I am getting the following error when calling HDF5File() function when running in parallel:
*** Error: Unable to open HDF5 file.
*** Reason: HDF5 has not been compiled with support for MPI.
*** Where: This error was encountered inside HDF5File.cpp.
*** Process: 1
*** DOLFIN version: 2019.1.0
*** Git changeset: 74d7efe1e84d65e9433fd96c50f1d278fa3e3f3f
FEniCS is compiled from source on a cluster. The FEniCS version is 2019.1. The HDF5 library version is 1.10.1 and is provided by the cluster. The cmake output message when compiling DOLFIN indicates that the HDF5 library is detected but it says nothing about MPI support:
-- The following OPTIONAL packages have been found:
* MPI, Message Passing Interface (MPI)
Enables DOLFIN to run in parallel with MPI
* PETSc (required version >= 3.7), Portable, Extensible Toolkit for Scientific Computation, <https://www.mcs.anl.gov/petsc/>
Enables the PETSc linear algebra backend
* SLEPc (required version >= 3.7), Scalable Library for Eigenvalue Problem Computations, <http://slepc.upv.es/>
* UMFPACK, Sparse LU factorization library, <http://faculty.cse.tamu.edu/davis/suitesparse.html>
* BLAS, Basic Linear Algebra Subprograms, <http://netlib.org/blas/>
* Threads
* CHOLMOD, Sparse Cholesky factorization library for sparse matrices, <http://faculty.cse.tamu.edu/davis/suitesparse.html>
* HDF5, Hierarchical Data Format 5 (HDF5), <https://www.hdfgroup.org/HDF5>
* ZLIB, Compression library, <http://www.zlib.net>
I am wondering if anyone has any insight on how to go about fixing this issue.
Thank you very much for your time.
