I had a couple of questions regarding the whole meshing workflow when using gmsh and meshio to get a mesh suitable for FEniCS.
1. What kind of mesh format is suitable for FEniCS? Is it XML or XDMF? What is the difference between the two? What does the H5 file have to do with the XDMF format?
2. Are there any severe differences when using the gmsh API vs using the pygmsh module to create the geometry and the corresponding mesh?
3. I have used the following code to convert a 2D .msh file to .xdmf format and have a couple of remarks on what I think is happening and please correct me if I am wrong :
a) The cell_data_dict() function returns the cell data of the values under the key ‘triangle’ which is again value under the key ‘gmsh:physical’. So is it basically a nested dictionary? I am a beginner in python so please correct me if my understanding is wrong.
b) Inside meshio.write, in cell_data={“surf_marker” : [tri_data]}, is it basically just writing a dictionary with the key as “surf_marker”? Where is this key useful to us later on? Is it during the post processing of the mesh? Or as I read it during the input of mesh using Dolfin? as seen in question 4)
c) I have seen in a code that @Dokken provided, uses a prune z command to remove the z cordinates before using the points for a 2d case? What was the need and cause of that?
mesh_name = "<filename>"
msh = meshio.read(mesh_name+".msh")
tri_data = msh.cell_data_dict["gmsh:physical"]["triangle"]
meshio.write(mesh_name+"_surf.xdmf",
meshio.Mesh(points=msh.points,
cells={"triangle": msh.cells_dict["triangle"]},
cell_data={"surf_marker": [tri_data]}
line_data = msh.cell_data_dict["gmsh:physical"]["line"]
meshio.write(mesh_name+"_line.xdmf",
cells={"line": msh.cells_dict["line"]},
cell_data={"line_marker": [line_data]}
4. My final question, if I have obtained the .xdmf files for both the surface and the lines, how should be inputting them into a fenics program? Please find my MWE based on an answer by Dokken in another question I came across…
mesh = Mesh()
with XDMFFile("<surfacemesh>.xdmf") as infile:
infile.read(mesh)
with XDMFFile("<linemesh>.xdmf") as infile:
V = FunctionSpace(mesh, CG, 1)
u_D = constant(0.0)
bc_left = DiricheltBC(V, u_D, mf, 1)
bc_right = DirichletBC(V, u0, mf, 3)
bcs = [bc_left, bc_right]
a = inner(grad(u), grad(v))*dx
# Constant forcing function and no Nuemann conditions
f = Constant(-6.0)
L = f*v*dx
# Compute solution
uh = Function(V)
solve(a == L, uh, bcs, solver_parameters={'linear_solver': 'gmres','preconditioner': 'ilu'})
# Save solution in VTK format for Paraview
file = File("poisson.pvd")
file << uh
where the “name_to_read” would be the “surf_marker” or “line_marker” depending on a 2d or 3d mesh.?
Can someone explain what MeshValueCollection and MeshFunctionSize do here?
Also after this if I wanted to set boundary conditions for the left and right boundary would I do that just using as shown in the last line? (Its physical_group tag is 1 and 3 as per the script given below)
Please consider also my script that generates a unit square mesh:
import sys
lc = 0.25
gmsh.model.geo.add_point(-0.5,-0.5,0,lc,1)
gmsh.model.geo.add_point(-0.5,0.5,0,lc,2)
gmsh.model.geo.add_point(0.5,0.5,0,lc,3)
gmsh.model.geo.add_point(0.5,-0.5,0,lc,4)
gmsh.model.geo.add_line(1,2,1)
gmsh.model.geo.add_line(2,3,2)
gmsh.model.geo.add_line(3,4,3)
gmsh.model.geo.add_line(4,1,4)
gmsh.model.geo.add_curve_loop([1,2,3,4],1)
gmsh.model.geo.add_plane_surface([1],1)
gmsh.model.geo.synchronize()
gmsh.model.add_physical_group(1,[1],1,name="left_boundary")
gmsh.model.add_physical_group(1,[2],2,name="bottom_boundary")
gmsh.model.add_physical_group(1,[3],3,name="right_boundary")
gmsh.model.add_physical_group(1,[4],4,name="top_boundary")
gmsh.model.add_physical_group(2,[1],1,name="domain")
gmsh.model.mesh.generate(2)
gmsh.write("unitsquare.msh")
if '-nopopup' not in sys.argv:
gmsh.fltk.run()
gmsh.finalize()
Thanks in advance!!
Wanted to add that this workflow is currently working and I was able to produce the following result for the 2d Poisson problem: ![]()
