In the below MWE, I am compiling the outer three annuli into a single domain. So I am left out with two meshes, the mesh on the innermost disc and the single combined mesh of the outer three annuli. Next, I am applying a pressure on the innermost circle (for the pressure, I am considering a for loop to slowly increase the pressure, otherwise the code diverges) and solving for the deformation (u1
) of the combined mesh by minimizing a variational form that consists of identity matrices and a pressure term. The deformation (u2
), due to deformation u1
, of the disc mesh is computed by minimizing another variational form and passing the displacement of the nodes on the innermost circle as a DirichletBC. This code works perfectly fine and gives me accurate results.
Next, I am applying ALE.move()
on both meshes by their corresponding solutions.
Next, there is another similar loop. In this loop, the pressure doesn’t increase. Instead the entries of a diagonal matrix changes with iterations which is incorporated into the strain energy density function.
MWE:
I have considered the following geometry:
GMSH script (in the MWE, the msh file is named MWE.msh):
SetFactory("OpenCASCADE");
Circle(1) = {0, 0, 0, 1, 0, 2*Pi};
Circle(2) = {0, 0, 0, 1.5, 0, 2*Pi};
Circle(3) = {0, 0, 0, 2.5, 0, 2*Pi};
Circle(4) = {0, 0, 0, 3.5, 0, 2*Pi};
Hide "*";
Show {
Curve{1}; Curve{2}; Curve{3}; Curve{4};
Physical Curve("C1", 1) = {1};
Physical Curve("C2", 2) = {2};
Physical Curve("C3", 3) = {3};
Physical Curve("C4", 4) = {4};
Curve Loop(1) = {1};
Plane Surface(1) = {1};
Curve Loop(2) = {2};
Curve Loop(3) = {1};
Plane Surface(2) = {2, 3};
Curve Loop(4) = {3};
Curve Loop(5) = {2};
Plane Surface(3) = {4, 5};
Curve Loop(6) = {4};
Curve Loop(7) = {3};
Plane Surface(4) = {6, 7};
Physical Surface("S5", 5) = {2};
Physical Surface("S6", 6) = {3};
Physical Surface("S7", 7) = {4};
Physical Surface("S8", 8) = {1};
The mesh looks like
Here is the MWE:
import numpy
out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
return out_mesh
#***********IMPORTING GEOMETRY FROM GMSH*****************************
msh = meshio.read("MWE.msh")
triangle_mesh = create_mesh(msh, "triangle", True)
line_mesh = create_mesh(msh, "line", True)
meshio.write("mf.xdmf", line_mesh)
mesh = Mesh()
infile.read(mesh)
ds_custom = Measure("dS", domain=mesh, subdomain_data=mf)
dx_custom = Measure("dx", domain=mesh, subdomain_data=cf)
#***********************EXTRACTING DISC MESH AND DEFINING MEASURES******************
lumen=SubMesh(mesh,cf,8)
boundary_marker_lum = MeshFunction("size_t", lumen, lumen.topology().dim()-1, 0)
ncells2 = MeshFunction("size_t", lumen, lumen.topology().dim())
surface_marker_lum = MeshFunction("size_t", lumen, lumen.topology().dim(), 0)
vmap2 = lumen.data().array("parent_vertex_indices", 0)
cmap2 = lumen.data().array("parent_cell_indices", lumen.topology().dim())
n = 0
for c in cells(lumen):
parent_cell = Cell(mesh, cmap2[c.index()])
surface_marker_lum.array()[c.index()] = cf.array()[parent_cell.index()]
for f in facets(parent_cell):
for g in facets(c):
g_vertices = vmap2[g.entities(0)]
if set(f.entities(0)) == set(g_vertices):
boundary_marker_lum.array()[g.index()] = mf.array()[f.index()]
n=n+1
ds_lum = Measure('ds', domain=lumen, subdomain_data=boundary_marker_lum)
dx_lum = Measure('dx', domain=lumen, subdomain_data=surface_marker_lum)
#************COMPILING OUTER THREE ANNULI TO SOLVE THE HYPERELASTICITY PROBLEM***************
combined_subdomains = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
cs_2 = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
combined_subdomains.array()[cf.array()==5] = 1
