(fenicsx) subdomain integral fails depending on form of meshtags
The code below does an integral over a subdomain defined by a MeshTags instance. When the mesh tags are generated using a constant, the integration works fine. When the mesh tags are generated using array data, the integration fails with a TypeError in forms.py. Below is a short script demonstrating this. This is on mac Catalina (10.15.7) installed via conda, dolfinx version 0.5.0.
"""Subdomain Integration Example"""
from dolfinx import fem, mesh
from dolfinx.fem import assemble_scalar, form
# Create Mesh
msh = mesh.create_rectangle(
    comm=MPI.COMM_WORLD,
    points=((0.0, 0.0), (2.0, 1.0)),
    n=(30, 20),
    cell_type=mesh.CellType.triangle,
bdim = (cdim := msh.topology.dim) - 1
# Create a function to integrate
def f_(x):
    return x[0, :] - 3 * x[1, :]
V = fem.FunctionSpace(msh, ("Lagrange", 1))
f = fem.Function(V)
f.interpolate(f_)
# Volume Integration
cells_bot = dolfinx.mesh.locate_entities(
    msh, cdim, lambda x: x[1, :] < 0.5 + 1e-4
mtbot = dolfinx.mesh.meshtags(msh, cdim, cells_bot, 1)
dx1 = ufl.Measure("dx", subdomain_data=mtbot)
int_f1 = msh.comm.allreduce(assemble_scalar(form(f * dx1(1))), op=MPI.SUM)
print(f"integral of f over subdomain 1: {np.array(int_f1)}")
# Now try using array data instead of a constant
tag_data = np.ones(len(cells_bot), dtype=int)
mtbot2 = dolfinx.mesh.meshtags(msh, cdim, cells_bot, tag_data)
dx2 = ufl.Measure("dx", subdomain_data=mtbot2)
int_f1 = msh.comm.allreduce(assemble_scalar(form(f * dx2(1))), op=MPI.SUM)
Here is the output when running it:
(fenicsx)  1206. python example_integration.py
integral of f over subdomain 1: 0.2500000000000002
  File "/Users/deboyce/Projects/fenicsX/run/learn/example_integration.py", line 44, in <module>
  File "/Users/deboyce/miniconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 166, in form
    return _create_form(form)
  File "/Users/deboyce/miniconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 161, in _create_form
    return _form(form)
  File "/Users/deboyce/miniconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 155, in _form
    return formcls(ufcx_form, V, coeffs, constants, subdomains, mesh, module.ffi, code)
  File "/Users/deboyce/miniconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 51, in __init__
    super().__init__(ffi.cast("uintptr_t", ffi.addressof(self._ufcx_form)),
TypeError: __init__(): incompatible constructor arguments. The following argument types are supported:
    1. dolfinx.cpp.fem.Form_float64(spaces: List[dolfinx::fem::FunctionSpace], integrals: Dict[dolfinx::fem::IntegralType, Tuple[List[Tuple[int, object]], dolfinx.cpp.mesh.MeshTags_int32]], coefficients: List[dolfinx.cpp.fem.Function_float64], constants: List[dolfinx.cpp.fem.Constant_float64], need_permutation_data: bool, mesh: dolfinx.cpp.mesh.Mesh = None)
    2. dolfinx.cpp.fem.Form_float64(form: int, spaces: List[dolfinx::fem::FunctionSpace], coefficients: List[dolfinx.cpp.fem.Function_float64], constants: List[dolfinx.cpp.fem.Constant_float64], subdomains: Dict[dolfinx::fem::IntegralType, dolfinx.cpp.mesh.MeshTags_int32], mesh: dolfinx.cpp.mesh.Mesh)
Invoked with: <cdata 'uintptr_t' 6342831776>, [], [<dolfinx.cpp.fem.Function_float64 object at 0x17968a5b0>], [], {<IntegralType.cell: 0>: <dolfinx.mesh.MeshTagsMetaClass object at 0x179fe24d0>, <IntegralType.exterior_facet: 1>: None, <IntegralType.interior_facet: 2>: None, <IntegralType.vertex: 3>: None}, <dolfinx.mesh.Mesh object at 0x17987e700>
(fenicsx)  1207.
Try using dtype=np.int32 or np.intc, as this is what form supports.
See for instance
and
Thanks! This solves my issue.
