FacetNormals for Internal Surface Pressure
Hey All,
Was just reading the following: Wrong FacetNormal vector on internal boundaries
I am trying to implement the solution to see if it can fix my inflation test on the inner boundary of an annulus. The code uses a gmsh generated annulus with full incompressibility and Mooney-Rivlin. It worked fine for axial extension but trying to implement pressure has been an issue which brought me to learn about the facetNormals
from dolfinx import mesh, fem, io, default_scalar_type
from numpy import linalg as LNG
import argparse
# += Parameters
MESH_DIM = 3
LEN_Z = 1
R0 = 1
R1 = 1.5
P_INNER = 0.15
P_OUTER = 0
def gen_annulus(test_name, test_type, test_order, refine_check):
    # Initialise and begin geometry
    gmsh.model.add(test_name)
    # += Setup base of annulus, surface
    innerCircle = gmsh.model.occ.addCircle(x=0, y=0, z=0, r=R0, tag=1)
    outerCircle = gmsh.model.occ.addCircle(x=0, y=0, z=0, r=R1, tag=2)
    innerCircleCurve = gmsh.model.occ.addCurveLoop([innerCircle], 1)
    outerCircleCurve = gmsh.model.occ.addCurveLoop([outerCircle], 2)
    baseSurface = gmsh.model.occ.addPlaneSurface(wireTags=[outerCircle, innerCircle], tag=1)
    # += Synchronize and add physical group
    basePhysicalGroup = gmsh.model.addPhysicalGroup(dim=2, tags=[baseSurface], tag=100, name="Annulus Base Surface")
    gmsh.model.occ.synchronize()
    # += Extrude from geometry
    baseExtrusion = gmsh.model.occ.extrude(dimTags=[(2, baseSurface)], dx=0, dy=0, dz=LEN_Z)
    # += Create Physical Group on volume
    volumePhysicalGroup = gmsh.model.addPhysicalGroup(3, [baseExtrusion[1][1]], tag=1000, name="Internal Volume")
    innerPhysicalGroup = gmsh.model.addPhysicalGroup(2, [baseExtrusion[3][1]], tag =101, name="Inner Surface")
    outerPhysicalGroup = gmsh.model.addPhysicalGroup(2, [baseExtrusion[2][1]], tag =102, name="Outer Surface")
    topPhysicalGroup = gmsh.model.addPhysicalGroup(2, [baseExtrusion[0][1]], tag =103, name="Annulus Top Surface")
    # += Create Mesh
    gmsh.model.mesh.generate(MESH_DIM)
    if refine_check == "True":
        gmsh.model.mesh.refine()
    gmsh.model.mesh.setOrder(test_order)
    # += Write File
    gmsh.write("gmsh_msh/" + test_name + ".msh")
    gmsh.finalize()
def main(test_name, test_type, test_order, refine_check):
    # Mesh Generation
    # Load Domain & Interpolation
    domain, _, facet_markers = io.gmshio.read_from_msh("gmsh_msh/" + test_name + ".msh", MPI.COMM_WORLD, 0, gdim=MESH_DIM)
    tdim = domain.topology.dim
    fdim = tdim - 1
    domain.topology.create_entities(fdim)
    domain.topology.create_connectivity(tdim, fdim)
    VE2 = ufl.VectorElement("Lagrange", domain.ufl_cell(), degree=2)
    FE1 = ufl.FiniteElement("Lagrange", domain.ufl_cell(), degree=1)
    W = fem.FunctionSpace(domain, ufl.MixedElement([VE2, FE1]))
    w = fem.Function(W)
    # += Collapse into geometric space
    V, _ = W.sub(0).collapse()
    Vx, _ = V.sub(0).collapse()
    Vy, _ = V.sub(1).collapse()
    Vz, _ = V.sub(2).collapse()
    # Determine Boundaries
    #    (1): Base
    base_facets = mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(x[2], 0))
    #    (2): Top
    top_facets = mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(x[2], LEN_Z))
    #    (3): Inner Cylinder Surface
    def inner_bound(x):
        return np.isclose(np.sqrt(x[0]**2+x[1]**2), R0)
    inner_facets = mesh.locate_entities_boundary(domain, fdim, inner_bound)
    #    (4): Outer Cylinder Surface
    def outer_bound(x):
        return np.isclose(np.sqrt(x[0]**2+x[1]**2), R1)
    outer_facets = mesh.locate_entities_boundary(domain, fdim, outer_bound)
    # += Collate Marked boundaries
    marked_facets = np.hstack([base_facets, top_facets, inner_facets, outer_facets])
    # += Assign boundaries IDs
    marked_values = np.hstack([
        np.full_like(base_facets, 1),
        np.full_like(top_facets, 2),
        np.full_like(inner_facets, 3),
        np.full_like(outer_facets, 4)
    # += Sort and assign
    facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
    # Boundary Conditions
    # += Base Dirichlet BCs but broken per subspace
    #    (1): Interpolation space
    #    (2): Internal function to determine if on z = 0
    base_dofs_z = fem.locate_dofs_topological((W.sub(0).sub(2), Vz), facet_tag.dim, facet_tag.find(1))
    # += Set Dirichlet BCs of (1) on (2)
    u0_bc = fem.Function(Vz)
    u0 = lambda x: np.full(x.shape[1], default_scalar_type(0.0))
    u0_bc.interpolate(u0)
    bc_base_z = fem.dirichletbc(u0_bc, base_dofs_z, W.sub(0).sub(2))
    # += Top Dirichlet BCs
    top_dofs_z = fem.locate_dofs_topological((W.sub(0).sub(2), Vz), facet_tag.dim, facet_tag.find(2))
    # # += Set Dirichlet BCs of (1) on (2)
    u1_bc = fem.Function(Vz)
