Hi, i am trying to get the coordinates of facets, cells or surfaces in dolfinx. Some of the functions I use have a dependency on the coordinates of my system. As an example: I am trying to find the lowest point of this mesh (Taken from the dolfinx tutorial).
proc = MPI.COMM_WORLD.rank
top_marker = 2
bottom_marker = 1
left_marker = 1
if proc == 0:
# We create one rectangle for each subdomain
gmsh.model.occ.addRectangle(0, 0, 0, 1, 0.5, tag=1)
gmsh.model.occ.addRectangle(0, 0.5, 0, 1, 0.5, tag=2)
# We fuse the two rectangles and keep the interface between them
gmsh.model.occ.fragment([(2, 1)], [(2, 2)])
gmsh.model.occ.synchronize()
# Mark the top (2) and bottom (1) rectangle
top, bottom = None, None
for surface in gmsh.model.getEntities(dim=2):
com = gmsh.model.occ.getCenterOfMass(surface[0], surface[1])
if np.allclose(com, [0.5, 0.25, 0]):
bottom = surface[1]
top = surface[1]
gmsh.model.addPhysicalGroup(2, [bottom], bottom_marker)
gmsh.model.addPhysicalGroup(2, [top], top_marker)
# Tag the left boundary
left = []
for line in gmsh.model.getEntities(dim=1):
com = gmsh.model.occ.getCenterOfMass(line[0], line[1])
if np.isclose(com[0], 0):
left.append(line[1])
gmsh.model.addPhysicalGroup(1, left, left_marker)
gmsh.model.mesh.generate(2)
gmsh.write("mesh.msh")
gmsh.finalize()
I can’t find an implementation similar to this post (Finding cell facet coordinates) in dolfinx, unfortunately. The method cells(), I can’t find in the python API. Did I miss something or is there a better implementation for this?
I import the data, using the approach of Using the GMSH Python API to generate complex meshes | Jørgen S. Dokken
Many thanks in advance
