I am trying to extend a following code https://github.com/FEniCS/dolfinx/issues/3165 to include mixed space elements.
import basix.ufl
from dolfinx.mesh import create_unit_square
from dolfinx.fem import functionspace, Function
def tensor(x):
mat = np.array([[1], [0], [0], [2], [3], [0], [4], [5], [6]])
return np.broadcast_to(mat, (9, x.shape[1]))
def tensor2(x):
mat = np.array([[1], [2], [3], [4], [5], [6]])
return np.broadcast_to(mat, (6, x.shape[1]))
element = basix.ufl.element("DG", mesh.basix_cell(), 0, shape=(3, 3), symmetry=True)
space = functionspace(mesh, element)
space_mix = functionspace(mesh, basix.ufl.mixed_element([element,element]))
subspace,_ = space_mix.sub(0).collapse()
f = Function(subspace)
# f = Function(space)
# f.interpolate(lambda x: tensor2(x))
f.interpolate(lambda x: tensor(x))
print(f.eval([[0, 0, 0]], [0]))
When using a standard space, function with full tensor (
tensor(x)) works properly (prints[1. 2. 4. 2. 3. 5. 4. 5. 6.]), while the other approach with only symmetrical part (usingtensor2) givesInterpolation data has the wrong shape/size.error. -
When using the mixed space, the first approach (
tensor(x)) gives theInterpolation ...error, while the second (usingtensor2(x)) sometimes ends up with Ubuntu (invalid pointer) or MPI (SEGV) memory errors. Regardless of errorsprintalways executes printing incorrect result:[1.0000e+000 4.0000e+000 9.5750e-321 4.0000e+000 5.0000e+000 1.0563e-320] -
Both approaches (with standard and mixed space) work well when
symmetry=False
Am I doing something wrong?
