I am using the dolfin_dg library (https://bitbucket.org/nate-sime/dolfin_dg/src/master/) to solve the convection diffusion equation
\mathbf{b} \cdot \nabla t - \kappa \nabla^2 t = 0
The domain is a simple unit square. The advection field is a horizontal vector \mathbf{b} = (1.0). There are two Dirichlet BC in the lower left side of the domain. Zero outflow in the top and bottom and I’d like to have free outflow in the right hand side. What I imagine is having very little diffusion and the advection field transporting the Dirichlet BC from the left to the right uniformly. What happens now though when I impose zero flow everywhere is that there is some sort of accumulation of the field t in the upper side instead of leaving freely. This is because I am marking all the boundary edges in
CompiledSubdomain("on_boundary").mark(inlets_mshfunc, OUTFLOW)
If I change it to
CompiledSubdomain("on_boundary && !(x[0] > (1.0 - DOLFIN_EPS)").mark(inlets_mshfunc, OUTFLOW)
The right side is not marked, but the problem does not converge. I think I might be missing some fundamental concept on how to pose boundary conditions on hyperbolic problems
Here is the code
from dolfin_dg import *
__author__ = 'njcs4'
parameters['form_compiler']["cpp_optimize"] = True
parameters['form_compiler']["optimize"] = True
parameters['form_compiler']['representation'] = 'uflacs'
parameters["ghost_mode"] = "shared_facet"
ele_n = 100
p = 1
mesh = UnitSquareMesh(ele_n, ele_n, 'left/right')
V = FunctionSpace(mesh, 'DG', p)
class Inlet1(SubDomain):
return x[0] < DOLFIN_EPS and between(x[1], (0.2, 0.4))
class Inlet2(SubDomain):
return x[0] < DOLFIN_EPS and between(x[1], (0.0, 0.2))
inlets_mshfunc = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
inlets_mshfunc.set_all(0)
INLET1, INLET2, OUTFLOW = 1, 3, 30
CompiledSubDomain("on_boundary && !(x[0] > (1.0 - DOLFIN_EPS))").mark(inlets_mshfunc, OUTFLOW)
inlets = Inlet1()
inlets.mark(inlets_mshfunc, INLET1)
inlets = Inlet2()
inlets.mark(inlets_mshfunc, INLET2)
ds = Measure('ds', domain=mesh, subdomain_data=inlets_mshfunc)
gD1 = Constant(100)
gD2 = Constant(1)
gN = Constant(0.0)
b = Constant((10, 0))
f = Constant(0.0)
def F_c(u):
return b*u
H = LocalLaxFriedrichs(lambda u, n: dot(b, n))
kappa = 1e-8
def F_v(u, grad_u):
return kappa*grad_u
bcs = [DGNeumannBC(ds(OUTFLOW), gN),
DGDirichletBC(ds(INLET1), gD1),
DGDirichletBC(ds(INLET2), gD2)]
ho = HyperbolicOperator(mesh, V, bcs, F_c, H)
eo = EllipticOperator(mesh, V, bcs, F_v)
residual = ho.generate_fem_formulation(u, v) \
+ eo.generate_fem_formulation(u, v) \
- f*v*dx
du = TrialFunction(V)
J = derivative(residual, u, du)
solve(residual == 0, u, [], J=J, solver_parameters={"newton_solver" : {"absolute_tolerance": 1e-6}})
File("dolfin_dg_adv_diff.pvd") << u
