Extracting 2D boundary mesh from 3D mesh
Hello all,
I’m currently trying to extract a certain 2D portion of the boundary of a 3D mesh. As a minimum working example, consider trying to extract the bottom surface of a unit cube.
dim = 3
N = 2**5
mesh = UnitCubeMesh(N,N,N)
bdim = dim-1
bmesh = BoundaryMesh(mesh, "exterior")
mapping = bmesh.entity_map(bdim)
part_of_bot = MeshFunction("size_t", bmesh, bdim)
for cell in cells(bmesh):
    curr_facet_normal = Facet(mesh, mapping[cell.index()]).normal()
    if near(curr_facet_normal.y(), -1.0): #On bot boundary
        part_of_bot[cell] = 1
bot_boundary = SubMesh(bmesh, part_of_bot, 1)
File('bot_boundary.pvd') << bot_boundary
When directly examining the output mesh files, I can see that it preserved the y coordinate (which makes sense). However, I need the 2D mesh, with the zero y coordinate pruned. How might I go about getting rid of that coordinate from bot_boundary, or better yet, is there a way to build bot_boundary (say an option that I can pass to SubMesh) that doesn’t preserve the y coordinate in the first place? I can’t find a relevant function in the docs (Restriction seemed relevant, but that’s been removed since).
Thanks for any input.
If it helps, my goal is eventually to pass the resulting 2d mesh to VectorFunctionSpace. There’s a dimension option for VectorFunctionSpace which I believe will let it ignore the 3rd coordinate, however that won’t work my application and the MWE as they lie in the X-Z plane. I suppose I could rotate bot_boundary into the X-Y plane and proceed like that.
There must be a better way to do it than that though.
Consider the following MWE using meshio (which can be installed with pip), for instance
pip3 install --no-binary=h5py h5py meshio --user
dim = 3
N = 2**5
mesh = UnitCubeMesh(N, N, N)
bdim = dim-1
    if near(curr_facet_normal.y(), -1.0):  # On bot boundary
#File('bot_boundary.pvd') << bot_boundary
with XDMFFile("bot_mesh.xdmf") as xdmf:
    xdmf.write(bot_boundary)
in_mesh = meshio.read("bot_mesh.xdmf")
cells = in_mesh.get_cells_type("triangle")
points = np.delete(in_mesh.points, 1, axis=1)
out_mesh = meshio.Mesh(points=points, cells={"triangle": cells})
meshio.write("pruned_mesh.xdmf", out_mesh)
mesh2D = Mesh()
with XDMFFile("pruned_mesh.xdmf") as xdmf:
    xdmf.read(mesh2D)
print(mesh2D.geometry().dim())
Thank you, that seems to work!
I am able to extract boundary mesh using above MWE, but, unable to obtain the subdomains from original 3D mesh. The application is cylinder inscribed in a cube. (sub-domain1=cylinder, subdomain2=cube). Like using mesh0 = SubMesh(mesh, subdomains, 0) gives cylinder mesh.
How can we get the subdomain mesh at boundary, bot_boundary which would be a 2D circle?
Like, the bot_boundary=SubMesh(bmesh, part_of_bot, 1) giving submesh at y=-1 boundary.
, can we extract original subdomain data from bot_boundary.
I tried using,
bot_boundary_0=SubMesh(bot_boundary, subdomains,0) and creating bmesh using only mesh0, but, all causing entire page shut. Any help is greatly appreciated…
