I would suggest using meshio, as shown in
To be slightly more specific, read in your vtk mesh (and data ) with meshio.read("filename.vtk"), then create a mesh with each of the data
mesh = meshio.read("filename.vtk")
# Code for extracting fibers from the read in mesh goes here
strain_data = ....
fibers_data = ....
sheets_data = ...
out_mesh = meshio.Mesh(points=mesh.points, cells={
cell_type: cells}, cell_data={"strain": [strain_data], "fibers":[fibers_data], ....]})
if prune_z:
out_mesh.prune_z_0()
out_mesh.write("mesh.xdmf")
which can be read into dolfin as
with XDMFFile("mesh.xdmf") as infile:
infile.read(mesh)
mvc = MeshValueCollection("size_t", mesh, mesh.topology().dim())
infile.read(mvc, "strain")
strain_func = cpp.mesh.MeshFunctionSizet(mesh, mvc) # boundary_parts
The code above is pseudo-code, as I do not use the vtk format, and do not have any minimal examples at hand to test the code. Therefore, this might require modification. Note that there are many posts about how to read in meshes and external data on this forum.
For your last question, how is your rho field defined? is it defined as a function of x,y,z? if so, use subdomain on the following form:
class rho0_boundary(SubDomain):
return on_boundary and near(rho(x), 0)
and use the subdomain as shown in: https://fenicsproject.org/olddocs/dolfin/latest/python/demos/subdomains-poisson/documentation.html?highlight=measure
