Hi, is there a way of extracting the boundary facet connectivity and the facet node coordinates from a mesh? For example from the domain object below in the linear elasticity example.
This is to pick a facet using another algorithm that needs the surface mesh and then setting that single facet as a zero displacement Diritchlet BC.
Thank you,
Alex
# Scaled variable
import pyvista
from dolfinx import mesh, fem, plot, io, default_scalar_type
L = 1
W = 0.2
mu = 1
rho = 1
delta = W / L
gamma = 0.4 * delta**2
beta = 1.25
lambda_ = beta
g = gamma
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([L, W, W])],
[20, 6, 6], cell_type=mesh.CellType.hexahedron)
def clamped_boundary(x):
return np.isclose(x[0], 0)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
return ufl.sym(ufl.grad(u)) # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma(u):
u = ufl.TrialFunction(V)
f = fem.Constant(domain, default_scalar_type((0, 0, -rho * g)))
uh = problem.solve()
