Ok, I have found a solution: I assume that the simple expression ( Expression(‘10*exp_2’, exp_2=exp_2, degree=2) ) calls the function Exp2.eval(values, x). I defined the function eval(values, x, cell), thus the former could not be found, returning said error.
Is this a bug in fenics?
In summary this code that works for me:
mesh = UnitSquareMesh(10,10)
V = FunctionSpace(mesh, 'P', 1)
exp_1 = Expression( '10', degree=2)
exp_from_exp_1 = Expression('10*exp_1', exp_1=exp_1, degree=2) # this works
cpp_code = '''#include <pybind11/pybind11.h>
#include <pybind11/eigen.h>
namespace py = pybind11;
#include <dolfin/function/Expression.h> // for expressions
class Exp2 : public dolfin::Expression
public:
Exp2() : dolfin::Expression(){}
void eval(Eigen::Ref<Eigen::VectorXd> values, Eigen::Ref<const Eigen::VectorXd> x) const override
values[0] = 10;
PYBIND11_MODULE(SIGNATURE, m)
py::class_<Exp2, std::shared_ptr<Exp2>, dolfin::Expression>(m, "Exp2")
.def(py::init<>());
exp_2 = CompiledExpression( compile_cpp_code(cpp_code).Exp2(), degree=2)
exp_from_exp_2 = Expression('10*exp_2', exp_2=exp_2, degree=2)
test1 = interpolate(exp_1, V) # this works
test2 = interpolate(exp_2, V) # this works
test3 = interpolate(exp_from_exp_1, V) # this works
test4 = interpolate(exp_from_exp_2, V) # this does not work
Only difference is that I removed the requirement for cell in the eval function.
