I solved the problem (curl-curl equations) using Nedelec basis functions and obtained a (number of edges x 1) solution as expected. For example, assume that, I have 1584 edges in total, after I convert FEM solution to numpy array, I obtained 1584x1 vector. Now, I want to calculate the value of the solution (FEM solution) on the selected points (for instance, quadrature points). In my case, I have 1024 triangles and 3 quadrature points per triangle, I have totally 3072 points. I want to calculat ethe value of the FEM solution on these points, I want to obtain (3072,1) solution matrix obtained from the selected points. How can I project my solution (edge-based Nedelec basis functions are used) selected points.
I read different question from the forum and tutorial but I think, my question is not answered because in my case, I cannot obtain the solution of (number of pointsx1) that I expected to obtain as a result of the solution matrix (number of edgesx1) and projection to the selected points in any of the explained methods. What approach should I take? Are there any functions or code blocks that I can use to do this?
Thank you very much for your help
