Hi all,
Background
I want to perform a coordinate transform of my PDE, the Helmholtz equation. This coordinate transform is prescribed by another PDE which I solve in disjoint regions. Because this is solved in disjoint regions it is not continuously differentiable. To finally transform the Helmholtz equation I introduce, among other terms, a discontinuous Jacobian.
To be able to use the calculated transformation in the weak formulation of the Helmholtz equation, I have to map the values of the computed coordinate transformation onto a function that is defined on the mesh of the complete space.
To obtain the values at the vertices of the mesh of the solution x_transform I can do
values_x_transform = x_transform.x.array
However, I cannot do the same to get the values at the vertices of the derivative of x_transform, Dx(x_transform, 0). I would like to do something like
x_transform_derivative = Dx(x_transform, 0)
values_x_transform_derivative = x_transform_derivative.x.array
But this is not possible. I currently do this by solving an auxillary equation:
a = inner(u, v) * dx
L = inner(x_transform_derivative, v) * dx
uh = Function(V)
problem = fem.LinearProblem(a, L, u=uh, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
problem.solve()
values = uh.x.array # Extract sought vector
but this sounds rather wasteful on the computer resource front because a complete system has to be solved for this.
Question
Can I evaluate an UFL expression g at the mesh points of the underlying mesh? I have tried g(mesh.geometry.x) but this results in an infinite recursion loop.
A minimal working example (MWE) would be
from dolfinx import FunctionSpace, Function, fem
from dolfinx.generation import UnitSquareMesh
from ufl import TrialFunction, TestFunction, inner, dx, Dx
mesh = UnitSquareMesh(MPI.COMM_WORLD, 8, 8, dolfinx.cpp.mesh.CellType.quadrilateral)
V = FunctionSpace(mesh, ("CG", 1))
f = Function(V)
f.interpolate(lambda x: (x[0] ** 2) * (1 + 1j)) # An interesting nonzero example
g = Dx(f, 0) # Some ufl expression we want to evaluate
g(mesh.geometry.x) # Segfault due to infinite recursion:
Infinite recursion encountered:
File "/../ufl/core/expr.py", line 318 in __float__
File "/../ufl/core/terminal.py", line 50 in evaluate
File "/../ufl/exproperators.py", line 320 in _eval
File "/../ufl/exproperators.py", line 330 in _call
File "/../ufl/core/expr.py", line 313 in _ufl_evaluate_scalar_
# ---- Known solution, presumably rather slow because a full linear system needs to be solved ---- #
L = inner(g, v) * dx
uh = Function(V)
problem.solve()
Can I extract the values of the UFL expression at the mesh points without solving an auxillary problem as I have done above?
More information:
I use the Docker image build from the 0.3.0 release with complex mode enabled.
Many thanks in advance!
-Wouter