    u1 = lambda x: np.full(x.shape[1], default_scalar_type(0.0))
    u1_bc.interpolate(u1)
    bc_top_z = fem.dirichletbc(u1_bc, top_dofs_z, W.sub(0).sub(2))
    # += Concatenate boundaries
    bc = [bc_base_z, bc_top_z]
    # # Pressure Setup
    p_inner = fem.Constant(domain, default_scalar_type(P_INNER))
    p_outer = fem.Constant(domain, default_scalar_type(P_OUTER))
    n = ufl.FacetNormal(domain)
    ## START OF SOLUTION [Wrong FacetNormal vector on internal boundaries]
    cell_map = domain.topology.index_map(tdim)
    num_cells = cell_map.size_local + cell_map.num_ghosts
    cell_values = np.ones(num_cells, dtype=np.int32)
    cell_values[mesh.locate_entities(
            domain, tdim, inner_bound
    )] = 3
    cell_tag = mesh.meshtags(
        domain, tdim,
        np.arange(num_cells, dtype=np.int32), cell_values
    facet_map = domain.topology.index_map(fdim)
    num_facets = facet_map.size_local + facet_map.num_ghosts
    facets_to_integrate = facet_tag.find(3)
    f_to_c = domain.topology.connectivity(fdim, tdim)
    c_to_f = domain.topology.connectivity(tdim, fdim)
    integration_entities = []
    for i, facet in enumerate(facets_to_integrate):
        if facet >= facet_map.size_local:
            continue
        cells = f_to_c.links(facet)
        marked_cells = cell_tag.values[cells]
        correct_cell = np.flatnonzero(marked_cells == 2)
        assert len(correct_cell) == 1
        local_facets = c_to_f.links(cells[correct_cell[0]])
        local_index = np.flatnonzero(local_facets == facet)
        assert len(local_index) == 1
        integration_entities.append(cells[correct_cell[0]])
        integration_entities.append(local_index[0])
    ## END OF SOLUTION [Wrong FacetNormal vector on internal boundaries]
    # Setup Parameteres for Variational Equation
    # += Test and Trial Functions
    v, q = ufl.TestFunctions(W)
    u, p = ufl.split(w)
    # # += Identity Tensor
    I = ufl.variable(ufl.Identity(MESH_DIM))
    # += Deformation Gradient Tensor
    #    F = ∂u/∂X + I
    F = ufl.variable(I + ufl.grad(u))
    # += Right Cauchy-Green Tensor
    C = ufl.variable(F.T * F)
    # += Invariants
    #    (1): λ1^2 + λ2^2 + λ3^2; tr(C)
    Ic = ufl.variable(ufl.tr(C))
    #    (2): λ1^2*λ2^2 + λ2^2*λ3^2 + λ3^2*λ1^2; 0.5*[(tr(C)^2 - tr(C^2)]
    IIc = ufl.variable((Ic**2 - ufl.inner(C,C))/2)
    #    (3): λ1^2*λ2^2*λ3^2; det(C) = J^2
    J = ufl.variable(ufl.det(F))
    # IIIc = ufl.variable(ufl.det(C))
    # += Material Parameters
    c1 = 2
    c2 = 6
    # += Mooney-Rivlin Strain Energy Density Function
    psi = c1 * (Ic - 3) + c2 *(IIc - 3)
    # Terms
    gamma1 = ufl.diff(psi, Ic) + Ic * ufl.diff(psi, IIc)
    gamma2 = -ufl.diff(psi, IIc)
    # += First Piola Stress
    firstPK = 2 * F * (gamma1*I + gamma2*C) + p * J * ufl.inv(F).T
    # Setup Variational Problem Solver
    # += Gaussian Quadrature
    # += Domains of integration
    ds = ufl.Measure('ds', domain=domain, subdomain_data=[
                 (3, np.asarray(integration_entities, dtype=np.int32))], metadata=metadata)
    # += Residual Equation (Variational, for solving)
    R = ufl.inner(ufl.grad(v), firstPK) * dx + q * (J - 1) * dx - p_inner * J * ufl.dot(ufl.inv(F).T * n, v) * ds(3)
    problem = NonlinearProblem(R, w, bc)
    solver = NewtonSolver(domain.comm, problem)
    # += Tolerances for convergence
    solver.atol = 1e-8
    solver.rtol = 1e-8
    # += Convergence criteria
    num_its, converged = solver.solve(w)
    u_sol, p_sol = w.split()
    if converged:
        print(f"Converged in {num_its} iterations.")
        print(f"Not converged after {num_its} iterations.")
    # ParaView export
    with io.VTXWriter(MPI.COMM_WORLD, test_name + ".bp", w.sub(0).collapse(), engine="BP4") as vtx:
        vtx.write(0.0)
        vtx.close()
if __name__ == '__main__':
    # +==+ Intake Arguments
    argparser = argparse.ArgumentParser("FEniCSz Program for Passive Annulus Inflation")
    argparser.add_argument("test_ID")
    argparser.add_argument("gen_type")
    argparser.add_argument("gen_order", type=int)
    argparser.add_argument("refinement", type=bool)
    args = argparser.parse_args()
    test_name = args.test_ID
    test_type = args.gen_type
    test_order = args.gen_order
    refine_check = args.refinement
    # +==+ Feed Main()
    # python annulus_inflation.py quick_check Tetra 2 False
(this can be run as $python file_name.py TEST Tetra 2 False)
If anyone could just explain how to properly implement pressure on the internal boundary that would be super.
Thank you :slight_smile:
Hi. Regular user here. You may want to look at the plasticity example from NewFrac (didn’t read your code).
Thank you!! I’ll give it a look :slight_smile:
Edit: This ended up being perfect!
