Hi all,
in Fenics, I used to be able to compute the value of a function at vertices using compute_vertex_values().
I noticed that Fenicsx allows running f.x.array, but this returns the value of the function at all degrees of freedom, as opposed to just the mesh vertices. This can be different if the function degree is greater than 1.
For a scalar function defined on a 1D domain (e.g. a radial domain), I would like to be able to use plt.plot on mesh.geometry.x and f.compute_vertex_values(), if it existed. Is there a Fenicsx equivalent of compute_vertex_values?
You can consider, as an example, this MWE:
import dolfinx as d
msh = d.mesh.create_interval( comm=MPI.COMM_WORLD,
nx=100, points=(0, 10) )
def profile( r ):
return 1 / ( np.exp( ( r[0] - 1) / 0.2 ) + 1. )
Pn = ufl.FiniteElement( 'CG', msh.ufl_cell(), 4 )
S = d.fem.FunctionSpace( msh, Pn )
f = d.fem.Function(S)
f.interpolate(profile)
plt.plot( msh.geometry.x[:,0], f.x.array )
Thanks!
