In the FeniCSx tutorial for linear elasticity, they have calculated the Von Mises stress as follows: (link)
s = sigma(uh) -1./3*ufl.tr(sigma(uh))*ufl.Identity(uh.geometric_dimension())
von_Mises = ufl.sqrt(3./2*ufl.inner(s, s))
V_von_mises = fem.FunctionSpace(domain, ("DG", 0))
stress_expr = fem.Expression(von_Mises, V_von_mises.element.interpolation_points())
stresses = fem.Function(V_von_mises)
stresses.interpolate(stress_expr)
I’m trying to calculate the fluid shear stress by following the same steps above.
That means:
In place of
I have (The calculation you need for the shear stresses):
return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
return 2*mu*epsilon(u) - p*Identity(u.geometric_dimension())
#Stress tensor. Comes from the theory
T = -sigma(u_n, p_n)*n
#Normal stress (A scalar)
Tn = inner(T, n)
#Shear stress (A vector)
Tt = T - Tn*n
And then, for the function space given in the Vonn Meses stress:
I have the:
p_cg1 = FiniteElement('CG', mesh.ufl_cell(), 1)
scalar = FunctionSpace(mesh, p_cg1) #For the normal stress
v_cg2 = VectorElement('CG', mesh.ufl_cell(), 2)
vector = FunctionSpace(mesh, v_cg2) #For the shear stress
normal_stress = Function(scalar)
shear_stress = Function(vector)
Finally, in place of the calculation and the projection in Von Meses stress:
I will have (For the normal stress):
normal_stress_expr = Expression(Tn, scalar.element.interpolation_points())
normal_stress.interpolate(normal_stress_expr)
And I should have a similar thing for the shear stresses too.
However, even for this normal stress calculation, I’m getting the following error:
Looks like, there should be a different way to define the facet normals (Given by n)
I would really appreciate your suggestions.
I’m giving my entire code below if you need to reproduce everything. It is a bit lengthy, but it is just the exact copy (Except for the stress calculation) of the tutorial code in Poiseuille flow
import sys
from dolfinx import plot
# Initialize gmsh:
#from dolfinx import mesh
import pyvista
from dolfinx.io.gmshio import model_to_mesh
from dolfinx import geometry
# from dolfinx import fem,mesh
from prettytable import PrettyTable
import random
from dolfinx.mesh import create_unit_square
from ufl import (FacetNormal, FiniteElement, FacetArea,Identity,TestFunction, TrialFunction, VectorElement,
div, dot, ds, dx, inner, lhs, nabla_grad, rhs, sym)
from dolfinx.fem import Expression,Constant,Function, FunctionSpace, assemble_scalar, dirichletbc, form, locate_dofs_geometrical,locate_dofs_topological
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc
t = 0
T = 10
num_steps = 500
dt = T/num_steps
v_cg2 = VectorElement("CG", mesh.ufl_cell(), 2)
s_cg1 = FiniteElement("CG", mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, v_cg2)
Q = FunctionSpace(mesh, s_cg1)
p = TrialFunction(Q)
q = TestFunction(Q)
def walls(x):
return np.logical_or(np.isclose(x[1],0), np.isclose(x[1],1))
wall_dofs = locate_dofs_geometrical(V, walls)
u_noslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
bc_noslip = dirichletbc(u_noslip, wall_dofs, V)
def inflow(x):
return np.isclose(x[0], 0)
inflow_dofs = locate_dofs_geometrical(Q, inflow)
bc_inflow = dirichletbc(PETSc.ScalarType(8), inflow_dofs, Q)
def outflow(x):
return np.isclose(x[0], 1)
outflow_dofs = locate_dofs_geometrical(Q, outflow)
bc_outflow = dirichletbc(PETSc.ScalarType(0), outflow_dofs, Q)
bcu = [bc_noslip]
bcp = [bc_inflow, bc_outflow]
u_n = Function(V)
u_n.name = "u_n"
U = 0.5 * (u_n + u)
f = Constant(mesh, PETSc.ScalarType((0,0)))
mu = Constant(mesh, PETSc.ScalarType(1))
rho = Constant(mesh, PETSc.ScalarType(1))
# Define strain-rate tensor
def sigma(u, p):
# Define the variational problem for the first step
p_n = Function(Q)
p_n.name = "p_n"
F1 = rho*dot((u - u_n) / k, v)*dx
F1 += rho*dot(dot(u_n, nabla_grad(u_n)), v)*dx
F1 += inner(sigma(U, p_n), epsilon(v))*dx
F1 += dot(p_n*n, v)*ds - dot(mu*nabla_grad(U)*n, v)*ds
F1 -= dot(f, v)*dx
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1 = assemble_matrix(a1, bcs=bcu)
A1.assemble()
b1 = create_vector(L1)
u_ = Function(V)
a2 = form(dot(nabla_grad(p), nabla_grad(q))*dx)
L2 = form(dot(nabla_grad(p_n), nabla_grad(q))*dx - (1/k)*div(u_)*q*dx)
A2.assemble()
b2 = create_vector(L2)
p_ = Function(Q)
a3 = form(dot(u, v)*dx)
L3 = form(dot(u_, v)*dx - k*dot(nabla_grad(p_ - p_n), v)*dx)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
# Solver for step 1
solver1 = PETSc.KSP().create(mesh.comm)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setHYPREType("boomeramg")
# Solver for step 2
solver2 = PETSc.KSP().create(mesh.comm)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.BCGS)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(mesh.comm)
solver3.setOperators(A3)
pc3 = solver3.getPC()
xdmf = XDMFFile(mesh.comm, "poiseuille.xdmf", "w")
xdmf.write_mesh(mesh)
xdmf.write_function(u_n, t)
xdmf.write_function(p_n, t)
for i in range(num_steps):
# Update current time step
# Step 1: Tentative veolcity step
with b1.localForm() as loc_1:
loc_1.set(0)
assemble_vector(b1, L1)
set_bc(b1, bcu)
solver1.solve(b1, u_.vector)
u_.x.scatter_forward()
# Step 2: Pressure corrrection step
with b2.localForm() as loc_2:
loc_2.set(0)
assemble_vector(b2, L2)
set_bc(b2, bcp)
solver2.solve(b2, p_.vector)
p_.x.scatter_forward()
with b3.localForm() as loc_3:
loc_3.set(0)
assemble_vector(b3, L3)
solver3.solve(b3, u_.vector)
u_n.x.array[:] = u_.x.array[:]
p_n.x.array[:] = p_.x.array[:]
# Write solutions to file
# Close xmdf file
xdmf.close()
#Stress calculation:
Tn = inner(T, n)
Tt = T - Tn*n
# shear_stress_expr = Expression(Tt, vector.element.interpolation_points())
# shear_stress.interpolate(shear_stress_expr)
