)
print("Made it past update theta")
print("Made it past Lagrange update")
exponent_counter = update_exponent(exponent_counter)
# Update theta field and compliance
thetaold.x.array[:]= theta.x.array
old_compliance = compliance
