I would like to access the values of a function a boundary. Here is a MWE in case of a MixedElement representing for example the velocity and the pressure:
from dolfinx import fem, mesh
msh = mesh.create_unit_square(MPI.COMM_WORLD, 10, 10)
V = fem.functionspace(msh, ufl.MixedElement([ufl.VectorElement('P', msh.ufl_cell(), 2), ufl.FiniteElement('P', msh.ufl_cell(), 1)]))
W1 = V.sub(1)
Q, _ = W1.collapse()
facets_inflow = mesh.locate_entities_boundary(msh, 1, lambda x : np.isclose(x[0], 0.0))
bdofs_inflow = fem.locate_dofs_topological(Q, msh.topology.dim - 1, facets_inflow)
print(bdofs_inflow)
function = fem.Function(V)
p = function.sub(1).collapse()
print(p.x.array[bdofs_inflow])
This works fine, the script outputs the value of the pressure at the left boundary of the unit square.
Let’s try to do the same thing for with VectorElement:
import pylab as plt
V = fem.FunctionSpace(msh, ufl.VectorElement("DG", msh.ufl_cell(), 2, 3))
W1 = V.sub(0)
print(bdofs_inflow)
p = function.sub(0).collapse()
In this case bdofs_inflow is empty, so I’m doing something wrong. Could you, please, help me to correct this MWE to get the value of p at the left boundary?
