Hello everyone
I’m new with FEniCS and I’m trying to get the latest release (FEniCSx 0.5) running in conda. So far, I have installed it in conda using the commands
conda create -n mecanica
conda activate mecanica
conda install -c conda-forge fenics-dolfinx mpich pyvista
After that, I have checked that the corresponding modules appear in my environment, but when I try to import dolfinx using
I get the following error:
TypeError: function() argument 'code' must be code, not str
Any idea of how may I solve it?
Thank you!
In case it helps, the complete error is:
TypeError Traceback (most recent call last)
/tmp/ipykernel_45532/893141858.py in <module>
----> 1 import dolfinx
~/anaconda3/envs/mecanica/lib/python3.10/site-packages/dolfinx/__init__.py in <module>
29 from dolfinx import common
30 from dolfinx import cpp as _cpp
---> 31 from dolfinx import fem, geometry, graph, io, jit, la, log, mesh, nls, plot
32 # Initialise logging
33 from dolfinx.common import (TimingType, git_commit_hash, has_debug, has_kahip,
~/anaconda3/envs/mecanica/lib/python3.10/site-packages/dolfinx/fem/__init__.py in <module>
9 from dolfinx.cpp.fem import IntegralType
10 from dolfinx.cpp.fem import create_sparsity_pattern as _create_sparsity_pattern
---> 11 from dolfinx.fem import petsc
12 from dolfinx.fem.assemble import (apply_lifting, assemble_matrix,
13 assemble_scalar, assemble_vector, set_bc)
~/anaconda3/envs/mecanica/lib/python3.10/site-packages/dolfinx/fem/petsc.py in <module>
22 from dolfinx.cpp.fem import pack_coefficients as _pack_coefficients
23 from dolfinx.cpp.fem import pack_constants as _pack_constants
---> 24 from dolfinx.fem import assemble
25 from dolfinx.fem.bcs import DirichletBCMetaClass
26 from dolfinx.fem.bcs import bcs_by_block as _bcs_by_block
~/anaconda3/envs/mecanica/lib/python3.10/site-packages/dolfinx/fem/assemble.py in <module>
20 from dolfinx.cpp.fem import pack_constants as _pack_constants
21 from dolfinx.fem.bcs import DirichletBCMetaClass
---> 22 from dolfinx.fem.forms import FormMetaClass, form_types
23
24
~/anaconda3/envs/mecanica/lib/python3.10/site-packages/dolfinx/fem/forms.py in <module>
11 import typing
12
---> 13 from dolfinx.fem.function import FunctionSpace
14
15 if typing.TYPE_CHECKING:
~/anaconda3/envs/mecanica/lib/python3.10/site-packages/dolfinx/fem/function.py in <module>
28
29
---> 30 class Constant(ufl.Constant):
31 def __init__(self, domain, c: typing.Union[np.ndarray, typing.Sequence, float]):
32 """A constant with respect to a domain.
