Hi everyone,
I’m working with a phase field theory and I get when I try to derivate the local free energy function. It’s derivatives are sscalar values but I get an error saying Expecting a tuple of Index objects to A^indices := as_tensor(A, indices). The error points to the definition of f and the calling of the interpolation function h. Appreciate any help I can get.
Cheers
Here is my code:
class InitialConditions(UserExpression):
def eval(self, values, x):
if near(x[0], lenght, DOLFIN_EPS) and near(x[1], height/2, DOLFIN_EPS):
values[0] = 0.0
values[0] = 1.0
values[1] = 1.0
def value_shape(self):
return (2,)
class CahnHilliardEquation(NonlinearProblem):
def __init__(self, a, L, bcs):
self.L = L
self.a = a
self.bcs = bcs
def F(self, b, x):
assemble(self.L, tensor=b)
for bc in self.bcs:
bc.apply(b, x)
def J(self, A, x):
assemble(self.a, tensor=A)
for bc in self.bcs:
bc.apply(A)
class Gamma(SubDomain):
return near(x[0], lenght, DOLFIN_EPS) and near(x[1], height/2, DOLFIN_EPS)
# Output file
file = File("Results_AC/output.pvd", "compressed")
# Model parameters
A = Constant(5.35e+07)
cse = Constant(1.43e+02)
cle = Constant(5.10e+00)
D = Constant(8.50e-10)
M = Constant( D / ( 2.0 *A ) )
L = Constant(2.00e+00)
w = Constant(1.03e+01)
alpha = Constant(0.601281)
# Interpolation function
def h(n):
return ( -2.0*n^3.0 + 3.0*n^2.0 )
# Double well potential
def g(n):
return ( n^2.0 * ( 1.0 - n )^2.0 )
lmbda = 1.0e02 # surface parameter
dt = 5.0e-06 # time step
theta = 1.0 # time stepping family, e.g. theta=1 -> backward Euler, theta=0.5 -> Crank-Nicolson
# Geometry parameters and mesh parameters
lenght = 6. # [mm]
height = 30. # [mm]
Nelem = 100 # [-]
# Form compiler options
# Create mesh and build function space
mesh = RectangleMesh(Point(0., 0.), Point(lenght, height), Nelem, Nelem*5, diagonal='right')
ME = FunctionSpace(mesh, P1*P1)
du = TrialFunction(ME)
q, v = TestFunctions(ME)
# Define functions
u = Function(ME) # current solution
u0 = Function(ME) # solution from previous converged step
# Split mixed functions
dc, dn = split(du)
c, n = split(u)
c0, n0 = split(u0)
# Create intial conditions and interpolate
u_init = InitialConditions(degree=1)
u.interpolate(u_init)
u0.interpolate(u_init)
# Compute the chemical potential df/dc
n = variable(n)
c = variable(c)
f = A * ( c - cle - ( cse - cle ) * h(n) )^2.0 + w * g(n)
dfdc = diff(f, c)
dfdn = diff(f, n)
# Weak statement of the equations
L0 = ( c * q - c0 * q + dt * M * dot( grad( q ), grad( dfdc ) ) ) * dx
L1 = ( n * v - n0 * v + dt * L * alpha * dot( grad( v ), grad( n ) ) + dt * L * dfdn ) * dx
L = L0 + L1
# Compute directional derivative about u in the direction of du (Jacobian)
a = derivative(L, u, du)
# Boundary conditions
bc1 = DirichletBC(ME.sub(0), Constant(0.0), Gamma(), method="pointwise")
bc2 = DirichletBC(ME.sub(1), Constant(0.0), Gamma(), method="pointwise")
bcs = [bc1, bc2]
# Create nonlinear problem and Newton solver
problem = CahnHilliardEquation(a, L, bcs)
solver = NewtonSolver()
solver.parameters["linear_solver"] = "lu"
solver.parameters["convergence_criterion"] = "incremental"
solver.parameters["relative_tolerance"] = 1e-6
# Step in time
t = 0.0
Nsteps = 50
T = Nsteps*dt
file << (u.split()[0], t)
while (t < T):
u0.vector()[:] = u.vector()
solver.solve(problem, u.vector())
