Getting different results from Equivalent Fourier Integrals in FEniCS
Hello everyone,
I’m using FEniCS (2019 version) to compute a Fourier-type integral of a function q. My first approach is to directly integrate against a complex exponential:
def exp_Fourier(x, xi):
return np.exp(-2j * (xi[0] * x[0] + xi[1] * x[1]))
q_fourier_1 = assemble(exp_proj * q_proj * dx)
I then tried an alternative formulation, which should be mathematically equivalent:
Function V_0(x,y):
def V_0(x, xi, zeta):
return np.exp(-(zeta[0] + xi[0]*1j)*x[0] - (zeta[1] + xi[1]*1j)*x[1])
Function V(x,y):
def V(x, xi, zeta):
return np.exp(((zeta[0] - xi[0]*1j)*x[0] + (zeta[1] - xi[1]*1j)*x[1]) / 2)
q_fourier_2 = assemble(V0_proj * V_proj * V_proj * q_proj * dx)
Even though both expressions should yield the same result in theory, q_fourier_1 and q_fourier_2 produce different outcomes.
Has anyone experienced this kind of issue before? Could it be related to how FEniCS (2019) handles complex expressions or projection? Any insight would be greatly appreciated!
Thanks in advance!
As your code is far from complete, it is really hard to give you any advice (No way anyone can reproduce the results, and various variables are undefined).
One thing that I can see already is that you are using complex numbers in the second formulation. Complex number support is not part of legacy FEniCS, but DOLFINx (see for instance:The Poisson problem with complex numbers — FEniCSx tutorial)
Sorry for that, here is a completed code (for large values of xi the results are really different):
Parameters
xi_val = [20, 15]
zeta_val = [2, 1]
x0_val = 0.0
y0_val = 0.0
d_val = 0.1
Define functions
return np.exp((-(zeta[0] + xi[0]*1j)*x[0] - (zeta[1] + xi[1]*1j)*x[1]) )
def V_1(x, xi, zeta):
return np.exp(((zeta[0] - xi[0]*1j)*x[0] + (zeta[1] - xi[1]*1j)*x[1])/2)
return np.exp(-21j(xi[0] * x[0] + xi[1] * x[1]))
Function Xi:
def phi(x, d, x0, y0):
norm = np.sqrt((x[0]-x0)**2 + (x[1]-y0)**2)
if norm < d:
return np.exp(1+1/((norm/d)**2-1))
return 0.0
Function q_epsilon:
def q_function_epsilon(x, d, x0, y0):
return phi(x, d, x0, y0)
mesh = RectangleMesh(Point(-1, -1), Point(1, 1), 32, 32)
V = FunctionSpace(mesh, “CG”, 3)
— Process q_function—
class PythonQExpression(UserExpression):
def init(self, d, x0, y0, **kwargs):
self.d = d
self.x0 = x0
self.y0 = y0
super().init(**kwargs)
def eval(self, values, x):
    values[0] = q_function_epsilon(x, self.d, self.x0, self.y0)
def value_shape(self):
    return ()
q_expr = PythonQExpression(d=d_val, x0=x0_val, y0=y0_val, degree=2)
q_proj = interpolate(q_expr, V)
— Process V0 —
class PythonV0Expression(UserExpression):
def init(self, xi, zeta, **kwargs):
self.xi = xi
self.zeta = zeta
    values[0] = V_0(x, self.xi, self.zeta)
    return ()
V0_expr = PythonV0Expression(xi=xi_val, zeta=zeta_val)
V0_proj = interpolate(V0_expr, V)
— Process V —
class PythonVExpression(UserExpression):
self.xi = xi
self.zeta = zeta
values[0] = V_1(x, self.xi, self.zeta)
return ()
V_expr = PythonVExpression(xi=xi_val, zeta=zeta_val)
V_proj = interpolate(V_expr, V)
— Process exp_Fourier —
class PythonQFExpression(UserExpression):
def init(self, xi, **kwargs):
self.xi = xi
values[0] = exp_Fourier(x, self.xi)
return ()
F_q_expr = PythonQFExpression(xi=xi_val)
F_q_proj = interpolate(F_q_expr, V)
q_fourier_1 = assemble(V0_proj * V_proj * V_proj * q_proj * dx)
q_fourier_2 = assemble(F_q_proj * q_proj * dx)
print(“q_fourier_1:”, q_fourier_1)
print(“q_fourier_2:”, q_fourier_2)
thank you for your help.
First of all, please format your code with 3x`, ie
```python
#add code here
So that the code can be copy-pasted.
xi_val = [2, 1]
zeta_val = [2, 1]
x0_val = 0.0
y0_val = 0.0
d_val = 0.1
    return np.exp(-2*1j*(xi[0] * x[0] + xi[1] * x[1]))
    if norm < d:
        return np.exp(1 + 1 / ((norm/d)**2 - 1))
        return 0.0
V = FunctionSpace(mesh, "CG", 3)
    def __init__(self, d, x0, y0, **kwargs):
        self.d = d
        self.x0 = x0
        self.y0 = y0
        super().__init__(**kwargs)
        return ()
    def __init__(self, xi, zeta, **kwargs):
        self.xi = xi
        self.zeta = zeta
        return ()
V0_expr = PythonV0Expression(xi=xi_val, zeta=zeta_val, degree=3)
        self.xi = xi
        self.zeta = zeta
        return ()
V_expr = PythonVExpression(xi=xi_val, zeta=zeta_val, degree=3)
    def __init__(self, xi, **kwargs):
        self.xi = xi
        return ()
F_q_expr = PythonQFExpression(xi=xi_val, degree=3)
print("q_fourier_1:", q_fourier_1)
print("q_fourier_2:", q_fourier_2)
