Evaluating Function at Specific Points in FEniCS-Dolfin and tIGAr
I am currently working with FEniCS-Dolfin (version 2019.2.0.64.dev0) and tIGAr (version 2019.1) on Linux Ubuntu 24.04.1 LTS to solve the biharmonic problem using B-Splines. I run the following demo code i found from GitHub
The simplest example of a weak form that cannot be approached with traditional
FEA:  The biharmonic problem.
This example uses the simplest IGA discretization, namely, explicit B-splines
in which parametric and physical space are the same.
from tIGAr import *
from tIGAr.BSplines import *
import math
import subprocess
# Number of levels of refinement with which to run the Poisson problem.
# (Note: Paraview output files will correspond to the last/highest level
# of refinement.)
N_LEVELS = 3
# Array to store error at different refinement levels:
#L2_errors = zeros(N_LEVELS)
energyErrors = zeros(N_LEVELS)
# NOTE:  $L^2$ errors do not converge at optimal rate for the lowest feasible
# spline degree (quadratic), as, to complete the Aubin--Nitsche duality
# argument one needs the error to be more regular than this case allows.
# Energy norm convergence remains optimal for all degrees and is measured
# in this demo.  $L^2$ errors can be measured as well by un-commenting
# several lines below.
for level in range(0,N_LEVELS):
    ####### Preprocessing #######
    # Parameters determining the polynomial degree and number of elements in
    # each parametric direction.  By changing these and recording the error,
    # it is easy to see that the discrete solutions converge at optimal rates
    # under refinement.
    p = 4
    q = 4
    NELu = 10*(2**level)
    NELv = 10*(2**level)
    if(mpirank==0):
        print("Generating extraction...")
    # Create a control mesh for which $\Omega = \widehat{\Omega}$.
    splineMesh = ExplicitBSplineControlMesh([p,q],
                                            [uniformKnots(p,-1.0,1.0,NELu),
                                             uniformKnots(q,-1.0,1.0,NELv)])
    # Create a spline generator for a spline with a single scalar field on the
    # given control mesh, where the scalar field is the same as the one used
    # to determine the mapping $\mathbf{F}:\widehat{\Omega}\to\Omega$.
    splineGenerator = EqualOrderSpline(1,splineMesh)
    # Set Dirichlet boundary conditions on the 0-th (and only) field, on both
    # ends of the domain, in both directions, for two layers of control points.
    # This strongly enforces BOTH $u=0$ and $\nabla u\cdot\mathbf{n}=0$.
    field = 0
    scalarSpline = splineGenerator.getScalarSpline(field)
    for parametricDirection in [0,1]:
        for side in [0,1]:
            sideDofs = scalarSpline.getSideDofs(parametricDirection,side,
                                                nLayers=2) # two layers of CPs
            splineGenerator.addZeroDofs(field,sideDofs)
    # Write extraction data to the filesystem.
    DIR = "./extraction"
    splineGenerator.writeExtraction(DIR)
    ####### Analysis #######
    if(mpirank==0):
        print("Setting up extracted spline...")
    # Choose the quadrature degree to be used throughout the analysis.
    QUAD_DEG = 2*max(p,q)
    # Create the extracted spline directly from the generator.
    # As of version 2019.1, this is required for using quad/hex elements in
    # parallel.
    spline = ExtractedSpline(splineGenerator,QUAD_DEG)
    # Alternative: Can read the extracted spline back in from the filesystem.
    # For quad/hex elements, in version 2019.1, this only works in serial.
    #spline = ExtractedSpline(DIR,QUAD_DEG)
    if(mpirank==0):
        print("Solving...")
    # Homogeneous coordinate representation of the trial function u.  Because
    # weights are 1 in the B-spline case, this can be used directly in the PDE,
    # without dividing through by weight.
    u = TrialFunction(spline.V)
    # Corresponding test function.
    v = TestFunction(spline.V)
    # Laplace operator, using spline's div and grad operations
    def lap(x):
        return spline.div(spline.grad(x))
    # Create a force, f, to manufacture the solution, soln
    x = spline.spatialCoordinates()
    soln = (cos(pi*x[0])+1.0)*(cos(pi*x[1])+1.0)
    f = lap(lap(soln))
    # Set up and solve the biharmonic problem
    res = inner(lap(u),lap(v))*spline.dx - inner(f,v)*spline.dx
    u = Function(spline.V)
    spline.solveLinearVariationalProblem(res,u)
    print(u(0.2,0.3))
    ####### Postprocessing #######
    # The solution, u, is in the homogeneous representation, but, again, for
    # B-splines with weight=1, this is the same as the physical representation.
    File("results/u.pvd") << u
    # Compute and print the error in the discrete solution.
    #L2_error = math.sqrt(assemble(((u-soln)**2)*spline.dx))
    energyError = math.sqrt(assemble((lap(u-soln)**2)*spline.dx))
    #L2_errors[level] = L2_error
    energyErrors[level] = energyError
    if(level > 0):
        #rate = math.log(L2_errors[level-1]/L2_errors[level])/math.log(2.0)
        rate = math.log(energyErrors[level-1]/energyErrors[level])\
               /math.log(2.0)
        rate = "--"
    if(mpirank==0):
        #print("L2 Error for level "+str(level)+" = "+str(L2_error)
        #      +"  (rate = "+str(rate)+")")
        print("Energy error for level "+str(level)+" = "+str(energyError)
I aim to evaluate the solution function at specific points in the domain. However, when attempting to compute the value using the syntax u(0.2, 0.3), I encounter an error
  File "/app/biharmonic2.py", line 117, in <module>
    print(u(0.2,0.3))
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/function/function.py", line 355, in __call__
    self._cpp_object.eval(values, x)
RuntimeError:
***     https://fenicsproject.discourse.group/
*** Error:   Unable to intersect cell and point.
*** Reason:  Intersection is only implemented for simplex meshes.
*** Where:   This error was encountered inside Cell.cpp.
*** Process: 0
*** DOLFIN version: 2019.2.0.64.dev0
*** Git changeset:  ubuntu
Could anyone kindly guide me on the correct approach to evaluate the function at a predefined set of points in this framework?
Thank you in advance for your time and assistance.
Looking at some other tIGAr-dependent code that hasn’t been touched in a while, I suspect that the following would work:
xi = np.array([0.2, 0.3])
u_eval = u(xi)
Thank you for your suggestion. Unfortunately i’m still encountering the same error.
You mentioned referencing some other tIGAr-dependent code. Could you share the specific examples or sources you looked into? That might help with the problem.
Additionally, do you have any alternative suggestions or approaches to troubleshoot and resolve this issue?
  File "/app/biharmonic2.py", line 119, in <module>
    u_eval=u(xi)
RuntimeError:
*** Process: 0
I looked at a specific function in the PENGoLINS module. As far as I’m aware the module is no longer under active development. However, it’s been built on top of tIGAr, so leverages a bunch of its utilities under the hood. If you search for eval_func in that repository it will bring up everywhere that function has been used. That should be somewhat informative.
