I’m not getting any error with the MWE. The following runs for me using FEniCS 2019.1.0:
T = 3
p01 = -1.
p03 = -1.
cutoff_Tc = 1
# Define the loading as an expression depending on t
p1 = Expression(("0", "t <= tc ? p01*t/tc : p03", "0"),
t=0, tc=cutoff_Tc, p01=p01, p03=p03, degree=0)
for i in range(0,3):
print(assemble(p1[i]*dx(domain=UnitIntervalMesh(1))))
Thanks for your help, but it still does not work…
I tried also: dijitso.cmdline.cmd_clean() …here I am not sure what the arguments should be in dijitso.cmdline.cmd_clean(args, params)
The error.log file says that there is no Expression.h file, but it exists.
And it worked before…
/tmp/tmpi1ft54_x/dolfin_expression_c724df7a690a4ccbba6d7cc00af10c2b.cpp:13:10: fatal error: dolfin/function/Expression.h: No such file or directory
#include <dolfin/function/Expression.h>
compilation terminated.
