I am using legacy Fenics. Given a function defined on a mesh, I would like to extract its values only on the points which belong to the mesh boundary. I have looked online for this, all I could find is either
answers how to define a class which defines a boundary which is then used in DirichletBC to impose the BC on that boundary.
Thank you. This solution works only for functions in space FunctionSpace(mesh, 'CG', 1), not for functions in CG2:
mesh = UnitSquareMesh(4, 4)
V = FunctionSpace(mesh, 'CG', 2)
u.interpolate(Expression('x[0]+ 2*x[1]', degree=1))
vertex_function = MeshFunction("size_t", mesh, 0)
class BoundaryMarker(SubDomain):
return on_boundary
BoundaryMarker().mark(vertex_function, 1)
boundary_vertices = np.asarray(vertex_function.where_equal(1))
v_to_d = vertex_to_dof_map(V)
dofs = v_to_d[boundary_vertices]
for dof in dofs:
print(x[dof], u.vector()[dof])
$python3 solve.py
File "solve.py", line 21, in <module>
RuntimeError:
*** Error: Unable to tabulate dof to vertex map.
*** Reason: Can only tabulate dofs on vertices.
*** Where: This error was encountered inside DofMap.cpp.
Do you know how to make this work also for functions in other spaces ? I found this answer but then I don’t know how to do the equivalent of vertex_to_dof_map with the approach suggested in there.
Following your link, I found a solution by using a dummy space of polynomials with one degree, here it is. This function returns the coordinates of the boundary points of a mesh, then the nodal values of a function (even if this function is defined on a polynomial space with degree larger than one) can be obtained by evaluating the function at these points.
def boundary_points(mesh):
# create a dummy function space of degree 1 which will be used only to extract the boundary points
Q_dummy = FunctionSpace( mesh, 'CG', 1 )
vertex_to_degree_of_freedom_map = vertex_to_dof_map( Q_dummy )
vertex_function = MeshFunction( "size_t", mesh, 0 )
vertex_function.set_all( 0 )
BoundaryMarker().mark( vertex_function, 1 )
boundary_vertices = np.asarray( vertex_function.where_equal( 1 ) )
degrees_of_freedom = vertex_to_degree_of_freedom_map[boundary_vertices]
x = Q_dummy.tabulate_dof_coordinates()
x = x[degrees_of_freedom]
return x
