Error while using Crouzeix–Raviart elements for unsteady NSE
I am trying to use Crouzeix–Raviart (CR) elements to solve the DFG2D-3 benchmark from the tutorial. I made the mesh from triangular elements as CR does not work with quadrilaterals.
V = VectorFunctionSpace(mesh, ("Crouzeix-Raviart", 1))
Q = FunctionSpace(mesh, ("Discontinuous Lagrange", 0))
fdim = mesh.topology.dim - 1
# Define boundary conditions
class InletVelocity():
    def __init__(self, t):
        self.t = t
    def __call__(self, x):
        values = np.zeros((gdim, x.shape[1]),dtype=PETSc.ScalarType)
        values[0] = 4 * 1.5 * np.sin(self.t * np.pi/8) * x[1] * (0.41 - x[1])/(0.41**2)
        return values
# Inlet
u_inlet = Function(V)
inlet_velocity = InletVelocity(t)
u_inlet.interpolate(inlet_velocity)
bcu_inflow = dirichletbc(u_inlet, locate_dofs_topological(V, fdim, ft.find(inlet_marker)))
# Walls
#u_nonslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
u_nonslip = Function(V)
u_nonslip.x.set(0.)
bcu_walls = dirichletbc(u_nonslip, locate_dofs_topological(V, fdim, ft.find(wall_marker)))
# Obstacle
bcu_obstacle = dirichletbc(u_nonslip, locate_dofs_topological(V, fdim, ft.find(obstacle_marker)))
bcu = [bcu_inflow, bcu_obstacle, bcu_walls]
# Outlet
bcp_outlet = dirichletbc(PETSc.ScalarType(0), locate_dofs_topological(Q, fdim, ft.find(outlet_marker)), Q)
bcp = [bcp_outlet]
u_ = Function(V)
u_.name = "u"
u_s = Function(V)
u_n = Function(V)
u_n1 = Function(V)
p = TrialFunction(Q)
q = TestFunction(Q)
p_ = Function(Q)
p_.name = "p"
phi = Function(Q)
f = Constant(mesh, PETSc.ScalarType((0,0)))
F1 = rho / k * dot(u - u_n, v) * dx
F1 += inner(dot(1.5 * u_n - 0.5 * u_n1, 0.5 * nabla_grad(u + u_n)), v) * dx
F1 += 0.5 * mu * inner(grad(u + u_n), grad(v))*dx - dot(p_, div(v))*dx
F1 += dot(f, v) * dx
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1 = create_matrix(a1)
b1 = create_vector(L1)
a2 = form(dot(grad(p), grad(q))*dx)
L2 = form(-1/k * dot(div(u_s), q) * dx)
A2.assemble()
b2 = create_vector(L2)
a3 = form(dot(u, v)*dx)
L3 = form(dot(u_s, v)*dx - k * dot(nabla_grad(phi), v)*dx)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
This produces an error:
This integral is missing an integration domain.
ERROR:UFL:This integral is missing an integration domain.
  File "/Users/varunkumar/Downloads/FEniCSx v0.6/CRtest.py", line 178, in <module>
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ufl/measure.py", line 413, in __rmul__
    error("This integral is missing an integration domain.")
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ufl/log.py", line 135, in error
ufl.log.UFLException: This integral is missing an integration domain.
I am getting a similar error using IPCS as well but in the formulation of L2.
Continuous velocity/Discontinuous pressure (CD) elements give the same error. I am not well-versed in variational forms and don’t know what this error even means. Any suggestions on how to fix this would be greatly appreciated.
As you haven’t added how you import the different functions from dolfinx/ufl, it is hard to give guidance.
I would suggest defining dx as
dx = ufl.Measure("dx", domain=mesh)
