Extremely slow solver when using coordinate transform
I am trying to introduce spatial transform in a domain. This causes the solver to become extremely slow in compiling or assembly stage. I will appreciate if someone knowledgeable could help me understand how to possibly define the problem so as to avoid it.
Below is an MWE executed in dolfinx 0.8 installed in WSL through conda:
import dolfinx, gmsh, ufl, mpi4py, time
from dolfinx.io import gmshio
def magnetic_potential_model(mesh, ct, ft, space_transform=False):
    # gmsh domain tags, by visible inspection
    magnet_tag, shell_tag, vacuum_tag = 1, 2, 3
    Omega = dolfinx.fem.functionspace(mesh, ("CG", fem_degree))
    u, v = ufl.TrialFunction(Omega), ufl.TestFunction(Omega)
    dx = ufl.Measure('dx', domain=mesh, subdomain_data=ct)
    F = ufl.dot(ufl.grad(u), ufl.grad(v))*dx((magnet_tag,vacuum_tag)) # whole domain except the outer shell
    # add remnanet flux
    F += -ufl.dot(ufl.as_vector((0, 1, 0)), ufl.grad(v))*dx(magnet_tag) # only inside the magnet
    if space_transform:
        x, y, z = ufl.SpatialCoordinate(mesh)
        r = ufl.sqrt(x**2 + y**2)
        grad_x = lambda u, jac, r_: (1/jac*x**2/r**2 + y**2/(r*r_))*u.dx(0) + (1/jac*x*y/r**2 - x*y/(r*r_))*u.dx(1)
        grad_y = lambda u, jac, r_: (1/jac*x*y/r**2 - x*y/(r*r_))*u.dx(0) + (x**2/(r*r_) + 1/jac*y**2/r**2)*u.dx(1)
        r0_ie = fov_r - t_shell
        # IE: polynomial stretching: r_ = r0 + exi**beta*L
        beta = 3
        alpha = 1000*t_shell
        exi = (r-r0_ie)/t_shell
        r_ = r0_ie + (exi**beta)*alpha
        jac = alpha*beta/t_shell*exi**(beta-1)
        # gradients in the layer
        grad_x_u = grad_x(u, jac, r_)
        grad_y_u = grad_y(u, jac, r_)
        grad_x_test = grad_x(v, jac, r_)
        grad_y_test = grad_y(v, jac, r_)
        grad_ie_trial = ufl.as_vector((grad_x_u, grad_y_u))
        grad_ie_test = ufl.as_vector((grad_x_test, grad_y_test))
        F += ufl.dot(grad_ie_trial, grad_ie_test)*jac*(r_/r)*dx(shell_tag)
        F += ufl.dot(ufl.grad(u), ufl.grad(v))*dx((shell_tag))
    a = ufl.lhs(F)
    L = ufl.rhs(F)
    boundary_facets = dolfinx.mesh.exterior_facet_indices(mesh.topology)
    boundary_dofs = dolfinx.fem.locate_dofs_topological(Omega, mesh.topology.dim-1, boundary_facets)
    u_dbc = dolfinx.fem.Function(Omega)
    u_dbc.x.array[:] = 0.0
    dbc = [dolfinx.fem.dirichletbc(u_dbc, boundary_dofs)]
    ## solve
    petsc_options={"ksp_type": "preonly", "pc_type": "lu", "pc_factor_mat_solver_type":"mumps"}
    linear_problem = LinearProblem(a, L, bcs = dbc, petsc_options=petsc_options)
    uh = linear_problem.solve()
    uh.x.scatter_forward()
    print("Solved for {} dofs. Min, max of the solved potential is {}, {}".format(uh.x.array.size, uh.x.array.min(), uh.x.array.max()))
    return uh
fov_r = 1
t_shell = 0.1
gdim = 3
fem_degree = 2
gmsh.option.setNumber("General.Terminal", 0)
gmsh.clear()
occ = gmsh.model.occ
mag = occ.add_box(-0.5, -0.25, -0.25, 1, 0.5, 0.5)
fov = occ.add_cylinder(0, 0, -0.5, 0, 0, 1, fov_r)
shell = occ.add_cylinder(0, 0, -0.5, 0, 0, 1, fov_r-t_shell)
frag, _ = occ.fragment([(gdim, fov)], [(gdim, mag), (gdim, shell)])
occ.synchronize()
all_doms = occ.get_entities(gdim)
for j, dom in enumerate(all_doms):
    gmsh.model.addPhysicalGroup(dom[0], [dom[1]], j + 1)  # create the main group/node
all_edges = gmsh.model.getEntities(gdim - 1)
for j, edge in enumerate(all_edges):
    gmsh.model.addPhysicalGroup(edge[0], [edge[1]], edge[1])  # create the main group/node
gmsh.model.mesh.refine()
# gmsh.fltk.run()
mesh, ct, ft = gmshio.model_to_mesh(gmsh.model, mpi4py.MPI.COMM_WORLD, 0, gdim)
start_time = time.time()
uh = magnetic_potential_model(mesh, ct, ft, space_transform=False)
print("Solve time without spatial transform: {}".format(time.time()-start_time))
uh_st = magnetic_potential_model(mesh, ct, ft, space_transform=True)
print("Solve time with spatial transform: {}".format(time.time()-start_time))
This leads to the following output on my device:
Solve time without spatial transform: 3.008222818374634s
Solve time with spatial transform: 124.13119649887085s
I may be reading the gmsh part wrong, but it seems to me that your domain includes the origin of the (x, y) plane. In that case, your transformation which has 1/r becomes singular.
Thanks a lot for your feedback!
The origin x=y=z=0 should be inside the smaller box (magnet) which is located at the origin. The spatial transform is for the outer shell where r>0. The domain tags were found visibly and I did notice in the past that they changed at least for edges/facets from one execution environment (version?) to another. I do not have a quick idea at the moment to make them permanent but at least I have edited the code above by adding variable names to make the intent clear to the reader.
The problem is the automatic estimation of the quadrature degree for your integrals.
Setting:
    dx = ufl.Measure(
        "dx",
        domain=mesh,
        subdomain_data=ct,
        metadata={"quadrature_degree": 8},
you get:
Solved for 16433 dofs. Min, max of the solved potential is -0.11544615271350633, 0.1157284028550102
Solve time without spatial transform: 1.4832050800323486
Solved for 16433 dofs. Min, max of the solved potential is -0.11654400959639583, 0.11686836195473972
Solve time with spatial transform: 1.1220996379852295
This is because the estimated quadrature degree is 62, as you can see with:
    from ufl.algorithms.compute_form_data import estimate_total_polynomial_degree
    print(
        f"{space_transform=} , {estimate_total_polynomial_degree(a)}, {estimate_total_polynomial_degree(L)}"
yielding
space_transform=False , 2, 1
Solve time without spatial transform: 0.6003363132476807
space_transform=True , 62, 1
Solve time with spatial transform: 0.6055417060852051
You can set it up to about 15 without any huge performance hit, as there are special quadrature rules for such cases, see: basix/cpp/basix/quadrature.cpp at main · FEniCS/basix · GitHub
For my understanding, is it a corner case in the automatic determination algorithm or it is somehow merited by the variational form I have in at least some situations?
It is due to all the polynomials and fractions in
