Extreme Memory Usage for Legacy Fenics Mixed Formulation Code
Hi everyone,
I’m trying to run some code using a mixed finite element for incompressible flow in Fenics, and although the code works fine, it is using up excessive memory. The code uses Taylor-Hood elements for velocity and pressure, another “Real” element type for used for Lagrange multipliers, and an implicit RK3 formulation for the time discretization (BDF3). For a 1 million element 3D mesh, around 900 GB of RAM is needed on an HPC, which is excessive. I wanted to see if anyone here knows why so much memory is being used and how I can fix it. I have tried switching to a few iterative solvers, as I am currently using a direct solver, but still excessive memory is required and the results were completely different for some of the ones I tried. A simple use of the code for low Reynolds number flow through a rectangular domain is shown below for the sake of reproducibility. Even for this case, I got a segmentation fault due to running out of memory and had to run this case on a cluster. The code is as follow:
Thank you!
from math import log
import numpy
parameters["std_out_all_processes"] = False;
parameters['ghost_mode'] = 'shared_facet'
tol=1E-10
K=1 # Polynomial Order
dt=0.1 # Time Step
Time=30 # Total Time
n_u = 0.001568 # Increased viscosity from air to get low Re
rho = 1 # Appr Density of air
V_in = 0.05; # Inlet Velocity
V_initial = V_in # Initial Velocity
P_out = 0.0 # Outlet (atmospheric pressure)
P_initial = 1.0 # Initial Pressure
count = 0 # File output counter
###################### Read Mesh in and define boundaries
el_x = 50;
el_y = el_x
mesh=RectangleMesh(Point(0.0, 0.0), Point(4.0, 1.0), el_x, el_y)
inlet = 'near(x[0],0)'
outlet = 'near(x[0], 4)'
walls = 'near(x[1], 0) || near(x[1], 1)'
###################### Define Function Spaces and Elements
U=VectorFunctionSpace(mesh,'CG',K+1) # for velocity
P=FunctionSpace(mesh,'CG',K) # for pressure
NU=FunctionSpace(mesh, 'Real', 0) # for lagrange multiplier
U_el=VectorElement("CG", mesh.ufl_cell(), K+1) ### CG element is choosen for velocity
P_el= FiniteElement("CG", mesh.ufl_cell(), K) ### CG space is choosen for pressure
Nu_el=FiniteElement("Real", mesh.ufl_cell(), 0) # Lagrange Multiplier
W_1=MixedElement([U_el, P_el, Nu_el])
W=FunctionSpace(mesh, W_1)
du=TrialFunction(W)
upnu=Function(W)
u,p,nu=split(upnu)
lg_n=Function(NU)
vqnv=TestFunction(W)
v,q,nv=split(vqnv)
####################### Initial Conditions
Pressure=Expression("P", P = P_initial, degree=1)
Velocity=Expression(("Vx", "0.0"), Vx = V_initial, degree=1)
u_1=Function(U)
u_2=Function(U)
u_3=Function(U)
p_1=Function(P)
p_2=Function(P)
p_3=Function(P)
lg_n= interpolate(Constant(1.0),NU)
u_1=interpolate(Velocity,U)
p_1=interpolate(Pressure,P)
u_2=interpolate(Velocity,U)
p_2=interpolate(Pressure,P)
u_3=interpolate(Velocity,U)
p_3=interpolate(Pressure,P)
############################################# BCs
UNoslip=DirichletBC(W.sub(0),Constant((0.0, 0.0)),walls) # Wall no-slip
UbcIn=DirichletBC(W.sub(0),Constant((V_in, 0.0)),inlet) # Inlet Velocity
PbcOut = DirichletBC(W.sub(1), Constant(P_out), outlet)# Outlet Pressure
bcs=[UNoslip, UbcIn, PbcOut]
############################################# Formulation Variables
h = CellDiameter(mesh) #if want to use edge diameter use FacetArea
