Hi all,
I’m struggling to query a function on a hexmesh in c++, generated with:
auto cubemesh = UnitCubeMesh::create(MPI_COMM_WORLD, {16, 16, 16}, CellType::Type::hexahedron); auto mesh = std::make_shared<Mesh>(cubemesh); W = std::make_shared<FunctionSpace>(mesh); u = std::make_shared<Function>(W);
and filled with some solution.
The straightforward approach:
Array<double> u_p (3); Array<double> p (3); p[0] = 0.5; p[1] = 0.5; p[2] = 0.5; u->eval(u_p,p);
spits out the error that this has not been implemented for hex meshes. So I’m hoping that I can use the alternative function that I find in the docs:
void eval(Array<double> &values, const Array<double> &x, const Cell &dolfin_cell, const ufc::cell &ufc_cell) const
This requires the cell object associated to the coordinate P, as well as a UFC::Cell object for the hexahedral element. My attempted implementation is very convoluted, and I still haven’t managed to get it to run. I feel like there should be a very straightforward way to do this. I’d be very grateful if someone could share a code-snippet ![]()
