From 0.9 to 0.10: Issues at custom SNES Interface for blocked problems
I am on DOLFINx version: 0.10.0.post2 based on GIT commit: 601b058a51f6a8f3cea11811048283f00855e18d
Porting from 0.9 to 0.10 was successful except for my custom SNES solver and I am out of ideas. I have a custom SNES solver because my bilinear forms are assembled block-wise, i.e.
self.U_gobal = ufl.MixedFunctionSpace(V_p1, V_v1, V_p2, V_v2)  # Proper function spaces
self.U = [V_p1, V_v1, V_p2, V_v2]
p1 = fem.Function(self.U[0])
v1 = fem.Function(self.U[1])
p2 = fem.Function(self.U[2])
v2 = fem.Function(self.U[3])
q1, u1, q2, u2 = ufl.TestFunctions(self.U_global)
res = ufl.inner(v1, u1) * dx(1)
res += ufl.inner(ufl.dot(v1, ufl.grad(v1)), u1) * dx(1)
res += ufl.inner(ufl.grad(v2), ufl.grad(u2)) * dx(2)
, and I couldn’t get it to work with the new fem.petsc.NonlinearProblem, which seems to only work for MixedElements (which I do not use).
Anyways, here is the code from my custom SNES solver:
import typing
import petsc4py
# Define the Navier-Stokes problem class
class NavierStokesProblem:
    """Defines a nonlinear problem for SNES solver"""
    def __init__(
        self, F: list[dolfinx.fem.Form], J: list[list[dolfinx.fem.Form]],
        solutions: list[dolfinx.fem.Function],
        bcs: list[dolfinx.fem.DirichletBC],
        P: typing.Optional[list[list[ufl.Form]]] = None
    ) -> None:
        self._F = F
        self._J = J
        self._solutions = solutions
        self._bcs = bcs
        self._P = P
        #self._obj_vec = dolfinx.fem.petsc.create_vector_block(F) # v0.9
        self._obj_vec = dolfinx.fem.petsc.create_vector(dolfinx.fem.extract_function_spaces(F), kind=PETSc.Vec.Type.MPI) # v0.10
    def update_solutions(self, x: petsc4py.PETSc.Vec) -> None:
        """Update `self._solutions` with the data from `x`"""
        maps = [
            (si.function_space.dofmap.index_map, si.function_space.dofmap.index_map_bs)
            for si in self._solutions
        local_x = dolfinx.cpp.la.petsc.get_local_vectors(x, maps)
        for lx, s in zip(local_x, self._solutions):
            s.x.array[:] = lx
            s.x.scatter_forward()
    def obj(self, snes: petsc4py.PETSc.SNES, x: petsc4py.PETSc.Vec) -> np.float64:
        """Compute the norm of the residual"""
        self.F(snes, x, self._obj_vec)
        return self._obj_vec.norm()
    def F(self, snes: petsc4py.PETSc.SNES, x: petsc4py.PETSc.Vec, F_vec: petsc4py.PETSc.Vec) -> None:
        """Assemble the residual"""
        self.update_solutions(x)
        with F_vec.localForm() as F_vec_local:
            F_vec_local.set(0.0)
        # dolfinx.fem.petsc.assemble_vector_block(F_vec, self._F, self._J, self._bcs, x0=x, alpha=-1.0) # v0.9
        # From here v0.10
        dolfinx.fem.petsc.assemble_vector(F_vec, self._F)
        bcs1 = dolfinx.fem.bcs_by_block(
            dolfinx.fem.extract_function_spaces(self._J, 1),
            self._bcs,
        dolfinx.fem.petsc.apply_lifting(F_vec, self._J, bcs=bcs1, x0=x, alpha=-1)
        F_vec.ghostUpdate(
            addv=PETSc.InsertMode.ADD,
            mode=PETSc.ScatterMode.REVERSE,
        bcs0 = dolfinx.fem.bcs_by_block(
            dolfinx.fem.extract_function_spaces(self._F),
            self._bcs,
        dolfinx.fem.petsc.set_bc(F_vec, bcs0)
        # F_vec.ghostUpdate(PETSc.InsertMode.INSERT_VALUES, PETSc.ScatterMode.FORWARD) # v0.9
    def J(self, snes: petsc4py.PETSc.SNES, x: petsc4py.PETSc.Vec, J_mat: petsc4py.PETSc.Mat, P_mat: petsc4py.PETSc.Mat) -> None:
        """Assemble the Jacobian matrix"""
        J_mat.zeroEntries()
        # dolfinx.fem.petsc.assemble_matrix_block(J_mat, self._J, self._bcs) # v0.9
        dolfinx.fem.petsc.assemble_matrix(J_mat, self._J, self._bcs, diag=1.0) #v0.10
        J_mat.assemble()
        if self._P is not None:
            P_mat.zeroEntries()
            dolfinx.fem.petsc.assemble_matrix(P_mat, self._P, self._bcs, diag=1.0)
            P_mat.assemble()
def solve_nonlinear(
    sols: list[dolfinx.fem.Function],
    trials,
    res: ufl.Form,
    bc: list[dolfinx.fem.DirichletBC],
    entitymaps,
    tau_abs: float = 1e-3,
    tau_rel: float = 0.05
) -> dict:
    jac = ufl.derivative(res, sols[0], trials[0]) + ufl.derivative(res, sols[1], trials[1]) + ufl.derivative(res, sols[2], trials[2]) + ufl.derivative(res, sols[3], trials[3])
    F = dolfinx.fem.form(ufl.extract_blocks(res),entity_maps=entitymaps)
    J = dolfinx.fem.form(ufl.extract_blocks(jac),entity_maps=entitymaps)
    # Create the problem instance
    problem = NavierStokesProblem(F, J, sols, bc)
    # v0.9
    #jac = ufl.derivative(res, sols[0], trials[0]) + ufl.derivative(res, sols[1], trials[1]) + ufl.derivative(res, sols[2], trials[2]) + ufl.derivative(res, sols[3], trials[3])
    #F = dolfinx.fem.form(ufl.extract_blocks(res),entity_maps=entitymaps)
    #J = dolfinx.fem.form(ufl.extract_blocks(jac),entity_maps=entitymaps)
    # v0.10
    F_vec = dolfinx.fem.petsc.create_vector(dolfinx.fem.extract_function_spaces(problem._F), kind=PETSc.Vec.Type.MPI)
    J_mat = dolfinx.fem.petsc.create_matrix(problem._J)
    sol = dolfinx.fem.petsc.create_vector(dolfinx.fem.extract_function_spaces(problem._F), kind=PETSc.Vec.Type.MPI)
    sol.set(0.0)  # Initialize the solution vector (DIRTY HACK TODO!)
