Dear all,
I am trying to import an gmsh-generated mesh into fenics. However, since fenics can’t handle mixed topologies yet, I need to split the mesh up into different files. I’ve followed this tutorial.
Unfortunately, reading the surface (last line ft = xdmf.read_meshtags(mesh, name="Grid")) raises an Error: RuntimeError: Missing entity-vertex connectivity.
Below is a minimum “working”-example, raising that error. I am not sure if I just messed up the gmsh-generation, so I also attached the *.geo-file. The actual was generated using the GUI.
Thanks in advance.
# meshing.py
### Convert from msh to XDMF
out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
return out_mesh
mesh = meshio.read("mesh.msh")
mesh_surf = create_mesh(mesh, "triangle")
meshio.write("mesh_surf.xdmf", mesh_surf)
mesh_vol = create_mesh(mesh, "tetra")
meshio.write("mesh_vol.xdmf", mesh_vol)
### Read XDMF with dolfin
with XDMFFile(MPI.COMM_WORLD, "mesh_vol.xdmf", "r") as xdmf:
ct = xdmf.read_meshtags(mesh, name="Grid")
mesh.topology.create_connectivity(mesh.topology.dim, mesh.topology.dim-1)
with XDMFFile(MPI.COMM_WORLD, "mesh_surf.xdmf", "r") as xdmf:
//+ mesh.geo
SetFactory("OpenCASCADE");
Box(1) = {0, 0, 0, 1, 1, 1};
Physical Surface("s1") = {6};
Physical Surface("s2") = {1};
Physical Surface("s3") = {5};
Physical Surface("s4") = {2};
Physical Surface("s5") = {4};
Physical Surface("s6") = {3};
Physical Volume("dom") = {1};
