Problem with boundary conditions: Missing eval() function (must be overloaded)
I have a code that used to work with previous (2017) versions of FEniCS. Now, after a little adjustment because of code obsolescence, it returns the error
Generating mesh with CGAL 3D mesh generator
WARNING: user expression has not supplied value_shape method or an element. Assuming scalar element.
Solving linear variational problem.
File “MWE.py”, line 70, in
solve(a == L, u, bcs = bc0)
File “/usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py”, line 220, in solve
File “/usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py”, line 247, in _solve_varproblem
solver.solve()
RuntimeError:
*** Error: Unable to evaluate expression.
*** Reason: Missing eval() function (must be overloaded).
*** Where: This error was encountered inside Expression.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 74d7efe1e84d65e9433fd96c50f1d278fa3e3f3f
The code is
import mshr
cylinder = mshr.Cylinder(Point(0, 0, 0), Point(0, 0, -9), 8.0, 8.0)
domain = cylinder
mesh = mshr.generate_mesh(domain, 20)
# Define boundary conditions
tol = 1E-14
class Top(SubDomain):
    def inside(self, x , on_boundary):
       return on_boundary and near(x[2], 0.0, tol)
# Define subdomains.
# top
class Omega_0(SubDomain):
        return x[2] >= -6 - tol
# Other region.
class Omega_1(SubDomain):
        return x[2] <= -6 + tol
# Define the mesh
region = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
# Use the subdomains to mark the cells belonging to each subdomain
subdomain_0 = Omega_0()
subdomain_1 = Omega_1()
subdomain_0.mark(region, 0)
subdomain_1.mark(region, 1)
# k values of the layers
k_0 = 75
k_1 = 7
# Define the values of kappa in each subdomain
class K(UserExpression):
    def __init__(self, region, k_0, k_1, **kwargs):
        super().__init__(**kwargs)
        self.region = region
        self.k_0 = k_0
        self.k_1 = k_1
    if self.region[cell.index] == 0:
        values[0] = self.k_0
        values[0] = self.k_1
kappa = K(region, k_0, k_1)
# Apply boundary conditions
u_D0 = Constant(10.0)
bc0 = DirichletBC(V, u_D0, Top())
# Define initial value
u_0 = Constant(5.0)
u_n = interpolate(u_0, V)
F = u*v*dx + kappa*dot(grad(u), grad(v))*dx - u_n*v*dx
a, L = lhs(F), rhs(F)
I suspect the error is due to the way the boundary conditions are implemented, which used to work but not anymore. I have no idea how to fix the problem.
Note that the eval_cell definition is not property indented, so it is just interpreted as a free function, and not a method of K. If that is indented, the error goes away. The warning about value_shape can be eliminated by adding the method
    def value_shape(self):
        return ()
