Evaluate solution at grid points of structured mesh and reshape to tensor
Hello everyone,
I have a structured 3D grid and solve linear elasticity on that grid. After computing the solution vector uh, I would like to reshape it into an array of shape (Nx+1, Ny+1, Nz+1, 3) where Nx is the number of cells in x direction and so one, 3 is the number of component functions of the solution. The same should be done for a vector valued coefficient function C.
I am using the following domain and function spaces:
Nx = 20
Ny = 10
Nz = 10
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([2, 1, 1])],
                         [Nx, Ny, Nz], cell_type=mesh.CellType.tetrahedron)
# solution space
u = ufl.TrialFunction(V)
# space for coefficient function in PDE
space_Coeff = fem.functionspace(domain, ("CG", 1, (6,6)))
C = fem.Function(space_Coeff)
# after computing the solution vector uh from the variational problem we reshape
uh = uh.x.array.reshape(Nx+1, Ny+1, Nz+1, 3)
C_ = C.x.array.reshape(Nx+1, Ny+1, Nz+1, 6*6)
My question:
Is this the correct way of reshaping such that the tensors uh and C_ contain the values of the solution/coefficient function u and C at the grid points, i.e. uh[i_x, i_y, i_z, k] = u(i_x/Nx, i_y/Ny, i_z/Nz, k) where k=0,1,2 indices the component. Or does fenicsx use a different numbering when computing the solution vector uh over a structured grid such that the standard reshape does not fulfill this?
Thanks in advance and kind regards:)
See for instance:
DOLFINx in general does not consider a mesh structured. All meshes are unstructured, and data is reordered with respect to data-locality.
Thank you @dokken .
Yes I expected that and figured it out.