h_avg = (h('+') + h('-'))/2.0
C_a=6.0*(K+1.0)*(K+2.0)/2.0
cons=6.0/11.0*dt # BDF3 hf Constant
iden=Identity(2) # Identity Matrix
L_1=dot(u,v)*dx-18.0/11.0*dot(u_3,v)*dx+9.0/11.0*dot(u_2,v)*dx-2.0/11.0*dot(u_1,v)*dx
L_2=-cons*div(u)*q*dx+cons*nv*(1/rho)*p*dx+cons*nu*q*dx
L_3=cons*dot(dot(u,nabla_grad(u)),v)*dx\
+cons*1/2*dot(div(u)*u,v)*dx\
-cons*dot(u('+'),n('+'))*dot(u('+')-u('-'),avg(v))*dS\
+0.5*cons*abs(dot(u('+'),n('+')))*dot(u('+')-u('-'),v('+')-v('-'))*dS\
-(1/rho)*cons*p*div(v)*dx ########### upwind flux
L_4=cons*n_u*inner(nabla_grad(u)+nabla_grad(u).T-2/3*div(u)*iden,nabla_grad(v))*dx\
-cons*n_u*dot(dot(avg(nabla_grad(u)+nabla_grad(u).T-2/3*div(u)*iden),n('+')),v('+')-v('-'))*dS\
-cons*n_u*dot(dot(avg(nabla_grad(v)+nabla_grad(v).T-2/3*div(v)*iden),n('+')),u('+')-u('-'))*dS\
+cons*n_u*C_a/h_avg*dot(u('+')-u('-'),v('+')-v('-'))*dS
L=L_1+L_2+L_3+L_4
t_i=2*dt
while(t_i<Time):
  t_i+=dt
  print(t_i)
  J= derivative(L,upnu,du)
  problem = NonlinearVariationalProblem(L,upnu,bcs,J)
  prm = solver.parameters
  prm["newton_solver"]["absolute_tolerance"] = tol
  prm["newton_solver"]["relative_tolerance"] = tol
  prm["newton_solver"]["maximum_iterations"] = 25
  prm["newton_solver"]["relaxation_parameter"] = 1.0
  #prm["newton_solver"]["linear_solver"] = "gmres"
  #prm["newton_solver"]["linear_solver"] = "petsc"
  #prm["newton_solver"]["preconditioner"] = "jacobi"
  prm["newton_solver"]["linear_solver"] = "mumps" #most stable
  solver.parameters["newton_solver"]["error_on_nonconvergence"] = False
  solver.solve()
  _u,_p,_lg=upnu.split(True)
  u_1.assign(u_2)
  u_2.assign(u_3)
  u_3.assign(_u)
  p_1.assign(p_2)
  p_2.assign(p_3)
  p_3.assign(_p)
  lg_n=_lg
  if (count > 0):
    File("Velocity_"+"Time_"+str(t_i)+"_.pvd") << _u
    File("Pressure_" +"Time_"+str(t_i)+"_.pvd") << _p
  count = count + 1
quit()
Move your solver definition outside of the time loop. You are recreating matrices, ksp solvers etc at every timestep. With modern petsc (>~3.16) these do not get destroyed properly by the Python garbage collector, leading to an accumulation in memory usage over time.
Hi @dokken,
Thanks for the help, I updated my code. Unfortunately I am still running out of memory. I should have specified earlier but I typically have been running out of memory at time step 1 and not at later time steps. Here is my updated code that I am still having trouble with:
L=L_1+L_2+L_3+L_4
t_i=2*dt
################ Solver set-up
#prm["newton_solver"]["relaxation_parameter"] = 1.0
#prm["newton_solver"]["linear_solver"] = "bicgstab"
#prm["newton_solver"]["preconditioner"] = "icc"
################## Loop over Time
while(t_i<Time):
   t_i+=dt
   print(t_i)
   solver.solve()
   u_1.assign(u_2)
   u_2.assign(u_3)
   u_3.assign(_u)
   p_1.assign(p_2)
   p_2.assign(p_3)
   p_3.assign(_p)
   lg_n=_lg
   if (count > 0):
   count = count + 1
quit()
Were you able to cure this issue? I am running into something similar with a moderately sized (128x128x128) elasticity problem.
@jzcrow Unfortunately, I never figured out a resolution in the legacy FEniCS. However, I reimplemented my solver in FEniCSX and it worked fine there. Perhaps try that if you haven’t yet.
Alright thank you. Wasn’t the answer I was hoping for, but it is what it is lol
