Hello everyone,
I want to explore the export functionalities of dolfinx 0.9. Specifically, if higher order finite element functions can directly be exported without having to do any interpolations.
For this I constructed the following minimal working example:
import dolfinx.mesh
import dolfinx.fem
import dolfinx.io
import basix
from ufl import *
# Create a mesh
# Define P2 function space
# Ve = basix.ufl.element("Lagrange", mesh.basix_cell(), degree=2)
V = dolfinx.fem.functionspace(mesh, ("CG", 2))
# Create and name a function
u = dolfinx.fem.Function(V)
u.name = "solution"
def f(mod, x):
return sin(pi * x[0]) * sin(pi * x[1])
u.interpolate(f)
expr = dolfinx.fem.Expression(u, V.element.interpolation_points())
# Write mesh and function to XDMF
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "solution.xdmf", "w") as xdmf:
xdmf.write_mesh(mesh)
xdmf.write_function(u)
I get the following error :
File "/opt/anaconda3/envs/envt_name/lib/python3.13/site-packages/dolfinx/fem/function.py", line 459, in interpolate
_interpolate(u0)
File "/opt/anaconda3/envs/envt_name/lib/python3.13/functools.py", line 934, in wrapper
File "/opt/anaconda3/envs/envt_name/lib/python3.13/site-packages/dolfinx/fem/function.py", line 440, in _interpolate
self._cpp_object.interpolate(u0, cells0, cells1) # type: ignore
TypeError: interpolate(): incompatible function arguments. The following argument types are supported:
1. interpolate(self, f: ndarray[dtype=complex128, writable=False, shape=(*), order='C'], cells: ndarray[dtype=int32, writable=False, shape=(*), order='C']) -> None
2. interpolate(self, f: ndarray[dtype=complex128, writable=False, shape=(*, *), order='C'], cells: ndarray[dtype=int32, writable=False, shape=(*), order='C']) -> None
3. interpolate(self, u: dolfinx.cpp.fem.Function_complex128, cells0: ndarray[dtype=int32, writable=False, shape=(*), order='C'], cells1: ndarray[dtype=int32, writable=False, shape=(*), order='C']) -> None
4. interpolate(self, u: dolfinx.cpp.fem.Function_complex128, cells: ndarray[dtype=int32, writable=False, shape=(*), order='C'], interpolation_data: dolfinx.cpp.geometry.PointOwnershipData_float64) -> None
5. interpolate(self, e0: dolfinx.cpp.fem.Expression_complex128, cells0: ndarray[dtype=int32, writable=False, order='C'], cells1: ndarray[dtype=int32, writable=False, order='C']) -> None
Invoked with types: dolfinx.cpp.fem.Function_complex128, function, ndarray, ndarray
File "src/new_dolfinx/P2Fields.py", line 25, in <module>
u.interpolate(f)
File "/opt/anaconda3/envs/envt_name/lib/python3.13/site-packages/dolfinx/fem/function.py", line 466, in interpolate
self._cpp_object.interpolate(np.asarray(u0(x), dtype=self.dtype), cells0) # type: ignore
File "/Users/anant/PhD/felics_simulations/src/new_dolfinx/P2Fields.py", line 24, in f
return ufl.sin(ufl.pi * x[0]) * ufl.sin(ufl.pi * x[1])
File "/opt/anaconda3/envs/envt_name/lib/python3.13/site-packages/ufl/operators.py", line 628, in sin
return _mathfunction(f, Sin)
File "/opt/anaconda3/envs/envt_name/lib/python3.13/site-packages/ufl/operators.py", line 597, in _mathfunction
f = as_ufl(f)
File "/opt/anaconda3/envs/envt_name/lib/python3.13/site-packages/ufl/constantvalue.py", line 517, in as_ufl
raise ValueError(
f"Invalid type conversion: {expression} can not be converted to any UFL type."
ValueError: Invalid type conversion: [2.82743339e+00 3.14159265e+00 3.14159265e+00 ... 1.57079633e-01
1.57079633e-01 7.51366423e-34] can not be converted to any UFL type.
If I simply comment out :
def f(mod, x):
u.interpolate(f)
and run the remaining code, then I get the error :
File "src/new_dolfinx/P2Fields.py", line 37, in <module>
File "/opt/anaconda3/envs/envt_name/lib/python3.13/site-packages/dolfinx/io/utils.py", line 252, in write_function
super().write_function(getattr(u, "_cpp_object", u), t, mesh_xpath)
RuntimeError: Degree of output Function must be same as mesh degree. Maybe the Function needs to be interpolated?
Would be highly grateful for any leads. Thanks and regards! ![]()
