Flux computed and interpolated into deg 0 space leads to an error
I have a code very similar to the one I posted here.
At some point, I compute a heat flux as:
# Heat flux.
Q = functionspace(mesh, ("DG", 0, (mesh.geometry.dim,)))
q = Function(Q)
flux_calculator = Expression(-κ * grad(temp), Q.element.interpolation_points())
q.interpolate(flux_calculator)
Where temp comes from:
# Define ME function space
deg = 1
el = FiniteElement("CG", mesh.ufl_cell(), deg)
mel = MixedElement([el, el])
ME = FunctionSpace(mesh, mel)
u, v = TestFunction(ME)
TempVolt = Function(ME)
temp, volt = split(TempVolt)
As far as I understand, the above code should work. However, I get an error when I save the heat flux field with:
with VTXWriter(MPI.COMM_WORLD, "results/heat_flux.bp", [out2], engine="BP4") as vtx:
    vtx.write(0.0)
The traceback is:
  File "/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/io/utils.py", line 91, in __init__
    comm, filename, output._cpp_object, engine)  # type: ignore[union-attr]
AttributeError: 'list' object has no attribute '_cpp_object'
  File "/root/shared/TE_simulation/BN_example.py", line 261, in <module>
  File "/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/io/utils.py", line 94, in __init__
    self._cpp_object = _vtxwriter(comm, filename, _extract_cpp_functions(
RuntimeError: VTK does not support cell-wise fields. See https://gitlab.kitware.com/vtk/vtk/-/issues/18458.
One way to bypass this problem is to pick a higher degree for the heat flux (which I don’t think make sense). It doesn’t make sense because the temp field is CG 1st degree, so linear. The heat flux involves a spatial derivative of it, so it should be cell-wise constant, and DG (because I picked it this way). Therefore, picking a deg == 1 is not correct. But this fixes this error… What is going on?
I also got strange warnings when I played around with the degrees of both temp and the heat flux, such as:
libffcx_forms_6d805b63b192afc755cfe28f475c8e3fdb08abc5.c: In function ‘tabulate_tensor_integral_888714572bbf59b20e226d6f0e3ddb633201b4cc’:
libffcx_forms_6d805b63b192afc755cfe28f475c8e3fdb08abc5.c:855:21: warning: unused variable ‘weights_083’ [-Wunused-variable]
  855 | static const double weights_083[1] = {0.5};
At top level:
libffcx_forms_6d805b63b192afc755cfe28f475c8e3fdb08abc5.c:855:21: warning: ‘weights_083’ defined but not used [-Wunused-const-variable=]
libffcx_forms_1bccbd7aa7954a36b415fefd115e419ef5f34d0f.c: In function ‘tabulate_tensor_integral_d8173cb13faee8cb1f81d5db877573e52f4a8903’:
libffcx_forms_1bccbd7aa7954a36b415fefd115e419ef5f34d0f.c:855:21: warning: unused variable ‘weights_083’ [-Wunused-variable]
although I don’t get those with the code above. I do not remember which combination of degrees yielded these warnings.
There is already a feature request on this Add support for cell-wise data in ADIOS2 output · Issue #2720 · FEniCS/dolfinx · GitHub
Note that the error is not in the interpolation, but in writing to file.
If you wish to export to file you can try reinterpolating again the DG0 field into a DG1 function and export to file.
PR added for DG-0 support in VTXWriter (which would work with Paraview >= 5.12) at: Support DG-0 functions in VTXWriter by jorgensd · Pull Request #3107 · FEniCS/dolfinx · GitHub