    # Compute local offsets for block vector (use size_local, not size_global)
    maps = [
        for si in sols
    local_offset_p1 = 0
    local_offset_v1 = maps[0][0].size_local * maps[0][1]
    local_offset_p2 = local_offset_v1 + maps[1][0].size_local * maps[1][1]
    local_offset_v2 = local_offset_p2 + maps[2][0].size_local * maps[2][1]
    # Initialize solution vector from current solutions
    sol.array[local_offset_p1:local_offset_v1] = sols[0].x.array[:local_offset_v1]
    sol.array[local_offset_v1:local_offset_p2] = sols[1].x.array[:local_offset_p2 - local_offset_v1]
    sol.array[local_offset_p2:local_offset_v2] = sols[2].x.array[:local_offset_v2 - local_offset_p2]
    sol.array[local_offset_v2:] = sols[3].x.array[:len(sol.array) - local_offset_v2]
    # Define a function to monitor iteration residuals
    def monitor_residual(snes, it, norm):
        if MPI.COMM_WORLD.rank == 0:
            print(it, norm)
    # Create SNES solver
    snes = petsc4py.PETSc.SNES().create(MPI.COMM_WORLD)
    snes.setTolerances(max_it=50, atol=1e-8)  # Increased max iterations for strict convergence
    snes.getKSP().setType("preonly")
    snes.getKSP().getPC().setType("lu")
    snes.getKSP().getPC().setFactorSolverType("mumps")
    opts = PETSc.Options()  # type: ignore
    #opts["mat_mumps_icntl_14"] = 80  # Increase MUMPS working memory
    opts["mat_mumps_icntl_24"] = 1  # Option to support solving a singular matrix (pressure nullspace)
    opts["mat_mumps_icntl_25"] = 0  # Option to support solving a singular matrix (pressure nullspace)
    opts["mat_mumps_cntl_3"] = 1e-6  # Threshold for null pivot detection
    opts["ksp_error_if_not_converged"] = 1
    snes.getKSP().setFromOptions()
    snes.setObjective(problem.obj)
    snes.setFunction(problem.F, F_vec)
    snes.setJacobian(problem.J, J=J_mat, P=None)
    snes.setMonitor(monitor_residual)
    snes.setConvergenceHistory()
    snes.solve(None, sol)
I changed the block-assemble routines properly as discussed in the release notes to v0.10, but for some reason I get the PETSc error: New nonzero at (44,44) caused a malloc. Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off this check
when calling apply_lifting() (but not for the first time).
Residual and Jacobi matrix are equivalent for both v0.9 and v0.10 versions, until the fuction F is called for the second time, when the error occurs. Essentially the SNES is printing out a single residual (same for 0.9 and 0.10), and then I run into the error.
As I said before, the v0.9 version worked, so I assume something was implicitly done that now has do be performed manually, like apply lifting and the boundary condition business. Can someone spot the error? The 0.9 - version is commented.
If a minimum example is required, I can try to assemble one, but it will be a big minimal example most likely.
Thank you very much!
That is not correct. The new NonlinearProblem class supports MixedFunctionSpace, as shown in: Coupling PDEs of multiple dimensions — FEniCS Workshop
You can also have a look at: dolfinx/python/test/unit/fem/test_petsc_nonlinear_assembler.py at v0.10.0.post5 · FEniCS/dolfinx · GitHub
which does the manually “blocking” of the terms, rather than using ufl.extract_blocks.
Thank you for your answer. While I could not fix my custom solver, I successfully employed the NonlinearProblem class with the help of your second link (I was missing the assingment of the solution fem.Functions to the snes solution vector x). This is even better then custom code, so I consider this fixed. I could re-use the exact code from the link, I only used ufl.extract_blocks on my residual instead of manually sorting my form. It even computed the correct jacobian.
