Hello!
I have a code that works well but when I use a loop it does not work and I do not know which is the error because I have done all steps out of the code and it works.
import math
mesh =UnitCubeMesh(4, 4, 4)
# Defining the function spaces
V_c = FunctionSpace(mesh, 'P', 1)
# Velocity field
vel_x= Expression(('vmag*cos(theta)*ux','vmag*sin(theta)*ux','ux'), domain=mesh, degree=1, theta=pi/2, vmag=2, ux=5)
vel_y= Expression(('vmag*cos(theta)*uy','vmag*sin(theta)*uy','uy'), domain=mesh, degree=1, theta=pi/2, vmag=2, uy=2)
for theta in np.linspace(0, pi/2, num=10):
for vmag in np.linspace(0.5, 9, num=18):
u=vmag*(cos(theta)*vel_x+vmag*sin(theta)*vel_y)
#STABILIZATION TERMS
norm=sqrt(dot(u,u))
UFLValueError Traceback (most recent call last)
<ipython-input-15-ac6ef75c3701> in <module>
3 u=vmag*(cos(theta)*vel_x+vmag*sin(theta)*vel_y)
4 #STABILIZATION TERMS
----> 5 norm=sqrt(dot(u,u))
~/anaconda3/envs/nfenics/lib/python3.8/site-packages/ufl/operators.py in dot(a, b)
181 def dot(a, b):
182 "UFL operator: Take the dot product of *a* and *b*. The complex conjugate of the second argument is taken."
--> 183 a = as_ufl(a)
184 b = as_ufl(b)
185 if a.ufl_shape == () and b.ufl_shape == ():
~/anaconda3/envs/nfenics/lib/python3.8/site-packages/ufl/constantvalue.py in as_ufl(expression)
469 return IntValue(expression)
470 else:
--> 471 raise UFLValueError("Invalid type conversion: %s can not be converted"
472 " to any UFL type." % str(expression))
UFLValueError: Invalid type conversion: [Product(FloatValue(0.5), Indexed(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', tetrahedron, 1), dim=3), 22), VectorElement(FiniteElement('Lagrange', tetrahedron, 1), dim=3)), 37), MultiIndex((FixedIndex(0),))))
Product(FloatValue(0.5), Indexed(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', tetrahedron, 1), dim=3), 22), VectorElement(FiniteElement('Lagrange', tetrahedron, 1), dim=3)), 37), MultiIndex((FixedIndex(1),))))
Product(FloatValue(0.5), Indexed(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', tetrahedron, 1), dim=3), 22), VectorElement(FiniteElement('Lagrange', tetrahedron, 1), dim=3)), 37), MultiIndex((FixedIndex(2),))))] can not be converted to any UFL type.
I guess that the error is related to use np at the moment to perform the loop