combined_subdomains.array()[cf.array()==6] = 1
combined_subdomains.array()[cf.array()==7] = 1
mesh_ima = SubMesh(mesh, combined_subdomains, 1)
boundary_marker_ima = MeshFunction("size_t", mesh_ima, mesh_ima.topology().dim()-1, 0)
ncells0 = MeshFunction("size_t", mesh_ima, mesh_ima.topology().dim())
surface_marker_ima = MeshFunction("size_t", mesh_ima, mesh_ima.topology().dim(), 0)
vmap0 = mesh_ima.data().array("parent_vertex_indices", 0)
cmap0 = mesh_ima.data().array("parent_cell_indices", mesh_ima.topology().dim())
n = 0
for c in cells(mesh_ima):
parent_cell = Cell(mesh, cmap0[c.index()])
surface_marker_ima.array()[c.index()] = cf.array()[parent_cell.index()]
for g in facets(c):
g_vertices = vmap0[g.entities(0)]
boundary_marker_ima.array()[g.index()] = mf.array()[f.index()]
n=n+1
ds_ima = Measure("ds", domain=mesh_ima, subdomain_data=boundary_marker_ima)
dx_ima= Measure("dx", domain=mesh_ima, subdomain_data=surface_marker_ima)
n = FacetNormal(mesh_ima)
#*****************SOLVING HYPERELASTICITY PROBLEM ON THE OUTER THREE ANNULI COMBINED**************
V1 = VectorFunctionSpace(mesh_ima, "Lagrange", 1) # Introducing a vector function space on intima, media and adventitia combined, i.e., ima submesh
V2 = VectorFunctionSpace(lumen, "Lagrange", 1) # Introducing a vector function space on lumen
#----------DEFINING FUNCTIONS NEEDED FOR THE VARIATIONAL FORM--------------------------
u1 = Function(V1)
u2 = Function(V2)
v1 = TestFunction(V1)
v2 = TestFunction(V2)
u_ima = Function(V1)
u_lum = Function(V2)
P = 0.0
Pmax = 0.0
#---------------------DEFINING FUNCTIONS NEEDED FOR THE VARIATIONAL FORM FOR THE DISC---------------------
dp = 0.1 # Small pressure increment
NumSteps = 10
for i in range(0,NumSteps): # For loop for pressure increment
dl = lumen.geometry().dim()
Il = Identity(dl) # Identity tensor
Fl = Il + grad(u2)
J_e_l = det(Fl)
C_lumen = Fl.T*Fl
Ic_lumen = tr(C_lumen)
alpha, mu_lumen = 0.16666,1.0
psi_lumen = (mu_lumen/2)*(Ic_lumen - 3) + (alpha)*(J_e_l-1)**2 - mu_lumen*ln(J_e_l)
Pi_lumen = (psi_lumen*dx(domain=lumen))
#-----------------------------------------------------SETTING THE KINEMATICS FOR IMA-----------------------------------------------------------------------------------------------------
d = mesh_ima.geometry().dim()
I = Identity(d) # Identity tensor
F = I + grad(u1) # Deformation gradient
g_int = as_matrix([[1.0,0.0,0.0],[0.0,1.0,0.0],[0.0,0.0,1.0]])
g_med = Identity(d)
g_ad = Identity(d)
C_int = (F*inv(g_int)).T*(F*inv(g_int))
C_med = (F*inv(g_med)).T*(F*inv(g_med))
C_ad = (F*inv(g_ad)).T*(F*inv(g_ad))
M = cofac(F)
Ic_int = tr(C_int)
Ic_med = tr(C_med)
Ic_ad = tr(C_ad)
J_int = det(F*inv(g_int))
J_med = det(F*inv(g_med))
J_ad = det(F*inv(g_ad))
J_e = det(F)
C_lumen = F.T*F
# Elasticity parameters
nu = 0.497
mu1, mu2, mu3 = 27.9, 1.27, 7.56
eta_int, eta_med, eta_ad = 263.66, 21.6, 38.57
beta_int, beta_med, beta_ad = 170.88, 8.21, 85.03
rho_int, rho_med, rho_ad = 0.51, 0.25, 0.55
psi1 = (mu1/2)*(Ic_int - 3) + ((nu)*(mu1)/(1-2*nu))*(J_int-1)**2 - mu1*(ln(J_int)) + (eta_int/beta_int)*(exp(beta_int*((1-rho_int)*(Ic_int - 3)**2))-1)
psi2 = (mu2/2)*(Ic_med - 3) + ((nu)*(mu2)/(1-2*nu))*(J_med-1)**2 - mu2*(ln(J_med)) + (eta_med/beta_med)*(exp(beta_med*((1-rho_med)*(Ic_med - 3)**2))-1)
psi3 = (mu3/2)*(Ic_ad - 3) + ((nu)*(mu3)/(1-2*nu))*(J_ad-1)**2 - mu3*(ln(J_ad)) + (eta_ad/beta_ad)*(exp(beta_ad*((1-rho_ad)*(Ic_ad - 3)**2))-1)
Pi = (det(g_int))*(psi1*dx_ima(5)) + (det(g_med))*(psi2*dx_ima(6)) + (det(g_ad))*(psi3*dx_ima(7)) - (0.5)*inner(M*(P+(i*dp))*(-n), u1)*ds_ima(1)
Pi2 = psi_lumen*dx_lum(8)
