Fenicsx method, which is equaivalent to dofmap().dofs() in fenics
Hi fenics community,
I need to port some python code from fenics 2019 to fenicsx 0.5.1. Im having a hard time finding a method in fenicsx, which gives me a output like FunctionSpace.dofmap().dofs() in fenics. Could you give me a hint? Here is a MWE in fenics:
mesh = UnitSquareMesh(3,3)
elementShape = triangle
FE_vector=VectorElement('CG', elementShape, 2)
FE_scalar=FiniteElement('CG', elementShape, 2)
FE_scalar_p=FiniteElement('CG', elementShape, 2)
MixedList = [FE_vector, FE_scalar, FE_scalar_p]
element = MixedElement(MixedList)
VMixed = FunctionSpace(mesh,element)
dofs = VMixed.dofmap().dofs()
print(dofs)
Thanks alot in Advance,
Tobias
Consider
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 3, 3)
elementShape = ufl.triangle
FE_vector = ufl.VectorElement('CG', elementShape, 2)
FE_scalar = ufl.FiniteElement('CG', elementShape, 2)
FE_scalar_p = ufl.FiniteElement('CG', elementShape, 2)
element = ufl.MixedElement(MixedList)
VMixed = dolfinx.fem.FunctionSpace(mesh, element)
dofs = VMixed.dofmap.list.array
print(dofs)
Hi dokken,
thanks for your response.
I have a following question about your solution:
The shapes of the dofs-array in fenics and fenicsx differ.
In fenics i get:
While in fenicsx:
Screenshot from 2022-08-29 11-33-56
In fenics the dofs array has a length of 196, while in fenicsx it has the size 432.
How can i only get the values, which correspond to the values i get in fenics?
Thank you for your Help,
Tobias
The old dofs gives you the global indices of all dofs owned by the current process, i.e.
from mpi4py import MPI as _MPI
mesh = UnitSquareMesh(3, 3)
FE_vector = VectorElement('CG', elementShape, 2)
FE_scalar = FiniteElement('CG', elementShape, 2)
FE_scalar_p = FiniteElement('CG', elementShape, 2)
VMixed = FunctionSpace(mesh, element)
print(MPI.comm_world.allreduce(len(dofs), op=_MPI.SUM))
print(dofs)
executed with 3 MPI processes yields
96
[0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67]
196
[68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129]
196
[130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195]
In DOLFINx, you can get something similar by calling:
from IPython import embed
local_range = VMixed.dofmap.index_map.local_range
dofs = np.arange(*local_range)
print(MPI.COMM_WORLD.rank, dofs)
Thanks, that solved my Problem.
Hello! I’ve been translating a piece of code I had in fenics to dolfinx and I encountered some problems with the .dofmap().dofs() translation. The thing is that when using ‘VectorElement(‘Real’, mesh.ufl_cell(), 0, 3)’, fenics gives me 3 dof when calling V.sub(0).dofmap().dofs(), but dolfinx gives 0 when calling the analogous ‘V.sub(0).dofmap.list.array’. Is it possible to obtain the same output with dolfinx?
See Get velocity field at a boundary - #2 by dokken
But please that real elements are not supported in DOLFINX yet