# Compute first variation of Pi (directional derivative about u in the direction of v)
F1 = derivative(Pi, u1, v1)
F2 = derivative(Pi2, u2, v2)
bcs = []
# Solve variational problem
solve(F1 == 0, u1, bcs,
form_compiler_parameters=ffc_options)
u1.set_allow_extrapolation(True)
bc2 = DirichletBC(V2, u1, boundary_marker_lum, 1)
solve(F2 == 0, u2, bc2,
u_ima.assign(u1)
u1 = interpolate(u_ima, V1)
u_lum.assign(u2)
u2 = interpolate(u_lum, V2)
print('Pressure at the end of each loop', P+(i*dp))
print('END OF PRESSURE FOR LOOP')
Pmax = P + (NumSteps-1)*dp
print('Pmax =', Pmax)
#************************MOVING MESHES BY THE SOLUTIONS**********************
ALE.move(mesh_ima,u1) # Without ALE.move, the code works fine
ALE.move(lumen,u2)
#*****************************FOR LOOP FOR MATRIX****************************
V_lum = VectorFunctionSpace(lumen, 'P', 1)
V_ima = VectorFunctionSpace(mesh_ima, 'P', 1)
ug1 = Function(V_ima)
ug2 = Function(V_lum)
vg1 = TestFunction(V_ima)
vg2 = TestFunction(V_lum)
ug_ima = Function(V_ima)
ug_lum = Function(V_lum)
ng = FacetNormal(mesh_ima)
dt = 0.05
NumStepg = 10
for j in range(0,NumStepg): # For loop for matrix increment
dlg = lumen.geometry().dim()
Ilg = Identity(dlg) # Identity tensor
Flg = Ilg + grad(ug2)
J_e_lg = det(Flg)
Cg_lumen = Flg.T*Flg
Icg_lumen = tr(Cg_lumen)
psig_lumen = (mu_lumen/2)*(Icg_lumen - 3) + (alpha)*(J_e_lg-1)**2 - mu_lumen*ln(J_e_lg) # Accoding to Gou_Pence
dg = mesh_ima.geometry().dim()
Ig = Identity(dg) # Identity tensor
Fg = Ig + grad(ug1) # Deformation gradient
g_i = as_matrix([[1.0+(j*dt),0.0,0.0],[0.0,1.0+(j*dt),0.0],[0.0,0.0,1.0]])
g_med = Identity(dg)
g_ad = Identity(dg)
Cg_int = (Fg*inv(g_i)).T*(Fg*inv(g_i))
Cg_med = (Fg*inv(g_med)).T*(Fg*inv(g_med))
Cg_ad = (Fg*inv(g_ad)).T*(Fg*inv(g_ad))
Mg = cofac(Fg)
Icg_int = tr(Cg_int)
Icg_med = tr(Cg_med)
Icg_ad = tr(Cg_ad)
Jg_int = det(Fg*inv(g_int))
Jg_med = det(Fg*inv(g_med))
Jg_ad = det(Fg*inv(g_ad))
Jg_e = det(Fg)
psig1 = (mu1/2)*(Icg_int - 3) + ((nu)*(mu1)/(1-2*nu))*(Jg_int-1)**2 - mu1*(ln(Jg_int)) + (eta_int/beta_int)*(exp(beta_int*((1-rho_int)*(Icg_int - 3)**2))-1)
psig2 = (mu2/2)*(Icg_med - 3) + ((nu)*(mu2)/(1-2*nu))*(Jg_med-1)**2 - mu2*(ln(Jg_med)) + (eta_med/beta_med)*(exp(beta_med*((1-rho_med)*(Icg_med - 3)**2))-1)
psig3 = (mu3/2)*(Icg_ad - 3) + ((nu)*(mu3)/(1-2*nu))*(Jg_ad-1)**2 - mu3*(ln(Jg_ad)) + (eta_ad/beta_ad)*(exp(beta_ad*((1-rho_ad)*(Icg_ad - 3)**2))-1)
Pig = det(g_i)*(psig1*dx_ima(5)) + (det(g_med))*(psig2*dx_ima(6)) + (det(g_ad))*(psig3*dx_ima(7)) - (0.5)*inner(Mg*(Pmax)*(-ng), ug1)*ds_ima(1)
Pig2 = psig_lumen*dx_lum(8)
Fg1 = derivative(Pig, ug1, vg1)
Fg2 = derivative(Pig2, ug2, vg2)
bcgs_ima = []
solve(Fg1 == 0, ug1, bcgs_ima,
ug1.set_allow_extrapolation(True)
bcgs_lum = DirichletBC(V_lum, ug1, boundary_marker_lum, 1)
solve(Fg2 == 0, ug2, bcgs_lum,
ug_ima.assign(ug1)
ug1 = interpolate(ug_ima, V_ima)
ug_lum.assign(ug2)
ug2 = interpolate(ug_lum, V_lum)
print('g_int(11) =', 1.0+j*dt)
print('end of a growth loop')
ALE.move(mesh_ima,ug1)
ALE.move(lumen,ug2)
This provides the following error:
File "MWE.py", line 317, in <module>
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py", line 233, in solve
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py", line 314, in _solve_varproblem
solver.solve()
RuntimeError:
*** Error: Unable to create mesh entity.
*** Reason: Mesh entity index -1 out of range [0, 378] for entity of dimension 2.
*** Where: This error was encountered inside MeshEntity.cpp.
*** Process: 0
*** Git changeset: unknown
The code works fine if ALE.move()
is not applied in between the loops.
I am unable to figure out the problem here. Any help would be greatly appreciated. Thanks.
